857lover 291 #1 Posted March 17, 2022 so i was given a k301 with a starter generator and i wanna know if it will physicaly fit under the hood because its a fair bit taller and its just a bigger engine i dont want to have to cut my hood to makes this fit so im just looking for some words of wisdom i saw a guy on youtube i believe vins rj he has a 857 with a kholer magnum 10hp and it seems very do able i just wanna know what you guys think Share this post Link to post Share on other sites
roadapples 6,987 #2 Posted March 17, 2022 Don't have an 857, but before you cut a hood make a taller hinge bracket or spacer... Share this post Link to post Share on other sites
ebinmaine 81,048 #3 Posted March 17, 2022 26 minutes ago, 857lover said: vins rj He's here on Redsquare... @VinsRJ. 1 Share this post Link to post Share on other sites
Pullstart 71,482 #4 Posted March 17, 2022 (edited) I believe then you’d have essentially a 1057, which was a thing. That said, it should fit just fine *edit K301=12 hp. 1257. Edited March 17, 2022 by Pullstart Share this post Link to post Share on other sites
ebinmaine 81,048 #5 Posted March 17, 2022 2 minutes ago, Pullstart said: I believe then you’d have essentially a 1057, which was a thing. That said, it should fit just fine Oil pan may have been shorter in height on those early engines 2 Share this post Link to post Share on other sites
Pullstart 71,482 #6 Posted March 17, 2022 1 minute ago, ebinmaine said: Oil pan may have been shorter in height on those early engines good point. Share this post Link to post Share on other sites
squonk 48,287 #7 Posted March 17, 2022 (edited) Yes you need the shallow pan and the correct connecting rod to go with it. A K301 will use a lot more fuel than a K181. You'll get stranded in the woods. Edited March 17, 2022 by squonk 1 2 Share this post Link to post Share on other sites
WHX?? 58,324 #8 Posted March 17, 2022 Or bob the rod....or use a Cub short pan and hack the frame up to fit. You would also need a different pulley. Better idea is to look for a roller long frame to put it in. Share this post Link to post Share on other sites
ebinmaine 81,048 #9 Posted March 17, 2022 8 minutes ago, WHX?? said: roller long frame Just leave the 857 as it is and go get another tractor. Perfect excuse. I mean reason. 1 Share this post Link to post Share on other sites
857lover 291 #10 Posted March 17, 2022 i have a k301 with a flat oil pan it is 2and a half inches tall is there any thinner pans out there i’m having some clearance issues that i’m trying to resolve 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #11 Posted March 17, 2022 29 minutes ago, 857lover said: i have a k301 with a flat oil pan it is 2and a half inches tall is there any thinner pans out there i’m having some clearance issues that i’m trying to resolve http://gardentractorpullingtips.com/oilpan.htm There are diffrent oil pans, but you will need to found a shorter oilslinger Share this post Link to post Share on other sites
Achto 32,891 #12 Posted March 17, 2022 53 minutes ago, 857lover said: i’m having some clearance issues that i’m trying to resolve Trying to stuff a 12 horse in your short frame??? 2 Share this post Link to post Share on other sites
857lover 291 #13 Posted March 17, 2022 Just now, Achto said: Trying to stuff a 12 horse in your short frame??? you caught me red handed it even has a starter generator 2 Share this post Link to post Share on other sites
Achto 32,891 #14 Posted March 17, 2022 25 minutes ago, Maxwell-8 said: but you will need to found a shorter oilslinger Or grind your existing oil slinger down. 1 Share this post Link to post Share on other sites
857lover 291 #15 Posted March 17, 2022 yeah that’s what i’ve heard but what do i look up to find one of theese pans what did they come off of Share this post Link to post Share on other sites
Achto 32,891 #16 Posted March 17, 2022 Just now, 857lover said: you caught me red handed Find the part number for an oil pan for a 1045, These were big block's in a short frame from the factory. Share this post Link to post Share on other sites
857lover 291 #17 Posted March 17, 2022 2 minutes ago, Achto said: Find the part number for an oil pan for a 1045, These were big block's in a short frame from the factory. that’s is going to be a little difficult but i will see what i can find Share this post Link to post Share on other sites
Achto 32,891 #18 Posted March 17, 2022 (edited) 7 minutes ago, 857lover said: that’s is going to be a little difficult but i will see what i can find A 1045 came with a K241AS. Yes I know that is a 10hp engine but the oil pan should fit a K301. A quick search found some flat pans on Edited March 17, 2022 by Achto 1 Share this post Link to post Share on other sites
857lover 291 #19 Posted March 17, 2022 (edited) 4 minutes ago, Achto said: A 1045 came with a K241AS. Yes I know that is a 10hp engine but the oil pan should fit a K301. A quick search found some flat pans on what are you putting in the search bar i can’t seem to find one i see some that came off a cub but they have like a drain plug at the bottom that would interfere Edited March 17, 2022 by 857lover Share this post Link to post Share on other sites
857lover 291 #20 Posted March 17, 2022 6 minutes ago, Achto said: A 1045 came with a K241AS. Yes I know that is a 10hp engine but the oil pan should fit a K301. A quick search found some flat pans on or if you could send me the link i’d really appreciate that Share this post Link to post Share on other sites
Achto 32,891 #21 Posted March 17, 2022 (edited) 15 minutes ago, 857lover said: if you could send me the link i’d really appreciate that Did not find one for a WH per say. Important thing to look for is the threaded mounting holes in the bottom for the right hand side mounting bolts. You could also try posting in the want adds here for a 1045 oil pan. Edited March 17, 2022 by Achto Share this post Link to post Share on other sites
857lover 291 #22 Posted March 17, 2022 5 hours ago, squonk said: Yes you need the shallow pan and the correct connecting rod to go with it. A K301 will use a lot more fuel than a K181. You'll get stranded in the woods. yea i’ve thought about that too Share this post Link to post Share on other sites
Achto 32,891 #23 Posted March 17, 2022 5 hours ago, squonk said: A K301 will use a lot more fuel than a K181. You'll get stranded in the woods. Yet when it comes to working hard, my K301 does better on fuel than my K241 does. Share this post Link to post Share on other sites
daveoman1966 3,884 #24 Posted March 17, 2022 Is this what you want... It is approx 1-1/4" deep (outside). Share this post Link to post Share on other sites
953 nut 70,064 #25 Posted March 17, 2022 22 minutes ago, Achto said: A 1045 came with a K241AS. Yes I know that is a 10hp engine but the oil pan should fit a K301. A quick search found some flat pans on The 241AS is what we call a small block, pan from it will not fit a BIG Block. Your best bet is to build a taller hood hinge and steering tower. Your best Share this post Link to post Share on other sites
