nicky1 0 #1 Posted March 14, 2022 I was just curious if anyone has put a cast iron Briggs in a C-165 tractor. I have this tractor with a Kohler 12 horse that threw a rod. The Briggs is a 10 hp cast iron with electrric start. Share this post Link to post Share on other sites
ebinmaine 80,302 #2 Posted March 14, 2022 My significant other, trina, her first restoration was a 657 that we transplanted a 1978 Briggs 8 horse engine into. If the engine you are going to use does not have lateral crankshaft support you'll have to use an electric clutch. Other than that it's just a matter of lining up the mounts versus the original crankshaft location. Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #3 Posted March 14, 2022 I would sure try it. I think those briggs are good engines. Parts are plentiful and easy to get. 2 Share this post Link to post Share on other sites
ebinmaine 80,302 #4 Posted March 14, 2022 1 minute ago, OutdoorEnvy said: I would sure try it. I think those briggs are good engines. Parts are plentiful and easy to get. Agreed. Before I started using Kohler engines just a few years ago because of Wheelhorses I had always been a Briggs guy. Share this post Link to post Share on other sites
JoeM 10,157 #5 Posted March 14, 2022 Gear drive or hydro? Pretty significant difference 16 down to 10 HP. The hydro has parasitic hp use. May be 5-6 range. Not sure what you want to use it for but makes a difference. If gear driven it would be fine, wheel horse made a GT1100 using a briggs 11hp they ran great. Share this post Link to post Share on other sites
richmondred01 2,388 #6 Posted March 14, 2022 (edited) I’ve got a k301, wheel horse spec, with under 500 hours ready to drop in. no need for buying electronic pto. Drop it in and go. video of it running available. Edited March 14, 2022 by richmondred01 1 1 Share this post Link to post Share on other sites
JoeM 10,157 #7 Posted March 14, 2022 this is the adapter plate on the old 11hp I have in the junk pile. Share this post Link to post Share on other sites
