857lover 291 #1 Posted March 13, 2022 i just noticed that on this new 6 speed that when i get stuck usually the wheels would keep just spinning and digging a hole but it doesn’t do that the wheels just stop trying to turn and the belt stopped moving because my wheels stopped moving why is this ? Share this post Link to post Share on other sites
Handy Don 17,490 #2 Posted March 13, 2022 Worn or wrong size belt or contaminated belt surface are likely. However, the horse will slip the belt before it'll stall the engine so if you are really locked up, that'll be the reason. 3 Share this post Link to post Share on other sites
cschannuth 3,821 #3 Posted March 13, 2022 The belt is slipping on the engine pulley. 2 Share this post Link to post Share on other sites
WHX?? 58,218 #4 Posted March 13, 2022 what kind of belt and what condition is the belt in ? 2 Share this post Link to post Share on other sites
857lover 291 #5 Posted March 13, 2022 (edited) 9 minutes ago, WHX?? said: what kind of belt and what condition is the belt in ? it’s a brand new belt it’s one of those blue ones i forget the brand and it’s a 70 inch belt and it’s all strange when it’s in 3rd high you let out the clutch to move and it starts slow and kind of builds up speed Edited March 13, 2022 by 857lover Share this post Link to post Share on other sites
857lover 291 #6 Posted March 13, 2022 1 hour ago, Handy Don said: Worn or wrong size belt or contaminated belt surface are likely. However, the horse will slip the belt before it'll stall the engine so if you are really locked up, that'll be the reason. it’s just weird it only does it in 3rd high Share this post Link to post Share on other sites
wallfish 20,637 #7 Posted March 13, 2022 (edited) You need a stronger spring for the pedal return. 3rd gear applies the most force on the belt and it's slipping on the engine pulley as noted Edited March 13, 2022 by wallfish 3 Share this post Link to post Share on other sites
953 nut 69,551 #8 Posted March 14, 2022 the closer to one to one your engine to axle gear ratio comes the higher the demand you are placing on the belt. Stronger spring or a shorter belt will probably do the trick. 2 Share this post Link to post Share on other sites
lynnmor 9,042 #9 Posted March 14, 2022 22 minutes ago, 857lover said: it’s just weird it only does it in 3rd high Not weird at all, it takes more torque to get things turning with less gear reduction. 1 Share this post Link to post Share on other sites
857lover 291 #10 Posted March 14, 2022 1 hour ago, wallfish said: You need a stronger spring for the pedal return. 3rd gear applies the most force on the belt and it's slipping on the engine pulley as noted is the spring from a 6 speed diffrent than the one on a 3speed Share this post Link to post Share on other sites
Handy Don 17,490 #11 Posted March 14, 2022 Just now, 857lover said: is the spring from a 6 speed diffrent than the one on a 3speed You can find this yourself. Search in the Files/Document section of this site for the Illustrated Parts Manuals (IPM) for both your tractor and the donor tractor (probably a 1067). Look at the part numbers. 1 Share this post Link to post Share on other sites
Pullstart 71,296 #12 Posted March 14, 2022 You could try using your toe and pulling the clutch pedal back. That would simulate what @wallfish is saying… 2 Share this post Link to post Share on other sites
oldlineman 1,810 #13 Posted March 14, 2022 All of the above. Bob Share this post Link to post Share on other sites
peter lena 10,076 #14 Posted March 14, 2022 @857lover would go over every linkage point with aerosol lubricant , make the rust run out , grease related fittings , that linkage should work seamlessly , this is only a basic idea, don't know what the related areas are like , pete 1 Share this post Link to post Share on other sites
squonk 48,156 #15 Posted March 14, 2022 (edited) You're going off roading. You do not have stock sized pullies. A 70" belt may not be the correct length. Are your pullies the same width? The same profile? Also The used transmission may have worn hubs /axle keyways. The load you're putting on it may be enough to make them slip. How about some pictures so we can see your pulley belt set up? Edited March 14, 2022 by squonk 4 Share this post Link to post Share on other sites
857lover 291 #16 Posted March 14, 2022 (edited) 3 hours ago, squonk said: You're going off roading. You do not have stock sized pullies. A 70" belt may not be the correct length. Are your pullies the same width? The same profile? Also The used transmission may have worn hubs /axle keyways. The load you're putting on it may be enough to make them slip. How about some pictures so we can see your pulley belt set up? i will definitely grab some pictures after work but i have noticed my right hub keeps sliding back and forth like my set screw isn’t doing anything but also the trans pulley is a 4 inch diameter which is the same size as the one on my 3speed only difference is the bore is smaller Edited March 14, 2022 by 857lover Share this post Link to post Share on other sites
squonk 48,156 #17 Posted March 14, 2022 That rt. hub is probably your entire issue. What pulley are you running on the engine? 1 Share this post Link to post Share on other sites
857lover 291 #18 Posted March 14, 2022 52 minutes ago, squonk said: That rt. hub is probably your entire issue. What pulley are you running on the engine? i’m not sure it’s the one that’s been in the tractor since i’ve owned it Share this post Link to post Share on other sites
Ed Kennell 47,399 #19 Posted March 14, 2022 4 hours ago, squonk said: That rt. hub is probably your entire issue. What pulley are you running on the engine? May be Mike, but he states the belt is not moving. Share this post Link to post Share on other sites
857lover 291 #20 Posted March 14, 2022 1 hour ago, Ed Kennell said: May be Mike, but he states the belt is not moving. yea the belt dosent spin when its happening Share this post Link to post Share on other sites
857lover 291 #21 Posted March 14, 2022 10 hours ago, squonk said: You're going off roading. You do not have stock sized pullies. A 70" belt may not be the correct length. Are your pullies the same width? The same profile? Also The used transmission may have worn hubs /axle keyways. The load you're putting on it may be enough to make them slip. How about some pictures so we can see your pulley belt set up? Share this post Link to post Share on other sites
953 nut 69,551 #22 Posted March 14, 2022 Can't be sure from the picture but the engine pulley looks wide like a "B" bely pulley, belt should be riding high in the pulley so it has the maximum side contact area. Share this post Link to post Share on other sites
squonk 48,156 #23 Posted March 14, 2022 Pulley on trans also doesn't look stock to me and the idler looks high like the belt is too long. Share this post Link to post Share on other sites
Handy Don 17,490 #24 Posted March 15, 2022 (edited) I'm more noticing that the blue fabric on the top and bottom is there but gone on the sides. Also, as noted, belt is riding low in the groove. DEAD BELT is my vote (new belt = better grip ✅, ride higher ✅, pull the idler down a bit more ✅) And yeah, non-stock drive pulley on the trans but I don't think that's the issue because the belt stopped moving. Edited March 27, 2022 by Handy Don Share this post Link to post Share on other sites
squonk 48,156 #25 Posted March 15, 2022 The only thing that will stop the belt is it slipping on the engine pulley 2 1 Share this post Link to post Share on other sites
