Mike in NC
New Sneakers for the 312-H
Mike in NC
Our 312-H needed new tires, so it got some. V-61's for the front and Deestone Ags for the rear. Filled the fronts with fluid so far. Will fill the rears later.
  • Excellent 4
ebinmaine
How do you feel about the sizing of those DeeStones compared to what you took off.?
Mike in NC
The ones that I took off were 23/9.50 X 12 and the Deestonnes say 23/10.50 X 12 but are about the same size as the 23/9.50's that I took off. This is the reason that I went with the Deestones so that they would be close to the originals. So, they are a little smaller then the size on them.
I have read reviews of the Deestones running smaller so I went with them to give it a try, also I could not find 9.50 and I don't want real wide of tires.. And so far I am happy with them. I have used the tractor around the yard doing spring cleanup and they seem good.
Edited by Mike in NC
ebinmaine
How about the outside diameter?
Do the Deestones measure an accurate 23" ?
Mike in NC
I just went out and measured them, and aired up, they are a real close 23. It might be like a 22 3/4 but it is real close. I inflated one new one and put it beside one of the old ones that was still on a rim and they seamed just about the same diameter/height.
Sparky
I really like those fronts.
  Are they 15x5x6 or 16x6.50x8’s ?
Mike in NC
Thank you. They are 15/6.00 x 6.
