clueless 3,360 #1 Posted March 11, 2022 I want to swap out my amp meter on my '77 C-160 with a volt meter. I'm sure it's not as simply as disconnecting the two wires on the amp meter and reconnecting them to the volt meter. What do I need to do, diagrams (Richard) would be nice. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #2 Posted March 11, 2022 Join the 2 wires at the ammeter now and insulate well as they are still used to power the tractor. Connect the (+) voltmeter lead to the wire feeding the (+) terminal of the ignition coil. Ground the (-) voltmeter lead to the chassis. This way the voltmeter is not powered when the key is off. 4 1 Share this post Link to post Share on other sites
JoeM 9,679 #3 Posted March 11, 2022 1 hour ago, gwest_ca said: Connect the (+) voltmeter lead to the wire feeding the (+) terminal of the ignition coil I used that way to connect my last electric fuel pump. Simple and out in the open. 1 Share this post Link to post Share on other sites
953 nut 64,650 #4 Posted March 12, 2022 2 hours ago, clueless said: What do I need to do, diagrams (Richard) would be nice. No diagram needed, just do what Garry @gwest_ca said and you will be fine. 2 Share this post Link to post Share on other sites
