JoeM 10,317 #1 Posted March 5, 2022 Been messing around with some parts that need painted and were pitted but not rusted out. I read where it will adhere if you can paint over top of bedliner coating if done within the first 24 hours after the bedliner coating is applied. Tried a couple foot pads and they seem pretty durable. Trying it on a seat pan now. before paint after 7 4 Share this post Link to post Share on other sites
sjoemie himself 3,264 #2 Posted March 5, 2022 That's something different! I think I like it 4 Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted March 6, 2022 what brand... 1 Share this post Link to post Share on other sites
oliver2-44 11,791 #4 Posted March 6, 2022 if the parts you are putting bedliner on are rusted, may I suggest you treat them with Phosphoric Acid such as OSPH to kill the rust. Awhile back a member here stripped the bubbling bedline off a new to him fender pan that has rust growing under it. I like the look! 2 Share this post Link to post Share on other sites
JoeM 10,317 #5 Posted March 6, 2022 Iron Armor Truck Bed Coating from Harbo Fright. No rust, metal was wire cup wheeled to bare metal and primed with Rustoleum primer. Light sand with 500. To get the consistent coating I had to hold the can about 20 inch away from the piece or it was spotty and streaky. I tested Rustoleum bed coating and it gave a more uneven texture. 2 1 Share this post Link to post Share on other sites
kpinnc 19,036 #6 Posted March 6, 2022 Interesting. Looks nice! Curious just how durable it is. If it's pretty tough, that will be great on footrests. Let us know how it works. 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #7 Posted March 6, 2022 Looks better then I would have thought it would. Are you doing the rest of the tractor too now? 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #8 Posted March 6, 2022 3 hours ago, oliver2-44 said: Awhile back a member here stripped the bubbling bedline off a new to him fender pan that has rust growing under it That could have been me... I think it was rusting under the bedliner because whomever sprayed the bedliner did almost ZERO prep. Just sprayed over whatever was there. I think if one were to perform proper prep as Joe obviously has, it should be a long lasting rust free deal! It does look pretty neat! Share this post Link to post Share on other sites
953 nut 70,065 #9 Posted March 6, 2022 I have used Plasti Dip spray on the underside of mower decks and had good results. It gives a smooth finish and comes in colors including RED. https://plastidip.com/our-products/plasti-dip/ Share this post Link to post Share on other sites
JoeM 10,317 #10 Posted March 6, 2022 (edited) 12 hours ago, OutdoorEnvy said: Are you doing the rest of the tractor too now? All but the hood. I have the foot pads done top and bottom like the seat pan. I put a tape in lay on the foot pans so the tread tape would stick. I forgot to do this on the rear pan for the decal. might have to improvise. I have it all done in a couple week and will post a pic or two. Edited March 6, 2022 by JoeM 5 Share this post Link to post Share on other sites
Chris G 3,392 #11 Posted March 7, 2022 Ive painted some parts for my truck with bedliner and then color matched with paint and it held up well. Bit i definitely never thought of doing a tractor that way. Looks GOOD! Share this post Link to post Share on other sites
Brockport Bill 2,500 #12 Posted March 17, 2022 i did my footrests with bedliner black a couple weeks ago at suggestion of a Red Sq friend --- came out looking good -- primer, plus 3 coats of BL spray -- i was looking to mirror the "black" appearance elsewhere on tractor -- black engine, tires, steering wheel, black hood C175, tunnel and dash plates, etc --- the idea to do footrests started with discussion about availability and where to get footrest tread material - so decided to try the bedliner spray as alternative --- have not yet reinstalled the footrests on tractor, or actually used yet to determine effeciveness of being "slip proof" etc -- but at least they look cool so far Share this post Link to post Share on other sites
Brockport Bill 2,500 #13 Posted March 17, 2022 Some people suggested undercoat spray, but i decided bed liner option Share this post Link to post Share on other sites
