Rusty Tinsnips 477 #1 Posted March 1, 2022 One day getting ready to plow snow and the Raider 14 won't start due to low battery. This is a new battery put in 2 months ago. I jump start it and I notice the ammeter is showing about 5v discharge. So after plowing I check the battery with a digital meter and it shows about 12v when not running and 12 to 15 (all over the place) when running. Today I put a new regulator on and get 15v to 16v running. Battery has been on a tender for a week or so. It reads 13.6 not running. This is what I see when I took the old one off. The ammeter still shows 5v discharge and around 7v discharge with lights on when running. 1 Share this post Link to post Share on other sites
oldlineman 1,810 #2 Posted March 1, 2022 I would say remove the amp meter and install a voltmeter. 2 1 Share this post Link to post Share on other sites
squonk 48,152 #3 Posted March 1, 2022 That regulator is just about toast. Get a new one. Clean the mounting surface so it gets a good ground and clean/replace the wire terminals. Most likely the wire connections got funky and it increased the amps flowing through the regulator and started a nice slow cook. 1 1 Share this post Link to post Share on other sites
Rusty Tinsnips 477 #4 Posted March 1, 2022 20 minutes ago, oldlineman said: I would say remove the amp meter and install a voltmeter. That is in the plan. Thanks. 2 Share this post Link to post Share on other sites
pacer 3,180 #5 Posted March 1, 2022 Yep, thats a familiar sight around my shop. Those .... blankety blankety ammeters Glad to see youre going to a volt meter!! 1 Share this post Link to post Share on other sites
Pullstart 71,296 #6 Posted March 2, 2022 17 hours ago, Rusty Tinsnips said: ammeter is showing about 5v discharge 17 hours ago, Rusty Tinsnips said: ammeter still shows 5v discharge and around 7v discharge with lights on I know that you know what’s going on, but just to clarify it’s reading an amperage draw… not voltage. 1 Share this post Link to post Share on other sites
Roger R 473 #7 Posted March 2, 2022 Volt meter change out is a good idea, however your ammeter seems to be doing the job its designed for. Check the AC output of the alternator before changing anything. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #8 Posted March 2, 2022 Try this. Turn the ignition switch to the RUN position with the engine not running. Check voltage across battery terminals. Move red test lead to the DC+ on the regulator. Should have same voltage as across battery lugs. If not the same voltage fix the wiring between the regulator DC+ terminal and the battery. It likely passes through the ignition switch. The regulator requires battery voltage to turn it on before it can regulate the stator charge current. 4 Share this post Link to post Share on other sites
squonk 48,152 #9 Posted March 2, 2022 If you really want to know what your charging voltage is, buy a cheap analog voltmeter. I have seen many digital meters no matter what brand or price level give wild fluctuating readings on a running engine 4 Share this post Link to post Share on other sites
Handy Don 17,488 #10 Posted March 2, 2022 18 minutes ago, squonk said: If you really want to know what your charging voltage is, buy a cheap analog voltmeter. I have seen many digital meters no matter what brand or price level give wild fluctuating readings on a running engine Especially true with the S/G regulators "pulsing" the charge! Share this post Link to post Share on other sites
Rusty Tinsnips 477 #11 Posted March 2, 2022 5 hours ago, Roger R said: Check the AC output of the alternator before changing anything. I checked that first and got around 30v. 6 hours ago, Pullstart said: I know that you know what’s going on maybe... 2 Share this post Link to post Share on other sites
Rusty Tinsnips 477 #12 Posted March 2, 2022 4 hours ago, gwest_ca said: Move red test lead to the DC+ on the regulator. Should have same voltage as across battery lugs. Thanks, will do. At the battery now, I get 15v to 16v at full throttle. But the gauge still shows negative. With key OFF the gauge is centered. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #13 Posted March 2, 2022 31 minutes ago, Rusty Tinsnips said: But the gauge still shows negative. With key OFF the gauge is centered. There is a good chance the ammeter is wired backwards. To reverse the gauge leads remove the negative cable from the battery and then reverse the ammeter leads. Reconnect negative battery cable. Before - The ammeter still shows 5v amps discharge and around 7v amps discharge with lights on when running After suspected - The ammeter shows 5 amps charge and around 7 amps charge with lights on when running 3 Share this post Link to post Share on other sites
Rusty Tinsnips 477 #14 Posted March 2, 2022 1 minute ago, gwest_ca said: There is a good chance the ammeter is wired backwards. lol I never would have thought of that. It does make sense. It is exhibiting strange behavior. Thanks. Share this post Link to post Share on other sites
953 nut 69,544 #15 Posted March 3, 2022 21 hours ago, squonk said: I have seen many digital meters no matter what brand or price level give wild fluctuating readings on a running engine If the digital meter is anywhere close to the flywheel the rotating magnetic field of the flywheel will be picked up by induction and cause fluctuations. 1 Share this post Link to post Share on other sites
WHX?? 58,214 #16 Posted March 4, 2022 (edited) I have two of these now https://www.ebay.com/itm/303334048943 with good luck. Edited March 4, 2022 by WHX?? flip pic Share this post Link to post Share on other sites
Handy Don 17,488 #17 Posted March 4, 2022 1 hour ago, WHX?? said: I have two of these now https://www.ebay.com/itm/303334048943 with good luck. How does one interpret the red and orange dots? Share this post Link to post Share on other sites
WHX?? 58,214 #18 Posted March 4, 2022 I forget exactly what voltage the lights transition at. In a nut shell the lower the voltage drops the more the orange lights drop out. Once it it hits about 13 volts a series of green lights start. So green is charging good, orange is ok and red is you is just running on battery and gonna run out of go juice. It was just meant to be some eye candy for a custom 1055 build. I liked it so much that got one for a C-145 to replace a ammeter that was useless. The 145 had no regulator just a rectifier that overcharged with long seat times so this was a really a nice way to monitor and avoid cooking the battery. If the voltage got too high I flip the headlights on to bring the voltage back down. For less than a Jackson I really expected it to only last a couple of years but going on what three now and still works good. Build thread here... 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #19 Posted March 4, 2022 On 3/2/2022 at 2:36 PM, Rusty Tinsnips said: 15v to 16v at full throttle If you're seeing that much voltage at the battery you are charging the living poop out of that battery. Probably cooking it. OR, the battery is really bad, and already cooked. Voltmeters are fine... but IMHO an Ammeter is also necessary. 2 Share this post Link to post Share on other sites
WHX?? 58,214 #20 Posted March 4, 2022 7 minutes ago, Jeff-C175 said: Probably cooking it. Medium rare here... 1 Share this post Link to post Share on other sites
MAD MARK 74 #21 Posted April 10, 2022 On 3/4/2022 at 12:33 PM, Handy Don said: How does one interpret the red and orange dots? Direct analog 8~10.5V 11-12.5V 13~18 V LED 20 pcs red x 6 pcs yellow x 4 pcs green x 10 pcs Share this post Link to post Share on other sites
peter lena 10,076 #22 Posted April 10, 2022 @Rusty Tinsnips do a ground check , see if that helps stabilize the issue , go from battery ground cable bolt point to mount bolts on that , regularly use small alligator clip test wires to verify what's working , that cooling tin work is often corroded and rarely grounded . since upgrading all my grounding areas , my electrical issues are gone , just a suggestion , pete Share this post Link to post Share on other sites
peter lena 10,076 #23 Posted April 10, 2022 @Rusty Tinsnips notice the yellow electrical lug fitting , in the picture ? was having erratic charging issues ,since adding this and similar ground wires to my electrical set up , the problems are gone .BASE LINE , another separate battery cable from battery bolt area behind dash , to engine corner / frame area , near clutch pedal . bolt on 3/8 electrical lug , dielectric grease , serrated washers , from there run 10-12 ga wire to rectifier mount on cooling tin point , and from there to headlights , tell me how that works. lots of starts , no problems , keep it grounded , pete Share this post Link to post Share on other sites
