Redav72 231 #1 Posted February 19, 2022 Took apart the vacuum fuel pump on K-161S this afternoon to clear a scum blockage. I found that the vacuum diaphragm has a cut in it and one of the two seals for the one-way valves was missing. I had ordered a re-build kit for what I thought was the correct fuel-pump but it was the mechanical model. Has anyone had any luck finding a re-build kit for the vacuum version of the fuel pump? Otherwise does anyone have a recommendation on a diaphragm material that I could use to cut my own? I'll also need a small disc to serve as the second gate in the out side one-way valve. Share this post Link to post Share on other sites
wallfish 18,627 #2 Posted February 19, 2022 @buckrancher Brian was making those diaphragms but don't know for sure anymore. Try sending him a PM if he doesn't reply here on the thread. If you use the search you can find other threads on here where some have used other vacuum pulse pumps for replacements Share this post Link to post Share on other sites
RED-Z06 2,681 #3 Posted February 20, 2022 Got a photo of the pump you have? Share this post Link to post Share on other sites
J854D 141 #4 Posted February 20, 2022 A company called Then & Now Automotive has had complete Kohler vacuum fuel pump repair kits available before. Their website is undergoing some upgrades & I wasn’t able to find that kit just now. Try giving them a call. There is a link to their website here on this forum. Go to Wheel Horse Reference & click on Red Square links and choose Parts Suppliers. It is under the title of Kohler metal body fuel pump repair kits. I have also used @buckrancher for just the vacuum diaphragm like @wallfish had mentioned. Good product & good service! -JD- Share this post Link to post Share on other sites
J854D 141 #5 Posted February 20, 2022 After a little more searching on Then & Now Automotive’s website I was able to find the fuel pump kit you need. Their part number is AC-4S-VAC. It looks like it contains everything you’ll need! -JD- 3 Share this post Link to post Share on other sites
pfrederi 18,971 #6 Posted February 20, 2022 For only a few bucks more you can get a quality Facet electric pump 1 Share this post Link to post Share on other sites
Redav72 231 #7 Posted February 20, 2022 Thanks all. Will keep the electric pump in mind for future projects but want to stick as close to stock for this one. Ordered the kit from Then & Now, looking forward to hearing this engine sing again. 1 Share this post Link to post Share on other sites
