RED-Z06 2,718 #226 Posted February 17, 2022 3 minutes ago, TJ Salyers said: Is where the screws are is that the part I want to take off? Yep, remove the choke, remove the screws, whole top lifts off. 1 1 Share this post Link to post Share on other sites
TJ5208 1,841 #227 Posted February 17, 2022 Just now, RED-Z06 said: Yep, remove the choke, remove the screws, whole top lifts off. And that's how I would get to these holes you're talking about? 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #228 Posted February 17, 2022 1 minute ago, TJ Salyers said: And that's how I would get to these holes you're talking about? That would give you access to the pilot jet, bowl, float, inlet needle and seat...all of it 2 Share this post Link to post Share on other sites
TJ5208 1,841 #229 Posted February 17, 2022 Just now, RED-Z06 said: That would give you access to the pilot jet, bowl, float, inlet needle and seat...all of it Okay thanks my brother which is a mechanic thanks that the main jet is clogged up so will do it all this help. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #230 Posted February 17, 2022 1 minute ago, TJ Salyers said: Okay thanks my brother which is a mechanic thanks that the main jet is clogged up so will do it all this help. Its likely all gummy...but it was running right? Just with some choke? 2 Share this post Link to post Share on other sites
TJ5208 1,841 #231 Posted February 17, 2022 Just now, RED-Z06 said: Its likely all gummy...but it was running right? Just with some choke? Yeah it was running perfect and then now I have to run with half choke. 1 Share this post Link to post Share on other sites
Achto 31,520 #232 Posted February 17, 2022 (edited) Great advise @RED-Z06 thanks for sharing the pics. @TJ Salyers to simplify things. Would you drink through a straw out of a cup that is filled with mud & sludge?? Your engine does not want to either. Think of your float bowl as the cup and your jets as the straw. Clean them out & your engine will be much happier. Edited February 17, 2022 by Achto 3 1 Share this post Link to post Share on other sites
TJ5208 1,841 #233 Posted February 17, 2022 Okay thanks guys I'll see what I can do tomorrow. 1 Share this post Link to post Share on other sites
Achto 31,520 #234 Posted February 17, 2022 @TJ Salyers I quick search found a video for you to watch. The engine is on a JD but it's a Onan engine just the same. 3 2 Share this post Link to post Share on other sites
TJ5208 1,841 #235 Posted February 17, 2022 50 minutes ago, Achto said: @TJ Salyers I quick search found a video for you to watch. The engine is on a JD but it's a Onan engine just the same. Thank you. 2 Share this post Link to post Share on other sites
WHX?? 55,997 #236 Posted February 17, 2022 Saw this somewhere today.... psychic power on the blink If things don’t work give me a little to go on, please. “Won’t run” doesn’t help. 2 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #237 Posted February 17, 2022 47 minutes ago, WHX?? said: Saw this somewhere today.... psychic power on the blink If things don’t work give me a little to go on, please. “Won’t run” doesn’t help. Used to piss me off to no end when a co-worker would sign in a piece of equipment and just say "wont run". Wont crank: on turning the key nothing happens. Wont start: cranks over but wont run on its own. Wont Run right: cranks over, starts, runs incorrectly. 3 Share this post Link to post Share on other sites
ranger 1,851 #238 Posted February 17, 2022 15 minutes ago, RED-Z06 said: Used to piss me off to no end when a co-worker would sign in a piece of equipment and just say "wont run". Wont crank: on turning the key nothing happens. Wont start: cranks over but wont run on its own. Wont Run right: cranks over, starts, runs incorrectly. My ex boss worked as an engineer at a large mining site in, I think he said Gambia?. Anyway, one night they had a ‘Cat’ dozer driver call in request an engineer attend because the engine dipstick would not stay in? He said they asked all the relevant questions, ie “Is the engine smoking excessively, etc?” The operator apparently wouldn’t give a straight answer, just kept asking for them to attend. When they arrived, the reason was obvious, the dozer had run off the track and was now upside down! He used to delight in telling this story regularly! 1 5 Share this post Link to post Share on other sites
Handy Don 16,247 #239 Posted February 17, 2022 (edited) 1 hour ago, ranger said: My ex boss worked as an engineer at a large mining site in, I think he said Gambia?. Anyway, one night they had a ‘Cat’ dozer driver call in request an engineer attend because the engine dipstick would not stay in? He said they asked all the relevant questions, ie “Is the engine smoking excessively, etc?” The operator apparently wouldn’t give a straight answer, just kept asking for them to attend. When they arrived, the reason was obvious, the dozer had run off the track and was now upside down! He used to delight in telling this story regularly! Great story! I'll bet they just righted it, got the dipstick back in, added some oil and put it right back to work! Hard sometimes for we who understand mechanical things (more or less ) to fully get our head around how those who simply don't have any aptitude for it get by in the world. Recall that Cadillac was the first to introduce an electric starter for an automobile--there's money to be made making it (relatively) foolproof! Edited February 17, 2022 by Handy Don 3 Share this post Link to post Share on other sites
kpinnc 17,804 #240 Posted February 17, 2022 In the military, everything has an acronym. When I was in aviation maintenance, there was a push to simplify trouble reporting in aircraft logbooks. Acronyms were acceptable, and the shorter the entry, the better. Army helicopters have tie down chains nowadays because a microburst once destroyed an entire battalion of helicopters in Texas in the late 90s. Because only certain parts of an aircraft are rugged enough for chains, some use different lengths depending on where they go. So four chains for the Apache have two that are longer in the back. I remember a new pilot listing a problem as "chains do not reach anchors" after a night flight that was signed off by mechanic as "stretching completed". Over time such silliness devolved into reports like "ORT INOP" signed off as "RPR CMPLT". Of course these became hilarious over time, because you often had no idea what was wrong- or what was actally fixed. Not a good thing with $30 million aircraft... Typical guvment work I guess. 1 4 Share this post Link to post Share on other sites
Handy Don 16,247 #241 Posted February 18, 2022 2 hours ago, kpinnc said: Over time such silliness devolved into reports like "ORT INOP" signed off as "RPR CMPLT". Of course these became hilarious over time, because you often had no idea what was wrong- or what was actally fixed. Not a good thing with $30 million aircraft... A former fighter jet avionics crew chief, and later my boss, introduced me to the "brogan adjustment" he'd sometimes employed in the AF. He took off his shoe and whacked the side of one of our servers thinking it might restart correctly. 5 Share this post Link to post Share on other sites
kpinnc 17,804 #242 Posted February 18, 2022 1 minute ago, Handy Don said: A former fighter jet avionics crew chief, and later my boss, introduced me to the "brogan adjustment" he'd sometimes employed in the AF. He took off his shoe and whacked the side of one of our servers thinking it might restart correctly. We'd refer to that as a HEFRR. Heel Actuated Full Rapid Reset. 4 Share this post Link to post Share on other sites
Achto 31,520 #243 Posted February 18, 2022 2 hours ago, kpinnc said: Army helicopters I have friend that was a helicopter mechanic, working on Chinook's. This was his advise to me. " If you get on an Army helicopter and it is not leaking hydraulic fluid, GET OFF because this means that it is out of fluid" . 3 1 Share this post Link to post Share on other sites
kpinnc 17,804 #244 Posted February 18, 2022 (edited) 20 minutes ago, Achto said: have friend that was a helicopter mechanic, working on Chinook's. This was his advise to me. " If you get on an Army helicopter and it is not leaking hydraulic fluid, GET OFF because this means that it is out of fluid" . And there goes the thread! You just triggered my old fart army story gene. This is a true story, and was reenacted as often as possible. There was a group of ROTC cadets who got thier first ride in a helicopter. It was a Chinook. At about 3000 feet, the crew chief had an idea. It based on established military doctrine that mandates properly scaring the absolute crap out of new recruits. Double for those who you may have to salute later in your career. He and the pilots have ICS, so they can speak privately, whereas the passengers hear nothing though their hearing protection. So at 150 knots and 3000 feet, the pilot drops the collective and 50,000 pounds of helicopter is instantly converted to greased refrigerator that falls at 4000 feet per minute. The crew chief jumps up and runs over to a 50 gallon drum strapped in the hold with a hand pump in it. The Chinnok leaks so bad that this was what "military intelligence" folks came up with for long endurance flights. The crew chief pumps the handle as fast as he can while the pilot begins to level the aircraft out and begin to climb back to altitude. After a couple more times of this little show, with not one cadet being able to hear what's happening, but all of them either vomited or wet thier pants or both- the pilot drops the collective again. The crew chief dutifully jumps up and starts to the pump, then stops and gestures something akin to "oh, screw it", and returns to his seat. I wish we had video of 30 college kids fighting over who got to pump that handle, because ALL of them ran torwards it while the crew chief and pilots laughed themselves out of breath. If you ever fly on one, make sure the crew thinks you've done it before. The ride will be much less frightening! Edited February 18, 2022 by kpinnc 2 Share this post Link to post Share on other sites
Achto 31,520 #245 Posted February 18, 2022 @kpinnc my sides are hurting. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #246 Posted February 18, 2022 When my dad was in the Navy (69-73) he was stationed at a Chopper Training field as an Avionics specialist and one of his tasks was to inspect and sign out repaired aircraft, going over a very lengthy checklist, making sure every nut was torqued and wired...etc. His CO comes in with some Navy buddies and wants to take them on a scenic training mission around the county...but, all the in-service choppers were signed out, nothing on the flight line but 2 choppers that just got repaired and were waiting on inspection. Dad wouldn't sign one out..obviously, CO demanded it..dad wouldn't...CO grabbed the clip board, signed his name, told my dad "when i get back you're going in the brig for insubordination and im busting you down". 3 people witnessed this. CO checked the fuel, untied the blades, quick pre-flight and took off. Dad ran across to the tower and told the person in charge the chopper was not cleared...but they were already gone. It made it about 8 miles, they heard the mayday call in the tower, noise and vibration then it went down. Investigation showed the Jesus nut had not been wired and it backed off..whole main rotor came off. Dad was put on trial but the witnesses and evidence cleared him thankfully. 2 Share this post Link to post Share on other sites
RED-Z06 2,718 #247 Posted February 18, 2022 Dang my story was kind of a bummer🙁 1 Share this post Link to post Share on other sites
kpinnc 17,804 #248 Posted February 18, 2022 13 minutes ago, RED-Z06 said: Dang my story was kind of a bummer🙁 Nope. That's the stuff that safety breifings are made from. Such things happening were what we referred to as "natural selection", where all the stupid ones get killed. Your dad- he did his job. While the loss of life is sad always, he can be proud for standing his ground with honor. Had he acted any way otherwise, he would have been blamed. The way officers are coddled and protected in the military is mind boggling. Rank doesn't make you right, and I say that as a former officer myself. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #249 Posted February 18, 2022 I live in a Navy Town...in 36 years I've never met a Master Chief or higher that has ever been wrong...not even once. My Uncle was a MC...he could stand there, completely wrong, staring at solid evidence he was wrong, and flip it so thats what he was saying all along... 1 Share this post Link to post Share on other sites
TJ5208 1,841 #250 Posted February 18, 2022 Okay guys just to get a little bit back on topic here I think I may have found my problem I think the tractor was too much on the incline it was too low on fuel I'm not positive on that yet that's why I'm getting ready to try now with some blocks so I'm just going to see what kind of incline and see if it was actually getting fuel because the fuel filter is empty so I feel on it just didn't have enough fuel in it so that's what I'm going to try wish me luck 2 Share this post Link to post Share on other sites
