Jeff-C175 7,206 #51 Posted February 6, 2022 5 minutes ago, Snoopy11 said: MASSIVE Yeah, but as long as it's not clogged up, once the filter fills with fuel, the fuel should just flow through. It might take a little longer to get the filter filled the first time when newly installed, but after that should be no different. 3 1 Share this post Link to post Share on other sites
Kenneth R Cluley 589 #52 Posted February 6, 2022 Wwhatever you do concerning fuel, do it outside! And be safe! 4 Share this post Link to post Share on other sites
RED-Z06 2,567 #53 Posted February 6, 2022 This is a kohler filter i cut open, just a normal pleated filter inside, this one went 450hrs commercially and while filthy..still mowed and ran fine. 2 Share this post Link to post Share on other sites
Jeff-C175 7,206 #54 Posted February 6, 2022 1 minute ago, RED-Z06 said: kohler filter Actually, I would expect that a larger filter would have more surface area on the filter media, and more filter area would mean that much less restriction in the filter, and a longer life before totally clogged. 3 Share this post Link to post Share on other sites
Jeff-C175 7,206 #55 Posted February 6, 2022 There ARE different micron measurements of the filters. If they are too fine a media they may not be appropriate for gravity fed systems. But we're talking pumped applications, so that's just a point of information for the pedantic persons among us. 2 Share this post Link to post Share on other sites
RED-Z06 2,567 #56 Posted February 6, 2022 1 minute ago, Jeff-C175 said: Actually, I would expect that a larger filter would have more surface area on the filter media, and more filter area would mean that much less restriction in the filter, and a longer life before totally clogged. I haven't really ever seen a filter that didnt free flow fuel, but some auto filters have an internal check valve and dont flow both directions. 2 1 Share this post Link to post Share on other sites
lynnmor 7,813 #57 Posted February 6, 2022 You need to quit obsessing over the fuel filter, that ain't the problem. Like Ed said, when replacing a fuel filter in old, rotten, ethanol wasted fuel hose, expect some debris to be knocked loose. I expect the issue is in the carburetor. He changed the spark plugs but we didn't see the number on those Champions. 7 Share this post Link to post Share on other sites
Jeff-C175 7,206 #58 Posted February 6, 2022 (edited) 1 hour ago, RED-Z06 said: start putting old parts back on one at a time... plugs No, he definitely doesn't want to put the old plugs back in. One was a champion with broken porcelain, but it did have the tapered seat which I believe is correct for the Onan. The other one was a gasketed typed and completely wrong plug for his engine. Edited February 6, 2022 by Jeff-C175 2 Share this post Link to post Share on other sites
TJ5208 1,841 #59 Posted February 7, 2022 2 hours ago, Snoopy11 said: By the way, I can't guarantee that the fuel filter is the issue... (although I'd bet money that this is the culprit)... it might not be. Definitely sounds like something fuel related though. Tests you could do... Bypass the fuel filter altogether temporarily. Use a dummy fuel tank and gravity feed fuel to the engine. Spray carb cleaner into the intake to see if that makes the engine run better... Take the fuel line off and verify that the fuel pump is pumping properly. Don Im going to put the stock fuel filter on it and see what happens. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #60 Posted February 7, 2022 @roadapples Where do you buy the clear blue fuel line ? 1 Share this post Link to post Share on other sites
roadapples 6,983 #61 Posted February 7, 2022 1 minute ago, elcamino/wheelhorse said: @roadapples Where do you buy the clear blue fuel line ? I got 25' off of ebay. But I think A to Z has it... 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #62 Posted February 7, 2022 Thanks 1 Share this post Link to post Share on other sites
TJ5208 1,841 #63 Posted February 7, 2022 33 minutes ago, Jeff-C175 said: No, he definitely doesn't want to put the old plugs back in. One was a champion with broken porcelain, but it did have the tapered seat which I believe is correct for the Onan. The other one was a gasketed typed and completely wrong plug for his engine. I put RS14YC new spark plugs back in it. Share this post Link to post Share on other sites
Jeff-C175 7,206 #64 Posted February 7, 2022 3 minutes ago, TJ Salyers said: RS14YC Is that the correct heat range? Not sure but I think that engine should have a little hotter plug? RS17 ? Anyway, it wouldn't cause the issue you're having now, so don't worry about it for now. 1 Share this post Link to post Share on other sites
Horse Newbie 7,395 #65 Posted February 7, 2022 (edited) While a lot of the subjects approached above on this have their merit, and could cause problems, what I suggest is replacing the fuel line, fuel filter more in line with what is actually needed, although the one you have may very well work, flush and clean gas tank, make sure the pet cock has the screen in the tank, or just get a new pet cock. See if it runs okay with the fuel cap off… the cap may not be venting causing a vacuum build up in the fuel line. After you do these things, turn the engine over with the fuel line run to a container so that you may be sure you are getting sufficient flow to the carb. On any machine that I do not know the history of, I would make sure my fuel and the delivery of that fuel through a clean fuel system was addressed first. With that, a good spark and and new plugs, my next step would be clean the carb. Edited February 7, 2022 by Horse Newbie 1 2 Share this post Link to post Share on other sites
TJ5208 1,841 #66 Posted February 7, 2022 (edited) Here's the fuel filter. picture before was because the filter was empty I hadn't ran it yet. Edited February 7, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
lynnmor 7,813 #67 Posted February 7, 2022 10 minutes ago, Jeff-C175 said: Is that the correct heat range? Not sure but I think that engine should have a little hotter plug? RS17 ? Anyway, it wouldn't cause the issue you're having now, so don't worry about it for now. The old number is RS14YC, for newer engines it is RS17YX, either one is correct but the newer one has the small center electrode and works a bit better. 2 1 Share this post Link to post Share on other sites
RED-Z06 2,567 #68 Posted February 7, 2022 RS17YX is the correct plug, Champion 909 Delco R44LTS NGK TR5 2 Share this post Link to post Share on other sites
Snoopy11 5,718 #69 Posted February 7, 2022 45 minutes ago, TJ Salyers said: Here's the fuel filter. picture before was because the filter was empty I hadn't ran it yet. Well, that fuel line is pretty crusty there buddy... you might have gotten some in the carb... @Jeff-C175 and Red are correct. The fuel filter I was using before has a check valve. I went out and checked (somehow I still have it). It wasn't the size or the filtering medium... it was the internals that were keeping it from flowing. I put it on... the first way... it didn't run... then I switched directions... and my machine ran great. It was the internal valving. I always thought it was the size, filtering medium, restriction... etc... but I was wrong. It does take a LONG time after putting it in correctly to get fuel... over 45 seconds of cranking... but it does work. Don 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,206 #70 Posted February 7, 2022 32 minutes ago, Snoopy11 said: 45 seconds of cranking. Which is best done in stages and allowing the starter to cool between stages, OR getting on your knees and 'servicing' the fuel system to prime the lines and filter. 2 2 Share this post Link to post Share on other sites
RED-Z06 2,567 #71 Posted February 7, 2022 29 minutes ago, Jeff-C175 said: Which is best done in stages and allowing the starter to cool between stages, OR getting on your knees and 'servicing' the fuel system to prime the lines and filter. Nah you make that starter earn its keep🤣 Onans i hand choke when they run dry, usually fills the bowl in 3 or 4 seconds, had a few that refused to self prime from dry. 4 Share this post Link to post Share on other sites
wallfish 18,085 #72 Posted February 7, 2022 11 hours ago, lynnmor said: You need to quit obsessing over the fuel filter, that ain't the problem. Like Ed said, when replacing a fuel filter in old, rotten, ethanol wasted fuel hose, expect some debris to be knocked loose. I expect the issue is in the carburetor. He changed the spark plugs but we didn't see the number on those Champions. Except it's not a bad idea to move that filter and locate it before the fuel pump. Running all that crap through the pump can effect the performance of the check valves in the pump. Not a big deal but if the lines are being replaced, might as well. 9 hours ago, Snoopy11 said: The fuel filter I was using before has a check valve. I went out and checked (somehow I still have it) Can you please post a pic and info on that filter? That would be a nice feature to have for the tractors with the tank under the seat. Kill 2 birds with one stone 3 Share this post Link to post Share on other sites
Snoopy11 5,718 #73 Posted February 7, 2022 5 hours ago, wallfish said: Can you please post a pic and info on that filter? That would be a nice feature to have for the tractors with the tank under the seat. Kill 2 birds with one stone Pardon the green... Napa 3032. I noticed on newer filters (mine is probably 5-6 years old) there is an arrow that tells you which way the flow goes... mine... for some odd reason... has no arrow... Obviously... no arrow means... no peace from... I don't like the "metal" as... I can't see the fuel going through... BUT... it works... Don 1 Share this post Link to post Share on other sites
JCM 10,190 #74 Posted February 7, 2022 15 hours ago, Jeff-C175 said: OR getting on your knees and 'servicing' the fuel system to prime the lines and filter. 1 1 3 Share this post Link to post Share on other sites
roadapples 6,983 #75 Posted February 7, 2022 1 hour ago, JCM said: May be funny, but you do what you gotta do. Had to do that a lot before I went to an electric pump. Which was after I changed to clear line and could see what was going on.... 3 Share this post Link to post Share on other sites
