stegs
Normal snowblower operation?
stegs
Hey guys/gals
quick question
I have a newer tall chute "toro" brand snowblower that i traded for from a member here
The snowblower works incredible, throws snow 20' easily. It has been a real life saver lately here in michigan with all the snow
Anyway, I have it mounted to my 417-A, but i noticed if i get into some really heavy or deep stuff the blower slows way down and almost stops
Usually its my fault, just going to fast, But i was wondering. Is is a sign that i need to replace the belt on the blower? Maybe its just wet? slipping?
It works fantastic 99.9% of the time, but every once in a while it will almost stop spinning.
Just curious, should i replace the belt, or you guys think it just gets wet and slips on the pulleys when the load is too much?
Pullstart
When it stops, do you see the belt stop too?  Also, are you sure it’s in the larger diameter of the two PTO grooves?
stegs
i guess i never really looked if the belts slows down. Usually at that point im turned around and backing up
and yes, i think im using the bigger of the pulleys,.
peter lena
@stegs  , think you are going too fast , should be taking advantage of the gearing  set up .  make sure that related linkages are lubricated and free and easy in their function . pete
lynnmor
I think that your PTO is slipping, they need to be adjusted up firmly for a snowblower.
stegs
oh never thought of that. Is there a way to test it?
lynnmor
Not really, you should feel a firm push as you engage.
pfrederi
Manual shows belt in the outer/smaller pulley of the PTO
pfrederi
Put a paint mark on the PTO cone.  When blowers stops does paint mark slow/stop??
oldlineman
With snow blowing around I would not think it would be uncommon for the PTO to get wet and slip even if it seems to work ok in the summer mowing. Probable just needs one or so turns on the adjustment rod.
