stegs 327 #1 Posted February 3, 2022 Hey guys/gals quick question I have a newer tall chute "toro" brand snowblower that i traded for from a member here The snowblower works incredible, throws snow 20' easily. It has been a real life saver lately here in michigan with all the snow Anyway, I have it mounted to my 417-A, but i noticed if i get into some really heavy or deep stuff the blower slows way down and almost stops Usually its my fault, just going to fast, But i was wondering. Is is a sign that i need to replace the belt on the blower? Maybe its just wet? slipping? It works fantastic 99.9% of the time, but every once in a while it will almost stop spinning. Just curious, should i replace the belt, or you guys think it just gets wet and slips on the pulleys when the load is too much? Share this post Link to post Share on other sites
Pullstart 71,098 #2 Posted February 3, 2022 When it stops, do you see the belt stop too? Also, are you sure it’s in the larger diameter of the two PTO grooves? Share this post Link to post Share on other sites
stegs 327 #3 Posted February 3, 2022 7 minutes ago, Pullstart said: When it stops, do you see the belt stop too? Also, are you sure it’s in the larger diameter of the two PTO grooves? i guess i never really looked if the belts slows down. Usually at that point im turned around and backing up and yes, i think im using the bigger of the pulleys,. 1 Share this post Link to post Share on other sites
peter lena 10,014 #4 Posted February 3, 2022 @stegs , think you are going too fast , should be taking advantage of the gearing set up . make sure that related linkages are lubricated and free and easy in their function . pete Share this post Link to post Share on other sites
lynnmor 9,010 #5 Posted February 3, 2022 I think that your PTO is slipping, they need to be adjusted up firmly for a snowblower. 3 Share this post Link to post Share on other sites
stegs 327 #6 Posted February 3, 2022 11 minutes ago, lynnmor said: I think that your PTO is slipping, they need to be adjusted up firmly for a snowblower. oh never thought of that. Is there a way to test it? Share this post Link to post Share on other sites
lynnmor 9,010 #7 Posted February 3, 2022 3 minutes ago, stegs said: oh never thought of that. Is there a way to test it? Not really, you should feel a firm push as you engage. Share this post Link to post Share on other sites
pfrederi 21,046 #8 Posted February 3, 2022 1 hour ago, Pullstart said: When it stops, do you see the belt stop too? Also, are you sure it’s in the larger diameter of the two PTO grooves? Manual shows belt in the outer/smaller pulley of the PTO 1 1 Share this post Link to post Share on other sites
pfrederi 21,046 #9 Posted February 3, 2022 Just now, lynnmor said: Not really, you should feel a firm push as you engage. Put a paint mark on the PTO cone. When blowers stops does paint mark slow/stop?? 3 Share this post Link to post Share on other sites
oldlineman 1,800 #10 Posted February 3, 2022 With snow blowing around I would not think it would be uncommon for the PTO to get wet and slip even if it seems to work ok in the summer mowing. Probable just needs one or so turns on the adjustment rod. Share this post Link to post Share on other sites
