Larry Chamberlain 29 #1 Posted February 3, 2022 Im having a really hard time re winding this thing keeps bird nesting on me works fine for like two cranks each way and goes to hell after that lol Model number is 45248 Thanks in advance Share this post Link to post Share on other sites
Jeff-C175 7,211 #2 Posted February 3, 2022 (edited) 48 minutes ago, Larry Chamberlain said: Model number is 45248 Hi Larry, were you able to locate the manual for your blower in the 'manuals' section? I don't see any manuals that have that model number on them. Can you post some pictures of your blower? https://www.wheelhorseforum.com/files/category/28-snow-blowers/ What size cable are you using? Edited February 3, 2022 by Jeff-C175 Share this post Link to post Share on other sites
Ed Kennell 46,981 #3 Posted February 3, 2022 I have used 0.105" trimmer string with some success. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #4 Posted February 3, 2022 Model number is 06-42ST05 This is a later manual but describes the cable installation. Share this post Link to post Share on other sites
lynnmor 9,010 #5 Posted February 3, 2022 5 hours ago, Larry Chamberlain said: this thing keeps bird nesting on me Perhaps you bought the rather course cable, you need cable with a lot of fine strands so that it is very flexible. 2 Share this post Link to post Share on other sites
Blackhood Bill 728 #6 Posted February 3, 2022 9 hours ago, Larry Chamberlain said: Im having a really hard time re winding this thing keeps bird nesting on me works fine for like two cranks each way and goes to hell after that lol Model number is 45248 Thanks in advance Larry, my cable broke last year. I had the same thing happen also, after several attempts. After reading the how to replace instructions several times I believe I was wrapping the cable a half wrap to much. After a half wrap less the cable stays pretty much in place and I can turn my chute both directions and not half to stop and fix the “birds nest”. Share this post Link to post Share on other sites
Larry Chamberlain 29 #7 Posted February 3, 2022 The cable i got seems to kink realy easy im gonna try it again and make sure its super tight wraps see if that helps do you guys have a link for the fine braded cable that dosnt kink Share this post Link to post Share on other sites
Blackhood Bill 728 #8 Posted February 3, 2022 (edited) @Larry Chamberlain, Larry I just bought clothes line cable that is vinyl coated at Menards Edited February 3, 2022 by Blackhood Bill Share this post Link to post Share on other sites
peter lena 10,013 #9 Posted February 3, 2022 @Larry Chamberlain , when working with wire cable , you cannot fight it into place , thats what your " birds nest comment " tells me , as you wind it on let it go where it wants too . typically have aerosol lubricated its initial lay out relieving and smoothing out its function . once its in place , try to relieve its binding areas , while still secured . that way you can stop the nest and still have it in place and control . had your problem myself , till I did it this way , pete Share this post Link to post Share on other sites
pfrederi 21,046 #10 Posted February 3, 2022 You want something like this. Key is 7 x 19.. home center stuff is usually 7 x7 and stiff... Share this post Link to post Share on other sites
