TJ5208 1,841 #176 Posted February 5, 2022 5 hours ago, 8ntruck said: When you change pulleys to increase the speed of the tractor, you are trading torque (pulling power) for speed. Increasing the input pulley speed on the transmission by a given percentage will reduce the torque input to the transmission by the same percentage. I think ill leave it stock. Just want more power who dont. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #177 Posted February 5, 2022 Got the parts just have to put them on. 1 1 Share this post Link to post Share on other sites
TJ5208 1,841 #178 Posted February 6, 2022 (edited) Would you guys consider these tires wore out. would you guys still stick fluid in them or not. Couldn't push any snow with ice underneath it today it would push a tiny bit then start spinning. any recommendations I don't really want to stick outside weights on it maybe inner wheel weights jut like the tractor look. I'm planning on filling all four tires. Edited February 6, 2022 by TJ Salyers 2 Share this post Link to post Share on other sites
Howie 900 #179 Posted February 6, 2022 Not going to push much without at least chains on there. 4 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #180 Posted February 6, 2022 (edited) 15 minutes ago, Howie said: Not going to push much without at least chains on there. @TJ Salyers Those are turf tires TJ, you need weight (whether filled tires or external weights) and chains (preferably 2 link) to get any grip at all. For turf use, no, they aren't particularly worn out. They were never intended for snow. Edited February 6, 2022 by Jeff-C175 3 Share this post Link to post Share on other sites
TJ5208 1,841 #181 Posted February 6, 2022 (edited) Just so thin tread. Edited February 25, 2022 by TJ Salyers 2 Share this post Link to post Share on other sites
c-series don 10,693 #182 Posted February 6, 2022 @TJ Salyers Like others have said weight and two link chains are the key. As a kid I weighed about 120 lbs and I had (have) a Work Horse GT-1800 with chains and no extra weight and I could move mountains of snow. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #183 Posted February 25, 2022 So what tires would you guys recommend me getting for DA BEAST. 1 Share this post Link to post Share on other sites
rmaynard 16,650 #184 Posted February 25, 2022 A lot depends on the look you are going for, the application you are going to using the tractor for, and how much money you have to spend. I personally like to use whatever tire Wheel Horse decided was right when the machine came off the assembly line. For that reason, I am a fan of Carlisle Turf Savers. 5 Share this post Link to post Share on other sites
TJ5208 1,841 #185 Posted February 25, 2022 I know I will be using it for garden plowing. I will also will be Plowing snow gravel dirt And pulling dead weight and pulling heavy loads. 1 Share this post Link to post Share on other sites
rmaynard 16,650 #186 Posted February 25, 2022 This is just my opinion, and I know this isn't going to help unless you have the budget for more than one set of tires, but AG's and tri-ribs for dirt plowing, turf's with weights and chains for snow plowing and dirt pushing. 3 Share this post Link to post Share on other sites
TJ5208 1,841 #187 Posted February 25, 2022 So what brand of tri ribs would you recommend me to get. Share this post Link to post Share on other sites
Sparky-(Admin) 23,903 #188 Posted February 25, 2022 13 hours ago, TJ Salyers said: So what tires would you guys recommend me getting for DA BEAST. How many times are you going to ask the same question in multiple threads? Bob @rmaynard had the best idea about keeping two sets of tires/wheels on hand for it. But since you probably only have one set of rims, here’s my opinion… Support an American company and buy the Carlisle Ags. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #189 Posted February 25, 2022 1 minute ago, Sparky said: How many times are you going to ask the same question in multiple threads? Bob @rmaynard had the best idea about keeping two sets of tires/wheels on hand for it. But since you probably only have one set of rims, here’s my opinion… Support an American company and buy the Carlisle Ags. I apologize. I was asking about the front tires. Share this post Link to post Share on other sites
Sparky-(Admin) 23,903 #190 Posted February 26, 2022 6 hours ago, TJ Salyers said: I apologize. I was asking about the front tires. I don’t own any tri-ribs and these guys will correct me if I’m wrong, but I think they mount up and look better on narrower front rims. Your 520 has wide fronts 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #191 Posted February 26, 2022 I put straight ribs on my wide Work Horse fronts… 1 3 Share this post Link to post Share on other sites
TJ5208 1,841 #192 Posted March 12, 2022 How long of a cable do i need for the rear lift? Share this post Link to post Share on other sites
Jeff-C175 7,207 #193 Posted March 12, 2022 Not to be a wise-a55, but to be a wise-a55; Share this post Link to post Share on other sites
Horse Newbie 7,398 #194 Posted March 12, 2022 On 2/25/2022 at 7:46 PM, Sparky said: I don’t own any tri-ribs and these guys will correct me if I’m wrong, but I think they mount up and look better on narrower front rims. Your 520 has wide fronts These will have to do… On 2/25/2022 at 8:00 PM, Horse Newbie said: I put straight ribs on my wide Work Horse fronts… 1 Share this post Link to post Share on other sites
TJ5208 1,841 #195 Posted March 13, 2022 (edited) Did these tires change? I was about to order me the 23 8 but the 23 10 looks better. Edited March 13, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Achto 30,045 #196 Posted March 13, 2022 I'd go with the 10.50's 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #197 Posted March 13, 2022 38 minutes ago, TJ Salyers said: Did these tires change? I was about to order me the 23 8 but the 23 10 looks better. Looks like the pics are mixed up, but it could just be me… looks like by the pics the 23x10.50 is narrower than the 23x8.50… 1 Share this post Link to post Share on other sites
TJ5208 1,841 #198 Posted March 14, 2022 (edited) Well now I'm stuck the fronts decided it would be fun to start leaking so what tires should I get? Edited March 14, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #199 Posted March 14, 2022 (edited) 1 minute ago, TJ Salyers said: Well now I'm stuck the fronts decided it would be fun to start leaking so what tires should I get? Where are the fronts leaking ? … sidewalls, valve stem, bead, hole in tread area ? Edited March 14, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
TJ5208 1,841 #200 Posted March 14, 2022 (edited) @Horse NewbieThey have tubes I tried the ole soap trick nothing. The tractor just got really hard to steer so I checked the air pressure nothing. They don't flatting out but want some new tires. But the tires are very cracked. Edited March 14, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
