briankd 833 #1 Posted January 30, 2022 was looking at this wiring and the P.o bypassed the pto switch . the seat switch and clutch interlock switch still hooked up . i see they have a inline diode installed any one know if W H ever done this looking at the wiring schematic on here i don't see any diodes . i should trace this down to see where and what it goes too . bought this from a old WH dealer and he installed a new rectifier before he sold it to me cause he says it wasn't charging. i am going to redo all this cobbled up wiring i found 2 inline fuses on the same wire one should be sufficient . Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,842 #2 Posted January 31, 2022 You will sometimes see a diode in the magneto ignition wire as a safety to protect the ignition from a 12 volt power source. The regulator DC+ output can be reduced by adding diodes. More common on the 3 amp unregulated charging systems but not original to the tractor. 1 Share this post Link to post Share on other sites
peter lena 9,555 #3 Posted January 31, 2022 @briankd , see the opportunity , hiding in plane site ? battery ground cable ? from its bolt down ground stop , add a 4 ga cable to corner of engine to frame , next to clutch pedal area ,use serrated washer and a bolt on electrical lug for easy added ground access. from that lug access , add 12 ga wire to rectifier bolts mounting points , then from there to your headlight grounding , add dielectric grease as you go to each bolt , connection point , you do not have to do this , if you think its crazy , but it works on my 3 horses . only a suggestion , while you have the opportunity . pete 1 Share this post Link to post Share on other sites
briankd 833 #4 Posted February 7, 2022 worked on this today and rewired it it had the seat switch along with the brake interlock switch still wired in and done away with them last 2 safety switches . some people on here would say i shouldn't done that but i want it to start i don't want issues latter on with theses safety switches . i am the only one using it if i had youngins operating it it would be different . just have a dumb question here on this seat switch . says operator in seat to power the accessories . that means the wire from seat goes to A on ignition switch ( hot wire ) then it would power the wire coming out ignition switch powering the wire to the headlight switch ? if so could run fused wire off positive on battery to the A term on ignition switch . don't make sense to me why you would have to be sitting in seat for headlights to work unless i'm missing something here lol Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,842 #5 Posted February 7, 2022 12 hours ago, briankd said: Don't make sense to me why you would have to be sitting in seat for headlights to work unless i'm missing something here lol The headlamps and ignition will work if the pto is OFF and no operator in the seat. The headlamps and ignition will not work if the pto is ON and no operator in the seat. The primary goal of this configuration is to control the ignition. The headlamps are secondary. If the engine is not running you don't need headlamps. 1 1 Share this post Link to post Share on other sites
WHX?? 53,302 #6 Posted February 7, 2022 12 hours ago, briankd said: . some people on here would say i shouldn't done that Not me but yes I am the only operator. Share this post Link to post Share on other sites
briankd 833 #7 Posted February 8, 2022 On 1/31/2022 at 8:45 AM, peter lena said: @briankd , see the opportunity , hiding in plane site ? battery ground cable ? from its bolt down ground stop , add a 4 ga cable to corner of engine to frame , next to clutch pedal area ,use serrated washer and a bolt on electrical lug for easy added ground access. from that lug access , add 12 ga wire to rectifier bolts mounting points , then from there to your headlight grounding , add dielectric grease as you go to each bolt , connection point , you do not have to do this , if you think its crazy , but it works on my 3 horses . only a suggestion , while you have the opportunity . pete done just as you said i had issue with my c120 when restored it had hell of a time to get a good ground on it ran wire and grounded everything . gets aggravating get a job like this done and stuff don't work due to bad grounds 1 Share this post Link to post Share on other sites
peter lena 9,555 #8 Posted February 8, 2022 @briankd brian , glad you did that , found that to be the best electrical aid for many issues , makes my stuff solidly start , now that I have you on the road of change , look up EVIL ENERGY for a fuel check valve in 5/16" size. , if you get one , mount it VERTICALLY on fuel pump discharge to carb . a perfect spot for it , like it was made for it. that check valve will hold a carb fuel charge, and stop fuel back flow , makes them start instantly . use the small dark green squeeze clamps on the fuel hose , and use flat jaw lineman's plyers to squeeze the clamps in place. have this same set up on my 3 horses , lots of hours , it works , keep it going , pete Share this post Link to post Share on other sites
briankd 833 #9 Posted February 8, 2022 1 minute ago, peter lena said: @briankd brian , glad you did that , found that to be the best electrical aid for many issues , makes my stuff solidly start , now that I have you on the road of change , look up EVIL ENERGY for a fuel check valve in 5/16" size. , if you get one , mount it VERTICALLY on fuel pump discharge to carb . a perfect spot for it , like it was made for it. that check valve will hold a carb fuel charge, and stop fuel back flow , makes them start instantly . use the small dark green squeeze clamps on the fuel hose , and use flat jaw lineman's plyers to squeeze the clamps in place. have this same set up on my 3 horses , lots of hours , it works , keep it going , pete i will check that out . seen some post on here about bleed back and some guys put the primer bulb inline like what you use on an outboard . and i was wondering about some kind of check valve . all my other tractors are tank under hood gravity feed to pump Share this post Link to post Share on other sites
briankd 833 #10 Posted February 8, 2022 7 minutes ago, peter lena said: EVIL ENERGY for a fuel check found them they sell them on amazon 10 bucks for 2 i am amazon member will get them ordered up THANKS !!!!! Share this post Link to post Share on other sites
peter lena 9,555 #11 Posted February 8, 2022 @briankd this is it ,https://www.amazon.com/EVIL-ENERGY-Return-Petrol-Aluminium/dp/B07ZB42CGT if your pump is worn , the drain back increases , but if your pump is ok , this check valve will hold the fuel in place , pete Share this post Link to post Share on other sites
peter lena 9,555 #12 Posted February 8, 2022 @briankd glad to help out , what ever I put out for information , I have that in use on my horses , it works , pete Share this post Link to post Share on other sites
briankd 833 #13 Posted February 8, 2022 2 minutes ago, peter lena said: @briankd this is it ,https://www.amazon.com/EVIL-ENERGY-Return-Petrol-Aluminium/dp/B07ZB42CGT if your pump is worn , the drain back increases , but if your pump is ok , this check valve will hold the fuel in place , pete yep im am ordering them as we speak i will put the second one on my c120 seems it sits for awhile it starts hard like the fuel drains back on it Share this post Link to post Share on other sites
peter lena 9,555 #14 Posted February 8, 2022 @briankd you are going to love it , let me know , install in the VERTICAL fuel line , between fuel pump and carb , arrow up on valve . pete 1 Share this post Link to post Share on other sites
briankd 833 #15 Posted February 8, 2022 appreciate info on the check valve ordered and will have them in 3 days Share this post Link to post Share on other sites
peter lena 9,555 #16 Posted February 8, 2022 @briankd morning, use a small amount of super lube or dielectric grease on the starting starting ends of the check valve , makes easier hose slide , also put on spring clamps first , so you can slide them over the hose end area. . https://www.grainger.com/product/44N742?ef_id=Cj0KCQiAxoiQBhCRARIsAPsvo-- shop around for pricing , use this on my throttle / choke cables , make it drip out the end , ensuring function and coverage . this will make cables much smoother, be in touch , pete Share this post Link to post Share on other sites
