ti-jean 45 #1 Posted January 18, 2022 (edited) Battery 12.75 volt poor spark at spark plugs wen the engine finish to run , low charging at idel normal or not ? sometime backfire befor start to muffler or by the carb ,cylinder compression on both 63fp head olso sometime spark and somtime no spark but always poor I suspect the ignition modul thank Edited January 18, 2022 by ti-jean Share this post Link to post Share on other sites
stevasaurus 23,617 #2 Posted January 18, 2022 Any idea what horse we are talking about?? Low charging at idle is normal with a starter/generator. Looking for bad grounds is the 1st thing to do. 1 1 Share this post Link to post Share on other sites
ti-jean 45 #3 Posted January 18, 2022 30 minutes ago, stevasaurus said: Any idea what horse we are talking about?? Low charging at idle is normal with a starter/generator. Looking for bad grounds is the 1st thing to do. Oh sorry the engine is p216g 1 Share this post Link to post Share on other sites
oliver2-44 11,214 #4 Posted January 18, 2022 His past post shows a 2001, 516 H 3 Share this post Link to post Share on other sites
ti-jean 45 #5 Posted January 18, 2022 (edited) 3 minutes ago, oliver2-44 said: His past post shows a 2001, 516 H sorry guys my last is from 8_02 2021 so what is the problem Edited January 18, 2022 by ti-jean 1 Share this post Link to post Share on other sites
lynnmor 8,627 #6 Posted January 18, 2022 Run the engine at half throttle, the voltage should come up to about 14 volts in a minute or so. If you have 63 psi compression, the engine is sick and needs repair. Backfiring might be the result of the sick engine or the carburetor and intake needs serviced. 1 1 Share this post Link to post Share on other sites
ti-jean 45 #7 Posted January 18, 2022 2 minutes ago, lynnmor said: Run the engine at half throttle, the voltage should come up to about 14 volts in a minute or so. If you have 63 psi compression, the engine is sick and needs repair. Backfiring might be the result of the sick engine or the carburetor and intake needs serviced. The compression geage is bad i check whit a good one next carburator it s ok and brend new intake seal on both side sorry for my english speeling thank tomorrow il check my oil pressure cutoff 1 Share this post Link to post Share on other sites
lynnmor 8,627 #8 Posted January 19, 2022 You don’t have an oil pressure cut off. 1 Share this post Link to post Share on other sites
ti-jean 45 #9 Posted January 19, 2022 1 minute ago, lynnmor said: You don’t have an oil pressure cut off. Whyi have a flashing light on dash board 1 Share this post Link to post Share on other sites
lynnmor 8,627 #10 Posted January 19, 2022 The oil pressure switch on the engine turns on that light with no pressure and turns on the hour meter with pressure. It does nothing to the ignition. 1 1 Share this post Link to post Share on other sites
ti-jean 45 #11 Posted January 19, 2022 (edited) I just came from my garage and started but very hard fire came out of the muffler after he start i get no broblem i did a video 5 minute ago but how to show it here and a dont have a hosting place i juste plow a big mount a snow no broblem but to get start it is very hard il try whit a sleg hamer next Edited January 19, 2022 by ti-jean 1 Share this post Link to post Share on other sites
lynnmor 8,627 #12 Posted January 19, 2022 You could become a supporter here or open a YouTube account. My guess is that the carburetor is in need of work. Your sledgehammer comment is not necessary. 2 Share this post Link to post Share on other sites
ti-jean 45 #13 Posted January 19, 2022 2 hours ago, lynnmor said: You could become a supporter here or open a YouTube account. My guess is that the carburetor is in need of work. Your sledgehammer comment is not necessary. Check on FB Redquare you will the video after start run good but likeci said very hard to start so afert towmoro sno storm i will have a check up step by step as Duramax7 show thank 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #14 Posted January 19, 2022 On my 416-H, if the engine is flooded from too much choke or the battery is a bit weak it will tend to slow down or hesitate on the compression strokes and it will backfire...i move the choke to off and throttle to idle...this lowers compression some and it usually fires right up. If its got alot of use, the valve lash may need to be adjusted. 2 1 Share this post Link to post Share on other sites
ti-jean 45 #15 Posted January 19, 2022 3 minutes ago, RED-Z06 said: On my 416-H, if the engine is flooded from too much choke or the battery is a bit weak it will tend to slow down or hesitate on the compression strokes and it will backfire...i move the choke to off and throttle to idle...this lowers compression some and it usually fires right up. If its got alot of use, the valve lash may need to be adjusted. Ya normaly after one hesitation I close the shoke and get start right bac thank's 1 Share this post Link to post Share on other sites
lynnmor 8,627 #16 Posted January 19, 2022 9 hours ago, ti-jean said: Check on FB Redquare you will the video after start run good but likeci said very hard to start so afert towmoro sno storm i will have a check up step by step as Duramax7 show thank Provide a link to the video, I don't frequent Facebook. 2 Share this post Link to post Share on other sites
ti-jean 45 #17 Posted January 19, 2022 2 minutes ago, lynnmor said: Provide a link to the video, I don't frequent Facebook. https://m.facebook.com/story.php?story_fbid=2914623475422122&id=100006234942027 1 Share this post Link to post Share on other sites
lynnmor 8,627 #18 Posted January 19, 2022 1 minute ago, ti-jean said: https://m.facebook.com/story.php?story_fbid=2914623475422122&id=100006234942027 Link doesn't work. Share this post Link to post Share on other sites
ti-jean 45 #19 Posted January 19, 2022 it work for me https://www.facebook.com/100006234942027/posts/2914623475422122/ 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #20 Posted January 19, 2022 It looks like the video is set on private...it needs to be set on public. 2 Share this post Link to post Share on other sites
ti-jean 45 #21 Posted January 19, 2022 (edited) 9 minutes ago, stevasaurus said: It looks like the video is set on private...it needs to be set on public. yes yes i juste change try it and let me know https://www.facebook.com/100006234942027/posts/2914623475422122/ Edited January 19, 2022 by ti-jean 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #22 Posted January 19, 2022 3 hours ago, lynnmor said: Provide a link to the video, I don't frequent Facebook. I don't either... so I can't be of assistance. Don 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #23 Posted January 19, 2022 Sounds like it is hunting just a little, but it could be the snow load doing it. 2 Share this post Link to post Share on other sites
ti-jean 45 #24 Posted January 19, 2022 15 minutes ago, stevasaurus said: Sounds like it is hunting just a little, but it could be the snow load doing it. the problem it's not on load it is at cold start in the garage Thank 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #25 Posted January 19, 2022 @ti-jean Have you tried a gas additive?? Might just be a little carbon build up...maybe running a little rich because of it. Try some Sea Foam gas treatment in the gas tank. Sea Foam is the best there is. Don't mess with anything else. Run it for a while, and try running it a little leaner. Idle down the engine before you shut it down...that could cut down on the back-firing. The engine actually sounds pretty good. No compression problem, I think. 2 Share this post Link to post Share on other sites
