Similar Content
By CS-17
Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
I received it in non working order, I have since done the following repairs: To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter. To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted). This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $1000 or best offer. Please feel free to CALL me for details or any question! THANKS for looking! -
By Kenneth R Cluley
Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim! Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
By Jennifer
Hello everyone! Got a real puzzle here! Husband has visited with some on here by phone, but he is getting really frustrated! Can anyone help us with this tractor! It will be mowing fine, then start dying off and on at different time frames! Temperature out side sometimes seems to play a part but could be coincident. So he has put more and more money in this and not fixed the issue! A list of what he has done thus far!
new Fuel line
new condensor
new points
new carb
new plug wire
new spark plug
Used fuel pump
new coil
new switch
new battery
new head gasket
soaked it with marvel mystry oil
soaked it with sea foam
removed fuel tank cleaned and blew out
cleaned sediment bowl. Brand new one is on its way
changed oil
all 4 brand new belts
By Wheelhorse427
The Kohler K181 on my 855 will only rev to about 2500 RPMs. When I pull the throttle cable out the whole way with the engine running, I can see the governor arm push the throttle back down. I have adjusted the governor by the manual 3 or 4 times, but it made no difference. I'm pretty sure the throttle linkage is hooked up correctly because the throttle will open the whole way when the engine isn't running. Do I need to replace my governor gear? Thanks in advance.
By 69-Raider-10
Happy Easter fellow Horse Junkies! I am not happy with my Raider 10 after I swapped out the Lauson for a K181. Its not so much the difference in power between the 10hp and the 8hp, its the fact that my other 2 tractors are a Bronco 14 and a 416 8 Onan. I hop on the Raider and even though its the most mechanically sound and aesthetically pleasing tractor, it has the least cajones. I have a low hour 14hp Magnum sitting around that I was saving as a backup but I think I want to drop it in the Raider. Anyone make this type of swap before? Anything that makes it not doable or ill advisable? As always I appreciate the input and your time in answering. Happy Easter!
