Raposo 532 #1 Posted January 13, 2022 Hey guys, I bought this magnum 8 used from someone who said “it was on a running and driving tractor” I got it home and mounted it to my 607 build and I can’t get it started for the life of me. I have swapped the carb, fuel pump, pulled the head the the valves seem to be operating fine. It’s shooting exhaust out the carb in attempting to start. So much so that it closes the throttle butterfly here’s a video, what am I missing here, extremely frustrating IMG_4719.MOV Share this post Link to post Share on other sites
Pullstart 71,296 #2 Posted January 13, 2022 Did you use any wiring from the 607? Make sure you have the correct ignition switch ok, the video loaded…. Based on the puff, you’re getting SOME fuel and spark. Try covering the intake completely with your hand and pulling it over. Share this post Link to post Share on other sites
Raposo 532 #3 Posted January 13, 2022 7 minutes ago, Pullstart said: Did you use any wiring from the 607? Make sure you have the correct ignition switch ok, the video loaded…. Based on the puff, you’re getting SOME fuel and spark. Try covering the intake completely with your hand and pulling it over. I’ll try that. Valves are not adjustable on the magnum 8 right? Share this post Link to post Share on other sites
Pullstart 71,296 #4 Posted January 13, 2022 7 minutes ago, Raposo said: I’ll try that. Valves are not adjustable on the magnum 8 right? Well, they are, via grinding the stem… Share this post Link to post Share on other sites
Pullstart 71,296 #5 Posted January 13, 2022 Hand over the carb trick… explained a bit around 5:57 in this video. Share this post Link to post Share on other sites
Raposo 532 #6 Posted January 13, 2022 1 minute ago, Pullstart said: Hand over the carb trick… explained a bit around 5:57 in this video. Did it the hand over the carb and it burbed and soaked my hand in fuel. There was a good amount of fuel, maybe it’s flooding the engine? The spark plug is wet. Maybe I’ll tighten the carb screws? Share this post Link to post Share on other sites
Pullstart 71,296 #7 Posted January 13, 2022 Clean off the plug, leave the carb where it is, roll it over again. Did you verify good blue spark too? Share this post Link to post Share on other sites
Raposo 532 #8 Posted January 13, 2022 38 minutes ago, Pullstart said: Clean off the plug, leave the carb where it is, roll it over again. Did you verify good blue spark too? Just checked and spark appears to be very intermittent. Wondering if that’s the issue. 1 Share this post Link to post Share on other sites
Pullstart 71,296 #9 Posted January 13, 2022 What did you use for wiring and a kill? Share this post Link to post Share on other sites
Raposo 532 #10 Posted January 13, 2022 Assuming the coil is bad? Share this post Link to post Share on other sites
pfrederi 21,175 #11 Posted January 13, 2022 For a secondary test you seem to be in spec. 7900/10850 ohms what is primary?? Should be 1.0/3.0 ohms Share this post Link to post Share on other sites
RED-Z06 2,720 #12 Posted January 13, 2022 Try a new plug 2 Share this post Link to post Share on other sites
Raposo 532 #13 Posted January 13, 2022 So I cleaned up the coil sanded all the rust off and re set the gap and installed a new plug and she finally fired IMG_4729.MOV 2 3 Share this post Link to post Share on other sites
pfrederi 21,175 #14 Posted January 14, 2022 Magnum ignitions are pretty hardy unless you fry them... Share this post Link to post Share on other sites
Pullstart 71,296 #15 Posted January 14, 2022 Awesome! Now just a reminder, make sure you get the rest of those tins on Share this post Link to post Share on other sites
