RED-Z06 2,720 #26 Posted January 12, 2022 1 hour ago, Achto said: Common clearance for a cast piston is .001 to .0015 per inch diameter. Hypereutectic pistons are tighter around .0005 per inch diameter. You are just outside the cast piston limits. It would probably be ok but may be noisy. You can get .003 over oem pistons, might be an option. Or maybe go .010 over rings on the stock piston, file end gap for correct gap. Did you put the balance gears back in when you built it the last time? Yes, they still seem fine, but im going to get more intimate with it Share this post Link to post Share on other sites
RED-Z06 2,720 #27 Posted January 14, 2022 2 cans of brake cleaner, 2 cans of carb cleaner, lots of air...you could eat off this engine. Rain tomorrow...but all the parts are in, bottom end and sump are sealed up...heads on, new coil yet to swap, new carb to put on..new pump is already on 1 Share this post Link to post Share on other sites
ebinmaine 80,310 #28 Posted January 14, 2022 14 minutes ago, RED-Z06 said: you could eat off this engine Ah. I do loves me a nice cast iron eating utensil. 1 Share this post Link to post Share on other sites
