RED-Z06 2,573 #1 Posted January 11, 2022 After honing... Just tore my M12 back down after 5hrs of running,developed a rattle, oil on the piston. The skirts are severely worn especially on the thrust side (rear of the block), the rod shows no scoring but its dull which is indicative of abrasive presence. Rings were in spec 5hrs ago but now. .019/.024/.110 top to bottom. The oil was dark and streaks of silver..i ran a magnet through the oil as it drained and got no ferrous debris so its aluminum...rod and piston. Live and learn...ill clean it more thoroughly this time but im thinking what got me was the valve box, i don't recall if i flushed it after honing and some grit could have been in there. Skirt thickness in 3 spots on trailing side..0.085 0.081 0.085. And on the thrust side..0.061 0.054 0.058 5 Share this post Link to post Share on other sites
Snoopy11 5,718 #2 Posted January 11, 2022 Some people may call me crazy... I think that applies... yes... But after grinding on block or anything of that nature, I pressure wash my block, and blow it out with my gas blower... I make sure the block is extremely dry, sitting it out in the sun as well. Just my "educated redneck" method... Don 1 Share this post Link to post Share on other sites
Snoopy11 5,718 #4 Posted January 11, 2022 (edited) 1 minute ago, ebinmaine said: Along with a big, hawkin' ...dawmn it... Don Edited January 11, 2022 by Snoopy11 Share this post Link to post Share on other sites
RED-Z06 2,573 #5 Posted January 11, 2022 I dunked the whole block into hot soapy water in a tub and used various brushes to scrub inside and out, cleaned the bore with a scotch pad and soap then water and rags..until it came out clean, then 150psi air.until dry. 1 Share this post Link to post Share on other sites
ebinmaine 72,671 #6 Posted January 11, 2022 Likely was the smallest little piece of aluminum schmutz that you can imagine. Just sitting in a corner waiting to get rolled around the engine... I can't speak from experience having never done a small engine on my own but I've had carburetors that needed to be cleaned out three or four times before they ran right. Rare. But it happens. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,718 #7 Posted January 11, 2022 1 minute ago, ebinmaine said: Likely was the smallest little piece of aluminum schmutz that you can imagine. Just sitting in a corner waiting to get rolled around the engine... I can't speak from experience having never done a small engine on my own but I've had carburetors that needed to be cleaned out three or four times before they ran right. Rare. But it happens. I had a steel pushrod go down into the oil pan of a briggs v twin. Thing got friggin' obliterated. HOWEVER, no damage to the cam or anything else. Just had to dig pieces out after disassembly. Don't ask me why it happened, but all I know is that it does... and usually destroys the cam... OH, uh, speaking of that, @RED-Z06... any damage to the cam lobes? Don Share this post Link to post Share on other sites
Maxwell-8 4,367 #8 Posted January 11, 2022 1 minute ago, Snoopy11 said: the cam lobes and crank? I am sorry for you. s*ucks having an engine "destroyed" that way 1 Share this post Link to post Share on other sites
Snoopy11 5,718 #9 Posted January 11, 2022 Just now, Maxwell-8 said: and crank? Yeah, crank journal could get scorred... but generally the came lobes are more vulnerable and soft... Don Share this post Link to post Share on other sites
RED-Z06 2,573 #10 Posted January 11, 2022 2 minutes ago, Snoopy11 said: I had a steel pushrod go down into the oil pan of a briggs v twin. Thing got friggin' obliterated. HOWEVER, no damage to the cam or anything else. Just had to dig pieces out after disassembly. Don't ask me why it happened, but all I know is that it does... and usually destroys the cam... OH, uh, speaking of that, @RED-Z06... any damage to the cam lobes? Don Not seeing any other wear, the bore somehow has no notable wear still showing my crosshatch infact. I think if id changed the oil it could have easily run like this 50+ hours but... 1 Share this post Link to post Share on other sites
Snoopy11 5,718 #11 Posted January 11, 2022 Just now, RED-Z06 said: I think if id changed the oil it could have easily run like this 50+ hours but... Maybe... throw some rings in it? Don Share this post Link to post Share on other sites
Snoopy11 5,718 #12 Posted January 11, 2022 32 minutes ago, RED-Z06 said: oil on the piston Smoking through exhaust or coming out of breather? Don Share this post Link to post Share on other sites
RED-Z06 2,573 #13 Posted January 11, 2022 Crank measures 1.4995 Rod measures 1.5005 Not enough to knock...both still in spec but at the outside limits of running spec. Share this post Link to post Share on other sites
RED-Z06 2,573 #14 Posted January 11, 2022 4 minutes ago, Snoopy11 said: Smoking through exhaust or coming out of breather? Don Somehow not really...no breather smoke or excessive vapor, no smoke visible while running but it had used some Share this post Link to post Share on other sites
RED-Z06 2,573 #15 Posted January 11, 2022 9 minutes ago, Snoopy11 said: Maybe... throw some rings in it? Don Ive got new piston, rings, rod...on the way Share this post Link to post Share on other sites
Snoopy11 5,718 #16 Posted January 11, 2022 2 minutes ago, RED-Z06 said: Crank measures 1.4995 1 minute ago, RED-Z06 said: Ive got new piston, rings, rod...on the way Sounds like... maybe a new crank in order. Just a matter of time. Don Share this post Link to post Share on other sites
Achto 29,402 #17 Posted January 11, 2022 I will spend far more time cleaning an engine than I will cleaning an open wound. Instead of soap & water grab a few cans of brake cleaner. Hose it down, dry it off with a blow gun, repeat 3 or 4 times. To clean the bore, put motor oil on a clean rag and wipe the bore. Repeat this using a clean rag each time until the rag comes out just as clean as it was before scrubbing the bore. Yes, it will have oil on it but there should be no black residue. 1 Share this post Link to post Share on other sites
RED-Z06 2,573 #18 Posted January 11, 2022 35 minutes ago, Snoopy11 said: Sounds like... maybe a new crank in order. Just a matter of time. Don Still within new spec..i could buy a new one and it be 1.4995 Share this post Link to post Share on other sites
Achto 29,402 #19 Posted January 11, 2022 3 hours ago, RED-Z06 said: Crank measures 1.4995 Rod measures 1.5005 .001" clearance sound perfect to me. Common clearance is .0008 - .001" per inch diameter of the crank pin. 1 Share this post Link to post Share on other sites
RED-Z06 2,573 #20 Posted January 11, 2022 3 minutes ago, Achto said: .001" clearance sound perfect to me. Common clearance is .0008 - .001" per inch diameter of the crank pin. Yeah that definitely wasnt my noise, there is scuffing on the rod big end though. The piston took a beating Share this post Link to post Share on other sites
Achto 29,402 #21 Posted January 12, 2022 4 hours ago, RED-Z06 said: After honing.. I know that you stated the piston ring end gap but what is your piston to cylinder clearance. Too great of clearance will cause piston slap or chatter. An egg shaped hole will also cause the same thing. Measure the bore in multiple spots, right all of you numbers down and see how strait the cylinder is. Measure the skirt on you new piston and figure out what you clearance is. Share this post Link to post Share on other sites
RED-Z06 2,573 #22 Posted January 12, 2022 1 minute ago, Achto said: I know that you stated the piston ring end gap but what is your piston to cylinder clearance. Too great of clearance will cause piston slap or chatter. An egg shaped hole will also cause the same thing. Measure the bore in multiple spots, right all of you numbers down and see how strait the cylinder is. Measure the skirt on you new piston and figure out what you clearance is. I probably should but, if its larger than spec im not going to have it punched out, just not worth it, im already to the point id have been ahead of the game to just pickup a used local M16 that ran for $200 and just swapped it on. No doubt the bore has some wear from the contamination vs last week, but...it'd be well more than its worth to punch it 10 or 20 over. It would cost 250+ for a local machine shop to bore it..been there with an M10S...700 in machining and parts for a 250 dollar engine. 1 Share this post Link to post Share on other sites
RED-Z06 2,573 #23 Posted January 12, 2022 And they are great engines...no doubt, but when you look at what parts cost...if not for sketchy aftermarket stuff it wouldn't be worth doing. Look at what a coil from stens would run retail vs dealer cost.. Share this post Link to post Share on other sites
RED-Z06 2,573 #24 Posted January 12, 2022 Old piston across the thrust faces on the skirts...3.363" New piston 3.369" That represents the maximum new size and maximum wear specified limit... 6thou wear is probably my noise Share this post Link to post Share on other sites
Achto 29,402 #25 Posted January 12, 2022 (edited) Common clearance for a cast piston is .001 to .0015 per inch diameter. Hypereutectic pistons are tighter around .0005 per inch diameter. You are just outside the cast piston limits. It would probably be ok but may be noisy. You can get .003 over oem pistons, might be an option. Or maybe go .010 over rings on the stock piston, file end gap for correct gap. Did you put the balance gears back in when you built it the last time? Edited January 12, 2022 by Achto Share this post Link to post Share on other sites
