BeninCT 451 #1 Posted December 31, 2021 I’ve been adding rear weight and will also add some weight upfront to help with steering when the snow plow is down but I thought I would ask the group if there was a general agreed-upon best tire to use upfront for steering traction when plowing? After that I wanted to ask if anybody had any experience adding metal studs to their front tires for plowing/steering traction? Share this post Link to post Share on other sites
ebinmaine 79,740 #2 Posted December 31, 2021 I've considered adding studs myself on several different occasions and I've always shied away from it. Reason being is because they are surprisingly easy to accidentally remove from the correct tire and accidentally install upside down in the wrong tire. Best recommendation for front traction in my experience is of course lots and lots of weight, combined with roller chains going the circumference of the tire. I did that on train is 867 and it works quite well giving consideration of the fact that her tractor is much much lighter than mine and so is she lighter than me. Extra WEIGHT as you know is your friend. On my plow tractor I have well oversized tires on the front which are fluid filled. 1 Share this post Link to post Share on other sites
wallfish 20,231 #3 Posted December 31, 2021 X 2 on the #40 roller chain 2 Share this post Link to post Share on other sites
formariz 12,381 #4 Posted December 31, 2021 9 minutes ago, wallfish said: X 2 on the #40 roller chain x3 on that. One needs only to really look at what the roller chain does to understand that nothing else will equal it. 1-extremely small contact point with ground piercing any snow or ice under it therefor making positive contact with ground. 2-extremely hard metal making it able to do the above. 3-ability to have exactly same effect on both wheels equally creating a "like it is on rails" effect. 4-what makes it so effective on #1 at the same time adds the benefit of "lightening" steering due to the minimal contact area. 5-the quickest and most inexpensive solution for the problem. 6-the only REAL solution for the problem 1 Share this post Link to post Share on other sites
rjg854 13,200 #5 Posted December 31, 2021 Couldn't agree more, roller chains make all the difference in the world. Share this post Link to post Share on other sites
pfrederi 20,898 #6 Posted December 31, 2021 Roller chains!!!! Share this post Link to post Share on other sites
ebinmaine 79,740 #7 Posted December 31, 2021 One would almost get the impression that some of us are into roller chains.... 😂 1 Share this post Link to post Share on other sites
varosd 1,185 #8 Posted December 31, 2021 I went with knock off MTD type metal front wheel weights and it made all the difference of course now that we moved from Pennsylvania back to the mountains of North Carolina we have had mild winters of course, we are looking at some dusting/ ice on Sunday night lol Share this post Link to post Share on other sites
Achto 32,119 #9 Posted December 31, 2021 I have these on the front of my C-145 that I use for pushing the snow blade around. They made a word of difference, no weight added and the tractor goes where I point it. https://www.amazon.com/Carlisle-Trac-ATV-Bias-Tire/dp/B001THCJDO Been thinking about adding these to the rear. I've heard very good reviews from people who don't even run chains with these. Say that chains are not needed. https://www.millertire.com/23x8-50r12-carlisle-versa-turf-compact-radial-tractor-tire-6-ply/ 2 Share this post Link to post Share on other sites
ebinmaine 79,740 #10 Posted January 1, 2022 21 minutes ago, Achto said: have these on the front of my C-145 that I use for pushing the snow blade around. They made a word of difference, no weight added and the tractor goes where I point it. https://www.amazon.com/Carlisle-Trac-ATV-Bias-Tire/dp/B001THCJDO I been thinking on ordering a set like that. Really do wish they came in a larger size for 8" wheel. Share this post Link to post Share on other sites
SylvanLakeWH 31,772 #11 Posted January 1, 2022 I run no weights no chains on my C 105 and C 6.5 (predator swap)… Michigan snow slop etc. Three flat concrete drives…two brand new. So I want no marks… Works fine… My question to the front chain guys - do you mark up your concrete / asphalt drives with the roller chain? When I ran chains on back for one year it was noticeable scratching on both asphalt and concrete. I stopped and frankly don’t see the need for my drives… dirt drives I get, paved I’m curious your experiences… Share this post Link to post Share on other sites
Rusty Tinsnips 477 #12 Posted January 1, 2022 2 hours ago, Achto said: I have these on the front of my C-145 that I use for pushing the snow blade around. They made a word of difference, no weight added and the tractor goes where I point it. These worked very good last year. On concrete. chipped stone and dirt. 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #13 Posted January 1, 2022 25 minutes ago, Rusty Tinsnips said: Those are snowblower tires if I am not mistaking? 1 Share this post Link to post Share on other sites
Achto 32,119 #14 Posted January 1, 2022 10 minutes ago, Maxwell-8 said: Those are snowblower tires if I am not mistaking? You are correct. They do make great steer tires as well. Share this post Link to post Share on other sites
Achto 32,119 #15 Posted January 1, 2022 2 hours ago, ebinmaine said: Really do wish they came in a larger size for 8" wheel. The ones that I posted are 16x6.50x8's 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #16 Posted January 1, 2022 27 minutes ago, Achto said: The ones that I posted are 16x6.50x8's Yessir. I have 20 x 8 x 8 on the plow rig. 1 Share this post Link to post Share on other sites
pfrederi 20,898 #17 Posted January 1, 2022 I suppose they are OK on cement/blacktop if it was clear when the snow came but if you have a build up of ice packed snow chains are the best answer 1 Share this post Link to post Share on other sites
Southern_Secret 464 #18 Posted January 1, 2022 Would these roller chain deals work good in light mud? If so how does one make them? Share this post Link to post Share on other sites
wallfish 20,231 #19 Posted January 1, 2022 4 hours ago, Southern_Secret said: Would these roller chain deals work good in light mud? If so how does one make them? For that condition Tri Rib tires are probably your best bet. Maybe doing 2 loops of chain on each tire would help too. I'll get you a pic of chain on a tire when it gets light out 1 Share this post Link to post Share on other sites
pfrederi 20,898 #21 Posted January 1, 2022 4 hours ago, wallfish said: For that condition Tri Rib tires are probably your best bet. Maybe doing 2 loops of chain on each tire would help too. I'll get you a pic of chain on a tire when it gets light out For mud I think the triribs would be better Share this post Link to post Share on other sites
ebinmaine 79,740 #22 Posted January 1, 2022 4 hours ago, wallfish said: For that condition Tri Rib tires are probably your best bet. 2 minutes ago, pfrederi said: For mud I think the triribs would be better Can concur. Trina has 3 tractors with 3 different types of front tires. Our experience: Turfs with roller chains are best for ice/snow. Tri ribs for mud dirt gravel sand. Front AGs work well on non ice conditions but not quite as good as tri ribs. Share this post Link to post Share on other sites
Lee1977 7,710 #23 Posted January 1, 2022 I agree that Tri-Ribs work great in mud dirt gravel and sand, but I avoid mud every where I can. I have the Tri-Ribs on my 312-8 on the rear I have Carlisle All Trails II. We don't get enough snow and ice to need chains. Snow usually only last a max of three days some might linger in shady areas for a week. We never get snow from the west the mountains gets that. We have to have moisture from the south and extremely cold air from the north east to get snow. The most useless tires I have ever had were the Carlisle Turf Savers that came on Wheel Horse Tractors. The only thing that is level around here is my drive way and it goes into my basement. Share this post Link to post Share on other sites
BeninCT 451 #24 Posted January 2, 2022 I am worried that these chains will mark up my new driveway. Do they leave any marks? I suppose as long as you are moving when you turn prob not… Thanks for all the responses. Turf saver tires are terrible in the snow and that is all I really use this thing for so considering those snowblower tires posted with the huge lugs. Thank you, again. 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,772 #25 Posted January 2, 2022 On 1/1/2022 at 12:20 PM, Lee1977 said: The most useless tires I have ever had were the Carlisle Turf Savers 20 minutes ago, BeninCT said: Turf saver tires are terrible in the snow I respectfully disagree. I plow three flat broom finished concrete driveways in South Eastern Michigan (just did 3” off all three this morning)… Carlisle Turf Savers with no added weight and no chains… work great for me. just my experience. I plow in 2nd gear with a C 105 and a C 6.5 (predator swap). Basically same tractors… Used chains first year and they definitely will mark up asphalt and concrete… Pics of my set up: 2 Share this post Link to post Share on other sites
