Wheelhorse616 4 #1 Posted December 26, 2021 My wheelhorse has been restored and my starter solenoid that is new only has power to the positive side. It won’t start but when I put a wrench across the two terminals it will start. Not the best with electrical so does the negative side of the starter have to be grounded. Thanks. 1 Share this post Link to post Share on other sites
Wheelhorse616 4 #2 Posted December 26, 2021 My wheelhorse 312-8 has been restored and my starter solenoid that is new only has power to the positive side. It won’t start but when I put a wrench across the two terminals it will start. Not the best with electrical so does the negative side of the starter have to be grounded. Thanks. Share this post Link to post Share on other sites
Handy Don 16,603 #3 Posted December 26, 2021 1 hour ago, Wheelhorse616 said: My wheelhorse has been restored and my starter solenoid that is new only has power to the positive side. It won’t start but when I put a wrench across the two terminals it will start. Not the best with electrical so does the negative side of the starter have to be grounded. Thanks. If you can jump the solenoid and start it, then you know two things: 1) the ignition switch "run" position is delivering power the coil to keep it running, and 2) the ignition switch "start" position is not getting power to the solenoid. What year is your 312? Can you post a picture of the solenoid and point out which connections you "wrenched" to start it? 1 Share this post Link to post Share on other sites
Handy Don 16,603 #4 Posted December 26, 2021 1 hour ago, Wheelhorse616 said: My wheelhorse has been restored and my starter solenoid that is new only has power to the positive side. It won’t start but when I put a wrench across the two terminals it will start. Not the best with electrical so does the negative side of the starter have to be grounded. Thanks. If you can jump the solenoid and start it, then you know two things: 1) the ignition switch "run" position is delivering power the coil to keep it running, and 2) the ignition switch "start" position is not getting power to the solenoid. What year is your 312? Can you post a picture of the solenoid and point out which connections you "wrenched" to start it? In the search bar, type "tractor 312-8 yyyy" replacing yyyy with your tractor's year. Select "use all my search terms" and "files" in the filters then hit enter. This will show you documents on file for your tractor. Come back when you have stuff! Good luck Share this post Link to post Share on other sites
953 nut 66,073 #5 Posted December 26, 2021 Most replacement solenoids have two small terminals, one goes to the "S" terminal on the ignition switch and the other is a ground. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #6 Posted December 27, 2021 You have a low oil switch that is part of the starter circuit. Check the oil level first and make sure it is full. Then disconnect the switch and see if it starts. The switch is mounted in the oil pan at the rear. If it does the low oil switch needs to be serviced. There are special instructions to remove the low oil switch without damaging it. 1 Share this post Link to post Share on other sites
Wheelhorse616 4 #8 Posted December 27, 2021 I figured out that my starter is fine, just have no clue where this wire goes, not good with electrical. If anyone owns 312-8 and knows where this goes, a description and picture would be great. Thanks. Share this post Link to post Share on other sites
Wheelhorse616 4 #9 Posted December 27, 2021 2 hours ago, gwest_ca said: You have a low oil switch that is part of the starter circuit. Check the oil level first and make sure it is full. Then disconnect the switch and see if it starts. The switch is mounted in the oil pan at the rear. If it does the low oil switch needs to be serviced. There are special instructions to remove the low oil switch without damaging it. I think I found the culprit, this wire, I am not sure where it goes because I am not good with wiring and can’t figure out the diagram too well. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #10 Posted December 27, 2021 The looks like a ground wire that would be between chassis parts to ensure a good ground but being a light gauge of wire would not be suitable for anything but a small circuit. 1 1 Share this post Link to post Share on other sites
Wheelhorse616 4 #11 Posted December 27, 2021 1 minute ago, gwest_ca said: The looks like a ground wire that would be between chassis parts to ensure a good ground but being a light gauge of wire would not be suitable for anything but a small circuit. If anyone finds picture or knows exactly where it goes it would help out a ton, thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #12 Posted December 27, 2021 Do you have a test light? Or a hand-held voltmeter? Share this post Link to post Share on other sites
Wheelhorse616 4 #13 Posted December 27, 2021 (edited) No test light as the ground wire is not connected to anything preventing it from being a full circuit. Edited December 27, 2021 by Wheelhorse616 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #14 Posted December 27, 2021 I should have said hand-held test light or hand-held voltmeter you can use for testing purpose. You need to figure out what part is not operating and then why it is not operating. We can help with that. Then the spare wire may come into play to correct the fault. 1 Share this post Link to post Share on other sites
953 nut 66,073 #15 Posted December 27, 2021 (edited) 13 hours ago, Handy Don said: If you can jump the solenoid and start it, then you know two things: 1) the ignition switch "run" position is delivering power the coil to keep it running, and 2) the ignition switch "start" position is not getting power to the solenoid. Most 312 models came with the Magnum engine, no points, no powered ignition coil, just a magneto. If the solenoid is not grounded it will not respond to twelve volts being applied to the other small post. Edited December 27, 2021 by 953 nut Share this post Link to post Share on other sites
RED-Z06 2,718 #16 Posted December 27, 2021 Thats the hood ground between the hood and block 1 1 Share this post Link to post Share on other sites
Wheelhorse616 4 #17 Posted December 27, 2021 4 hours ago, 953 nut said: Most 312 models came with the Magnum engine, no points, no powered ignition coil, just a magneto. If the solenoid is not grounded it will not respond to twelve volts being applied to the other small post. You mean the engine being grounded to the frame. I am guessing you mean from the block of the magnum engine right? Share this post Link to post Share on other sites
Wheelhorse616 4 #18 Posted December 27, 2021 6 hours ago, RED-Z06 said: Thats the hood ground between the hood and block What model tractor is that and what engine is on it. Just making sure. Share this post Link to post Share on other sites
RED-Z06 2,718 #19 Posted December 27, 2021 1 minute ago, Wheelhorse616 said: What model tractor is that and what engine is on it. Just making sure. 1987 312-8, M12S... Share this post Link to post Share on other sites
953 nut 66,073 #20 Posted December 28, 2021 8 hours ago, Wheelhorse616 said: You mean the engine being grounded to the frame. I am guessing you mean from the block of the magnum engine right? Look at post #5, I gave you a picture with an explanation. Share this post Link to post Share on other sites
RED-Z06 2,718 #21 Posted December 28, 2021 15 minutes ago, 953 nut said: Look at post #5, I gave you a picture with an explanation. Its very frustrating. Im confident if it was in front of me id have it cranking in 2 minutes or less... 1 Share this post Link to post Share on other sites
Wheelhorse616 4 #22 Posted December 28, 2021 34 minutes ago, 953 nut said: Look at post #5, I gave you a picture with an explanation. Sorry just confused because on another post somebody had sad the solenoids are already grounded. Share this post Link to post Share on other sites
RED-Z06 2,718 #23 Posted December 28, 2021 1 minute ago, Wheelhorse616 said: Sorry just confused because on another post somebody had sad the solenoids are already grounded. That was me. These tractors use a 3 post self grounding solenoid, it grounds to the frame, you apply 12v to the single small post, and it works. Share this post Link to post Share on other sites
Wheelhorse616 4 #24 Posted December 28, 2021 There’s some pictures, if anyone knows where that wire goes. Feel free to ask for more pictures of any other spot, let me know. Thanks! Share this post Link to post Share on other sites
Wheelhorse616 4 #25 Posted December 28, 2021 2 minutes ago, RED-Z06 said: That was me. These tractors use a 3 post self grounding solenoid, it grounds to the frame, you apply 12v to the single small post, and it works. Any extra pictures you need that would help you just let me know. Share this post Link to post Share on other sites
