Brockport Bill 2,144 #1 Posted December 14, 2021 your chart shows a 1970 Raider 10 having a 36 RD mower model # 5-7366 with a "successor" RD mower model #5-36mr 05 - I have a 36mr deck but no I.D. number... but assume its in the 05-36mr05 family --- does a 05-36mr05 fit that Raider for the lift assembly carriage and the pto and drive belt mule attachment etc? - i am not familiar with the Raider at all - thanks Share this post Link to post Share on other sites
TJ5208 1,841 #2 Posted December 14, 2021 Rebel has a 42 inch sd deck same tractor as yours the deck should fit 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,878 #3 Posted December 14, 2021 The front idler pulley assembly is different but do not know how that will affect it. One pulley is tensioned by a spring on the 5-7366. https://www.partstree.com/models/5-7366-toro-36-rear-discharge-mower-deck-1970/ The latest front idler assembly started in 1973 https://www.partstree.com/models/5-0622-toro-36-rear-discharge-mower-deck-1975/parts-list-for-rotary-mower-0/ Share this post Link to post Share on other sites
pfrederi 19,376 #4 Posted December 14, 2021 The raider could be had with a short lived front mount mule drive (pic1/2) that bolted directly to the frame. They are not real common. As an alternative you could get a set of these adapters (pic 3/4) that bolt on to the frame and let you create a modern front tachmatic to which you can mount a new style mule drive.. Search on here there are a couple threads that show you might bolt a modern tach matic to the front of the frame some drilling required,. Share this post Link to post Share on other sites
