RED-Z06 2,720 #1 Posted December 12, 2021 What paint actually dries hard? Seems like its hard to get a paint that dries and is durable. Any pictures of the rustoleum regal red? Share this post Link to post Share on other sites
Lee1977 7,756 #2 Posted December 12, 2021 8 minutes ago, RED-Z06 said: What paint actually dries hard? Seems like its hard to get a paint that dries and is durable. Any pictures of the rustoleum regal red? Regal Red Painted around 2010. I paint in the middle of the summer and put it out side for three or four days in the sun. 4 Share this post Link to post Share on other sites
johnnymag3 2,646 #3 Posted December 12, 2021 Regal Red 2016 ......different hue Driers hard though 3 1 Share this post Link to post Share on other sites
Pullstart 71,160 #4 Posted December 12, 2021 Regal Red, June of 2018. Rustoleum gray primer underneath. I wouldn’t say it’s super hard, but it would be easy to touch up. 3 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #5 Posted December 12, 2021 Any rattle can is not going to be as hard as a spray gun with hardener finish, but it's reasonably durable. You could always pick it up in the can, get a Harbor Freight 'purple gun', add some hardener before you spray. OR... look into a " 2K CLEAR COAT " after your rattle can. 2 Share this post Link to post Share on other sites
Jeff-C175 7,211 #6 Posted December 12, 2021 1 hour ago, RED-Z06 said: Any pictures of the rustoleum regal red? 3 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #7 Posted December 12, 2021 24 minutes ago, Jeff-C175 said: Any rattle can is not going to be as hard as a spray gun with hardener finish, but it's reasonably durable. You could always pick it up in the can, get a Harbor Freight 'purple gun', add some hardener before you spray. OR... look into a " 2K CLEAR COAT " after your rattle can. 2k is good stuff...i have a can of clear satin i got when i was restoring a Homelite Wiz55 but cant find a cylinder for it 3 Share this post Link to post Share on other sites
AMC RULES 37,259 #8 Posted December 12, 2021 Post #7777 here is showing some of my rattle can results. Share this post Link to post Share on other sites
stevasaurus 23,816 #9 Posted December 12, 2021 3 1 3 Share this post Link to post Share on other sites
squonk 47,990 #10 Posted December 12, 2021 This was done in RR about 5 yrs. ago. On the last color coat as it was still wet, a coat of Rustoleum Crystal Clear on top of it. Dries fast and hard. 3 1 Share this post Link to post Share on other sites
JCM 11,406 #11 Posted December 12, 2021 Excellent video for a Sunday afternoon. Thank you for that Steve. 1 1 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #12 Posted December 12, 2021 2 hours ago, AMC RULES said: Post #7777 here is showing some of my rattle can results. Pretty tractor 🤔 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #13 Posted December 12, 2021 Spraymax 2k on everything... particularly rustoleum. It dries super hard, as it is a "real" clear coat. Don Share this post Link to post Share on other sites
Snoopy11 5,731 #14 Posted December 12, 2021 3 hours ago, Jeff-C175 said: 2K CLEAR COAT Jeff had it covered already... Don Share this post Link to post Share on other sites
AMC RULES 37,259 #15 Posted December 12, 2021 My go to clear coat Available both, in a gloss or matte finish. 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #16 Posted December 12, 2021 1 hour ago, RED-Z06 said: Pretty tractor 🤔 Far cry from what I started with, so yes, thank you. Share this post Link to post Share on other sites
WHX?? 57,911 #17 Posted December 13, 2021 (edited) On this 1055 the hood was gunned by @Achto with Van Sickle in IH red. He did the fender pan too but during assembly I realized I'm a bone head prepped and painted the wrong pan so the right one I just rattle canned in regal. I didn’t prep it or anything cause I figured sometime Dan would have a can of Van Sickle open. Left the underside in primer.... just wanted to keep rolling with the project. The color match is dang near spot on ....regal might be a tad darker but not by much. Only real difference is the gloss and maybe abit of hardness. The belt guard was done in Van Sickle too. Rest of the tractor was rattled. Edited December 13, 2021 by WHX?? 4 Share this post Link to post Share on other sites
Achto 32,490 #18 Posted December 13, 2021 7 hours ago, RED-Z06 said: What paint actually dries hard? In order, hardest finish is #1 1 - epoxy 2 - urethane 3 - acrylic enamel with hardener 4 - synthetic/strait enamel with hardener 5 - either enamel without hardener 6 - spray can 2 1 Share this post Link to post Share on other sites
WHX?? 57,911 #19 Posted December 13, 2021 Might have asked you this before @Achto but whatever happened to Imron if I got that right. Used to be the bikers choice for scoots. Was supposed to be the hardest. Was that an epoxy? All I really remember is was hazardous to breath overspray. Share this post Link to post Share on other sites
Achto 32,490 #20 Posted December 13, 2021 3 minutes ago, WHX?? said: whatever happened to Imron if I got that right. Used to be the bikers choice for scoots. Was supposed to be the hardest. That was an epoxy paint made by Dupont. The original stuff no longer meets VOC regulations so it was pulled from the market. There is a new version, I have never sprayed it though. 1 Share this post Link to post Share on other sites
WHX?? 57,911 #21 Posted December 13, 2021 13 minutes ago, Achto said: original stuff no longer meets VOC regulations so it was pulled from the market. Maybe that's why the stoneys I knew sprayed it without respirators..... cheap high? 1 Share this post Link to post Share on other sites
ri702bill 12,915 #22 Posted December 13, 2021 9 hours ago, WHX?? said: Maybe that's why the stoneys I knew sprayed it without respirators..... cheap high? .... and a sad way to die. Two part paint in the air will permanently damage your lungs. As I said it will kill you - not today, but it will eventually catch up to you. BTW - how many retired Auto Body painters do you know???? I got out of the business at 26 years old.... Bill 1 Share this post Link to post Share on other sites
Gregor 4,848 #23 Posted December 13, 2021 I believe Chinese Red Lacquer dries harder than Regal Red. My biggest problem is finding a primer that dries as hard. The hardest paint on top of soft primer is still a problem. 2 8 Share this post Link to post Share on other sites
WHX?? 57,911 #24 Posted December 13, 2021 I've see that tractor before Greg...that seat is to die for! 1 Share this post Link to post Share on other sites
kpinnc 18,916 #25 Posted December 13, 2021 Gonna say the obvious: Greg that 876 is gorgeous! 1 Share this post Link to post Share on other sites
