TJ5208 1,841 #1 Posted December 5, 2021 (edited) Hey guys i was thinking about running chains on Rebel all year round with weights will it help traction in mud on hills pulling etc Edited December 5, 2021 by TJ salyers 1 Share this post Link to post Share on other sites
ebinmaine 76,170 #2 Posted December 5, 2021 Absolutely. Trina uses chains all year on her 867, Pigpen. Just do not use it on asphalt. 2 Share this post Link to post Share on other sites
Achto 30,325 #3 Posted December 5, 2021 No issue with that. I seen some people run chains with with turf tires to pull a mold board plow. 1 Share this post Link to post Share on other sites
953 nut 63,360 #4 Posted December 5, 2021 I keep tire chains and wheel weights on my GT-14 all year. As long as you don't spin the tires they are OK on paved driveways. 2 Share this post Link to post Share on other sites
ebinmaine 76,170 #5 Posted December 5, 2021 8 minutes ago, Achto said: No issue with that. I seen some people run chains with with turf tires to pull a mold board plow. How's that work on garden plowing? Decent traction? 1 Share this post Link to post Share on other sites
Achto 30,325 #6 Posted December 5, 2021 17 minutes ago, ebinmaine said: How's that work on garden plowing? Decent traction? Seems to work out well. 2 Share this post Link to post Share on other sites
Roger R 469 #7 Posted December 6, 2021 I have run chains on turf tires year around without problems. Great for banks and other steep areas especially when the grass is a bit damp. I found it does less damage to the turf due to little or no slip. 1 Share this post Link to post Share on other sites
ri702bill 10,812 #8 Posted December 6, 2021 You may also want to consider filling your rear tires with a non-freezing liquid like RV antifreeze, winter winshield washer fluid (as mine are) , or @ebinmaine's favorite - Rim Guard beet juice - IF you have a vendor for that near you. The first 2 weigh about 7-1/2 lbs per gallon, Rim Guard is heavier, around 10 lbs or so per gallon. My 23x8.50x12 turf tires hold about 5 and a half gallons each. You need to use tire tubes with the first 2 choices also - Rim Guard, as the name implies, is safe to use with painted steel wheels. 2 Share this post Link to post Share on other sites
