ri702bill 9,512 #1 Posted December 2, 2021 Some of you may recall several recent posts about Frame Reinforcing Plates or Angles and Diagonal Braces. Yesterday I installed the ones I made this summer for the C series. I was a bit concerned about unbolting all 4 Unidrive attaching bolts at once - working alone I did not want to have it shift. Removed the seat, rear pan and footrests - side metal. Jacked it up, placed 2 automotive jackstands at the outer ends of the rear foot rest mounts and set it down. Used 2 devices to hold the 8 speed - The floor jack under the front (shown) and a strap / comealong (not shown) to support the transaxle from above. No issues - parts are now installed. @Maxwell-8 - this is what we chatted about - all bolt in items. Bill 2 13 Share this post Link to post Share on other sites
Maxwell-8 4,367 #2 Posted December 2, 2021 (edited) That is a very beefy frame support! for sure a good idea to I could do on my C141 with such a heavy and torque engine! thanks!! Edited December 2, 2021 by Maxwell-8 1 1 Share this post Link to post Share on other sites
peter lena 9,302 #3 Posted December 2, 2021 @ri702bill , that's what I am talking about ! enhancing an original design set up , why not ? personally a good opportunity to upgrade related belt pulleys , that flat belt idler pully failure with those tiny bearings , industrial supply , do a match up on their swing out wall boards , same size / type pulley, with a larger 5/8 or 3/4 " bearing , wide rubber side shields , for easy lucas xtra heavy duty grease , change out , get the matching 3/8" ID bronze bushing for that pulley , bolt right on ,an exact fit , no noise or failures , lubricate all related linkage , make the rust run out ! looking at what I have done at same trouble spot , pete 1 Share this post Link to post Share on other sites
ri702bill 9,512 #4 Posted December 2, 2021 @peter lena Today I go thru all the brake and clutch pivots - disassemble, clean, use Pete's favorite green grease and reassemble with either nylon or copper thin washers to tighten up the joints - NEW stainless cotter pins. Do it once, do it right. 3 2 Share this post Link to post Share on other sites
peter lena 9,302 #5 Posted December 2, 2021 @Maxwell-8 opportunity , is the word , very often a problem exposes the opportunity while in a related area to correct anything else , could be a wiring / ground issue , or a rusted sloppy linkage point , if I am looking at it , you are too. regular bearing failures , put me on the lubrication change that I have done , no more failures or related noise . electrical problems , made me change and upgrade ALL WIRE ROUTING AND ELECTRICAL CABLE LUG MOUNTING POINTS . free up tight chafing / binding wires , use serated washers and dielectric grease at every connection point . use your battery ground cable bolt mount as a starting point , to engine corner , clutch pedal side , 4 ga cable to electrical lug , reduce to 10-12 gauge wire to engine charging bolt on rectifier point ground , continue to head light grounding . this set up works , on my 3 horses , GET FED UP , FIX IT ! Pete 2 Share this post Link to post Share on other sites
ebinmaine 72,940 #6 Posted December 2, 2021 Excellent work Bill. Share this post Link to post Share on other sites
ri702bill 9,512 #7 Posted December 3, 2021 Thanks. 1 Share this post Link to post Share on other sites
Handy Don 14,124 #8 Posted December 3, 2021 On 12/2/2021 at 8:33 AM, ri702bill said: Some of you may recall several recent posts about Frame Reinforcing Plates or Angles and Diagonal Braces. Yesterday I installed the ones I made this summer for the C series. I was a bit concerned about unbolting all 4 Unidrive attaching bolts at once - working alone I did not want to have it shift. Removed the seat, rear pan and footrests - side metal. Jacked it up, placed 2 automotive jackstands at the outer ends of the rear foot rest mounts and set it down. Used 2 devices to hold the 8 speed - The floor jack under the front (shown) and a strap / comealong (not shown) to support the transaxle from above. No issues - parts are now installed. @Maxwell-8 - this is what we chatted about - all bolt in items. Bill Elegant, well planned, and nicely executed. I especially like the "just bolt it in" aspect. Kudos. 3 Share this post Link to post Share on other sites
Sparky-(Admin) 23,266 #9 Posted December 3, 2021 Real nice modification! Probably should crawl under my dedicated snow plow tractor to make sure it isn’t “busted”. 2 Share this post Link to post Share on other sites
ebinmaine 72,940 #10 Posted December 3, 2021 15 minutes ago, Sparky said: Real nice modification! Probably should crawl under my dedicated snow plow tractor to make sure it isn’t “busted”. Definitely a good idea. Really not a bad fix to do and the bracing is certainly worth the investment of time to save a breakage later. 1 Share this post Link to post Share on other sites
