AHS
New carb for a B80
AHS
Ok, I’m having issues with the choke, I think the choke is 180 degrees from the old one. The choke plate is on the flat side of the shaft, and the detent ball is with it open (how it should be so it doesn’t accidentally close on you). Tell me you think…
pfrederi
A lot of the aftermarket (chicom) carbs have the choke set up for JD and other.  that is opposite what WH's need.  some provide an different choke shaft that you can put in... Honestly I have a couple horses where I just put a note on the instrument pane and live with reverse operation...
WHX??
Yeah that's always been a problem with the knock off carbs. Only two things you can do... one is try and get the tab off and rotate it and stake it back on. Paul beat me to the second one.
Edited by WHX??
ebinmaine
@AHS
I'm no fan of those Chinese carburetors but if you want to use it one option is to swap the choke shaft from the old carburetor.
Your BEST option is to do as Paul said above.
Do you have the old carb?
You mail it down here and I'll rebuild it for you...
  • Like 4
AHS
Ok, hold on; has anyone used one of these? That is set up right!
WHX??
Yep that's the right one just swap them out. I was never lucky enough for that to be "in the box" Red or even green loctite on those plate screws.
58 minutes ago, ebinmaine said:
@AHS
Yeah I know but so fast and easy even a Squonky can do it! :lol:
  • Haha 4
squonk
Heck I even think you can do it Jim! :)
  • Haha 4
ebinmaine
I agree with the principle of being fast and easy. Absolutely understand that.
Only thing is, I've had three or four of these things go through my shop now and all of them were garbage.
The one I bought for my own c-160 originally I had to clean the damn thing out three times.
How much time did I waste taking that thing back off the tractor. Draining the fuel system. Priming it back up.
After that episode and the others I'm done with replacement carbs. I'll keep rebuilding the old ones.
I'm glad they work for you guys though!
WHX??
That's why I have a box full of originals you are gonna inherit ..... :lol:
  • Haha 1
AHS
Guys, this is an I save tractors carb. From Maine. I mean it can be from China? I will save the original carb and send it down to you! @ebinmaine. As soon as I get this carb on there! On the B80, it just hunts on the hi side. I’ve played with the main jet a 1000 times!
pfrederi
  Probably if not maybe Taiwan.. in any event I got one for K341 from them still can't get it to idle or run well at other than full throttle...
They do NOT make carbs in the USA any more
Edited by pfrederi
  • Sad 2
ebinmaine
You send those out to me anytime.
Send a few rebuild kits.
I'll go through em for ya and you can broach a keyway or a few for me....
ebinmaine
I'll text you my address. Send it whenever...
You just pay for the kit and a bit of brake clean.
