JPWH 6,544 #26 Posted December 10, 2021 New front shoes arrived today. Í need to finish cleaning the rims and get them installed. 6 Share this post Link to post Share on other sites
953 nut 67,385 #27 Posted December 10, 2021 On 12/4/2021 at 3:00 PM, JPWH said: need to make handles for the throttle, choke, and hydraulic lever Lowell https://wheelhorsepartsandmore.com/ bought out Glen Pettit's molds and inventory and should be able to fix you up. 3 Share this post Link to post Share on other sites
JPWH 6,544 #28 Posted December 10, 2021 Thanks Dick. I knew he was making them but I am going to try to make something custom. Jay 1 Share this post Link to post Share on other sites
953 nut 67,385 #29 Posted December 11, 2021 10 hours ago, JPWH said: Thanks Dick. I knew he was making them but I am going to try to make something custom. Jay I know, you are just itching to turn some custom parts on the lathe aren't you? 3 Share this post Link to post Share on other sites
JPWH 6,544 #30 Posted December 11, 2021 Just a couple small pieces to mount some threaded knobs. 2 Share this post Link to post Share on other sites
JPWH 6,544 #31 Posted December 11, 2021 One custom throttle knob complete. 2 4 1 Share this post Link to post Share on other sites
JPWH 6,544 #32 Posted December 11, 2021 More parts came in the mail today. 5 Share this post Link to post Share on other sites
JPWH 6,544 #33 Posted December 12, 2021 I was playing in the shop early this morning. I spent a few minutes with the grinder with a cut off wheel, the drill press, and the lathe. 1 5 Share this post Link to post Share on other sites
ebinmaine 79,667 #34 Posted December 12, 2021 Nice work Sir. @Oldskool would get a kick outta this too. 2 1 Share this post Link to post Share on other sites
Oldskool 6,678 #35 Posted December 12, 2021 Thanks for the tag @ebinmaine Eric. Good looking tractor. Nice work on that side cover and knobs. I love those high wheel tractors but very few and VERY far between around here. 3 Share this post Link to post Share on other sites
JPWH 6,544 #36 Posted December 12, 2021 The more I do with this one the more I like it. I started getting the front wheels prepped for the new tri ribs.I want to try to keep the original patina but inside the wheels needs new paint I hope to get them mounted in the near future. I want to get the electrical as close to original as I can. I'm waiting on some bulb pigtails to arrive to start on rewiring. 4 Share this post Link to post Share on other sites
Pullstart 70,688 #37 Posted December 12, 2021 What about a rusty metal primer then a brown gloss paint on the inside of the wheels… then any spillage on the outside would be unnoticed? If not, gloss black? 2 Share this post Link to post Share on other sites
JPWH 6,544 #38 Posted December 12, 2021 I had not thought about gloss brown. I was going to use something close to original. I have cardboard and tape to avoid spillage. I will probably chuck them in the lathe on real slow speed to paint. 2 Share this post Link to post Share on other sites
Pullstart 70,688 #39 Posted December 12, 2021 1 hour ago, JPWH said: I had not thought about gloss brown. I was going to use something close to original. I have cardboard and tape to avoid spillage. I will probably chuck them in the lathe on real slow speed to paint. Perfect way to clean them with a wire wheel too! 5 Share this post Link to post Share on other sites
Oldskool 6,678 #40 Posted December 12, 2021 If your trying to match a rusty red color I found some paint that matched up pretty well. Sprayed lightly and let mother nature do the rest. I think it was a Rustoleum product. It was called Ruddy Red Primer. I've also used it as a rusty looking primer on wheels then misted the final color on until the coverage was where I wanted it. Then wet sanded to smooth out. Faux patina of sorts 2 Share this post Link to post Share on other sites
19richie66 17,929 #41 Posted December 12, 2021 (edited) Smear a thin coat of Dawn dish soap on areas you don’t want the paint to stick to. When your done just wash it off. Edited December 12, 2021 by 19richie66 2 2 Share this post Link to post Share on other sites
JPWH 6,544 #42 Posted December 12, 2021 This was the worst wheel. Even with the lathe it took a while to get it cleaned up. 4 2 Share this post Link to post Share on other sites
Pullstart 70,688 #43 Posted December 12, 2021 Looks great! I know some people have repaired pitted wheels with JB Weld or PC7. Great opportunity to smooth that thing out too! 2 Share this post Link to post Share on other sites
oliver2-44 11,628 #44 Posted December 12, 2021 I’ve used both PC7 and JB Weld on rim pitting in the beat area. Both work, although PC7 is a little thicker. I apply with a putty knife best I can. Then lay wax paper or clear cellophane wrap on it and smooth with my fingers through the wrap. Leave the wrap in place until dry. I then use a coarse file to work it down close and finish with sandpaper. Using the file and the wheel in the lathe should work great. 5 Share this post Link to post Share on other sites
JPWH 6,544 #45 Posted December 14, 2021 (edited) I have used JB weld on wheel repair to get it smooth after welding up holes and large pits. I will not be doing that to these wheels at this time. If I decide to restore them I will. I'm doing a rust treatment then a good coat of paint. I will be using tubes for the new tri rib tires. I received the light pigtails today. Now I can refurbish the headlights. Edited December 14, 2021 by JPWH 5 Share this post Link to post Share on other sites
8ntruck 9,046 #46 Posted December 14, 2021 On 12/12/2021 at 2:38 PM, Pullstart said: Looks great! I know some people have repaired pitted wheels with JB Weld or PC7. Great opportunity to smooth that thing out too! The wheels on my 72 Chevy pickup had pitted bead seats. After sandblasting, I used plain old Bondo to fill them. Used Rust Oleum primer and gloss white to finish. That was 8 maybe 10 years ago. Still holding air. I re-ground a broken 1/2" bolt hole punch from work to use as a tool to work the Bondo into place and shave it to final shape. 2 2 Share this post Link to post Share on other sites
JPWH 6,544 #47 Posted December 16, 2021 The inside of the rims are painted. I'm letting them sit a few days before I mount the tires. I also got all the new light socket pigtails installed and tested the headlights, tail light, and the gen warning light. 3 6 Share this post Link to post Share on other sites
19richie66 17,929 #48 Posted December 17, 2021 Awesome progress. I knew it went to a good home. 3 1 Share this post Link to post Share on other sites
rjg854 13,180 #49 Posted December 17, 2021 With what he did with that 854, no doubt about it. 2 1 Share this post Link to post Share on other sites
JPWH 6,544 #50 Posted December 17, 2021 (edited) I also have the new seat but will wait till it is installed to show it. Maybe this weekend. Also need to get a rear lift cable or some sort of linkage to the lift. Edited December 17, 2021 by JPWH 2 1 Share this post Link to post Share on other sites
