Jack Orsi 2 #1 Posted November 28, 2021 Wondering what the difference is in configuration on the underside of the deck between a mulching deck and a non mulching deck. Thought the mulching was a great idea but it has its own set of drawbacks especially in long grass. 1 Share this post Link to post Share on other sites
kpinnc 19,008 #2 Posted November 28, 2021 (edited) Mulching decks are heavily baffled, and the exhaust chute is plugged. Any decent one will use some type of mulching blades as well. And you nailed the drawback: heavy grass will overwhelm the mulching. Even short grass will make a clogged up mess, and mulching decks should be thoroughly cleaned out regularly. And now just my opinion: I can't think of a single benefit of a mulching deck that outweighs the negative. Even if it works as advertised- it's gonna make a mess and greatly reduce the lifespan of the deck and spindles. You're far better off to use a deck with a wide discharge pattern. Mulching blades will still reduce clipping size and minimize clumping. Edited November 28, 2021 by kpinnc 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #3 Posted November 28, 2021 This is a 42" side discharge deck that I converted into a mulcher. The redlines is where I added steel. Their is a link to it in my signature (underneath this post.) Share this post Link to post Share on other sites
Jack Orsi 2 #4 Posted November 28, 2021 Thanks Maxwell. Will look at converting to side discharge now that I know which baffles to remove. Deck came with the side discharge cover so I suspected it might be a kit. Deck and spindles seem to be in good shape and I always wash after use but it dies accumulate and also makes for uneven cutting. Ihave a tow behind sweeper so if it's really windrowish I can always sweep. It takes about 4-41/2 hrs to do front and back yards. Share this post Link to post Share on other sites
peter lena 10,090 #5 Posted November 28, 2021 @Jack Orsi wow 4 -1/2 hrs to do it ? agree with @kpinnc for a wide discharge deck , think the undue stress and wear on the entire deck is evident. towing a separate powered deck for field use could be a consideration. I use rear discharge decks , regularly , even at highest setting , dealing with high field grass would be asking too much. a field design separate cutting deck would probably be your answer. pete Share this post Link to post Share on other sites
pacer 3,180 #6 Posted November 28, 2021 14 hours ago, kpinnc said: You're far better off to use a deck with a wide discharge pattern. I would never use a 'chute' just for this reason. I want my clippings to come aroaring out of the deck and spreading it out. My property has/had VERY poor soil - gumbo clay, and for several years I could hardly grow weeds (but welcomed them cause I had something growing!) But over the years with shooting the clippings out my soil has improved to the point that I now have grass on 90% of my 2-2 1/2 acres and I firmly believe that adding those clippings has been a big factor in this. Course it also helped to get rid of some 100-125 pine trees (highly acidic soil) Share this post Link to post Share on other sites
