paxz71usa 173 #1 Posted November 28, 2021 (edited) Thought I would ask the ones that know because I for one don't know . I have a '73 12 Automatic that I started noticing a slight bit of play in the right front wheel. I'm currently using the tractor to haul wood and I'm trying to avoid down time by having the parts when I start the work. Looking at the parts break down that I have the part number for the front wheel bearings is 4999. Is this correct? From google search there seems to be several places that sell a replacement for these bearings. Any suggestions on where to buy would be helpful and which style i.e. sealed or greaseable. Since I'm not the worlds greatest mechanic with nothing more than basic tools , any "how to" help would be appreciated for sure. Thanks, PAX Edited November 28, 2021 by paxz71usa Share this post Link to post Share on other sites
RandyLittrell 3,945 #2 Posted November 28, 2021 These will fit right here and you if don't want to buy from Amazon you can just search for this size. https://smile.amazon.com/XiKe-Bearings-Applicable-Wheelbarrows-Replacement/dp/B078JY8452/ref=sr_1_3?crid=34YY9LY56MOKB&keywords=wheel+horse+wheel+bearings&qid=1638069290&sprefix=wheel+horse+whe%2Caps%2C198&sr=8-3 Randy 1 Share this post Link to post Share on other sites
ebinmaine 80,642 #3 Posted November 28, 2021 I bought sealed bearings in a couple 10 packs of the popular auction site. I like the sealed part for the convenience of no maintenance and no mess. 4 Share this post Link to post Share on other sites
Racinbob 13,135 #4 Posted November 28, 2021 Another I initially thought I'd just use them on my non-workers but about 3 years ago I put them in my workers. No grease mess and holding up great. Share this post Link to post Share on other sites
ebinmaine 80,642 #5 Posted November 28, 2021 23 minutes ago, Racinbob said: I put them in my workers. I'll be using them the same here as well. No real heavy usage yet. We'll see how they hold up next year. 1 Share this post Link to post Share on other sites
peter lena 10,047 #6 Posted November 28, 2021 @ebinmaine got them in my stuff , with those wide rubber side shields ,did the clean out and a lucas upgrade , been solid , thats just me , bearings have had no problems , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,642 #7 Posted November 28, 2021 44 minutes ago, peter lena said: wide rubber side shields Pete you talking about the end cups over the axle or something else? Share this post Link to post Share on other sites
Lee1977 7,764 #8 Posted November 28, 2021 5 minutes ago, ebinmaine said: Pete you talking about the end cups over the axle or something else? He's popping the bearing seal out and then putting it back in. 2 1 Share this post Link to post Share on other sites
peter lena 10,047 #9 Posted November 28, 2021 @ebinmaine sorry to confuse you , have been popping wide rubber. side bearing shields , for quite a while now , matter of fact when ever I do a bearing search that is the first thing I want ,wide side shields @Lee1977 was right on it . there probably isn't a bearing on my stuff that has not had the lucas upgrade . small pocket screwdriver , delicately pry on the side edge , no damage , do the grease switch , seal easily pops back in , no leaks . have no whining bearing noise or failures since, keep it greasy pete 2 Share this post Link to post Share on other sites
Achto 32,635 #10 Posted November 28, 2021 I like the bearings that have a seal on the outside but are open on the inside. Allows me to grease them and not have a mess on the outside. 2 Share this post Link to post Share on other sites
peter lena 10,047 #11 Posted November 28, 2021 @Achto that's what i do on my mower decks , using that lucas x tra heavy duty , hi temp anti sling , polyurea grease , also in my mule duplicate bearings . no whining bearings and no failures since doing the grease change out , pete 1 1 Share this post Link to post Share on other sites
