AHS 1,563 #1 Posted November 26, 2021 Ok, for the K series, (301, 321 etc) the intake gasket is 271030S The air filter gasket is 45 041 07S Does it apply to the M10, M12? I would think so… Correct me if I’m wrong, but I want to write these things down. Share this post Link to post Share on other sites
Maxwell-8 4,367 #2 Posted November 26, 2021 (edited) 1 hour ago, AHS said: Ok, for the K series, (301, 321 etc) the intake gasket is 271030S The air filter gasket is 45 041 07S Does it apply to the M10, M12? I would think so… Correct me if I’m wrong, but I want to write these things down. the gasket between the carb and engine is the same, the one between the airfilter and carb was diffrent K301 gasket on a M12 airfilterholder I had to drill the two "higher" middleheight holes to fit the K301 carb Edited November 26, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
pfrederi 18,971 #3 Posted November 26, 2021 These two should answer most your questions... 1 Share this post Link to post Share on other sites
AHS 1,563 #4 Posted November 26, 2021 Ok! Ya, I remember that, @Maxwell-8. Thank you @pfrederi… I got all the numbers!! Share this post Link to post Share on other sites
