Handy Don 16,953 #26 Posted November 25, 2021 Very interesting. The recycler 42 is a different deck than either SD or RD? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,354 #27 Posted November 26, 2021 https://www.wheelhorseforum.com/search/?q=86001&quick=1&type=downloads_file Share this post Link to post Share on other sites
Handy Don 16,953 #28 Posted November 26, 2021 15 hours ago, gwest_ca said: https://www.wheelhorseforum.com/search/?q=86001&quick=1&type=downloads_file Thanks for the link. Clever engineering there, and an interesting read of the install manual. Cautions on the grass height/amount of cut are worth noting! Share this post Link to post Share on other sites
cod 135 #29 Posted November 28, 2021 On 11/24/2021 at 7:41 AM, squonk said: Here's how much dirt and dust gets trapped with the insert. 99% of it just sweeps right out. And what gets trapped under the kickers When I picked up a re-cycler deck a few years ago I installed a rubber membrane that stretched over the spindles and covered the plate that holds the kickers. I run it with gator blades and it appears to work fine for leaves in the Fall. Watching this tread and Maxwell's post about converting a SD deck to a mulching deck with baffles has me wondering if it would be worthwhile to remove most of the plate that holds the kickers to get more room for gator style blades to grind things up. It seems to me that when WH made this style deck, gator blades as we know them, may not have been available so they opted for the kicker design. I think Squonk is doing the right thing to keep his deck in shape but perhaps opening up the hole in the flat plate and no kickers would make it easier to clean. The rascal would weigh less too... ;-) Cod Share this post Link to post Share on other sites
76c12091520h 4,238 #30 Posted December 1, 2021 Found these in my current nos parts haul..... Share this post Link to post Share on other sites
