WheelHorse520H 710 #1 Posted November 20, 2021 I have a 48” plow for my 520 that I am trying to put on my 607 with the solid lift linkage / down pressure bar. I have the second steel bar for the shorter frame but when I try to lift it the handle gets caught on the right footrest. Does anyone have any photos of how this gets setup? Thanks, Andrew Share this post Link to post Share on other sites
wallfish 20,667 #2 Posted November 20, 2021 Not too many people are going to put that blade on a 607 so it might be best if you post pics of what you have going on and we can figure it out. If that 520 blade frame has the extension on it for swept forward axle, remove it. Think it should fit on that tractor but... If all else fails I might have the correct A frame but have to look out back at the 2 that are out there. 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #3 Posted November 20, 2021 1 minute ago, wallfish said: If that 520 blade frame has the extension on it for swept forward axle, remove it Nope, pre swept axle. The manual for the plow says it will fit the short frames but I can’t get photos tonight. I’ve got it up and down before but then I angled the blade and then the handle got caught. Thanks for the help. Share this post Link to post Share on other sites
stevasaurus 23,857 #4 Posted November 20, 2021 Sometimes turning that handle around is what you need to do. Share this post Link to post Share on other sites
WheelHorse520H 710 #5 Posted November 20, 2021 4 hours ago, stevasaurus said: Sometimes turning that handle around is what you need to do. It was where the handle attaches that was the problem. But it’s good now, I just adjusted the location of the footrest, it’s not as comfortable but it works now. 1 Share this post Link to post Share on other sites
wallfish 20,667 #6 Posted November 20, 2021 The older axle brackets were set on the front of axle and pinch to the square of the the trans front and back whereas the newer style bracket bolts on the bottom and top of that trans square section. Just a guess but that's probably 1 1/2 difference so the older type would move that plow frame forward about 1 1/2". Does your bracket bolt to the trans top and bottom? Share this post Link to post Share on other sites
WheelHorse520H 710 #7 Posted November 20, 2021 3 minutes ago, wallfish said: Does your bracket bolt to the trans top and bottom? Yes, it sits on top of the axle and hangs down with the bolts pointed up. Share this post Link to post Share on other sites
wallfish 20,667 #8 Posted November 20, 2021 Pic of an older type bracket in this thread. It's not meant to be on a G14 but you should get the idea. 1 Share this post Link to post Share on other sites
