AHS
Drive pulley on an 8 speed
AHS
Ok, drive pulley seal is leaking. I am in the midst of replacing it. The pulley came off easy. Now the seal… use a pick tool? Like the ones seen in the picture? I can’t seem to get it out, any ideas?
ebinmaine
I haven't had a lot of luck removing the metal seals with just a pick.
I usually take a long thin quarter inch wide flat screwdriver and kind of crush the seal in and it will start to rotate. Just keep doing that very carefully and it will spin right out of its place.
oldlineman
you will also have to remove the key, this has to be done to install new seal but will help with removing old one also. Don't get too aggressive there is a needle bearing lurking behind the seal. Patience will be your friend. Bob
peter lena
AHS
Metal seals? I will have to show you the one I have got from the dealer.  I am unsure if it the right seal, cause this is the first time I have done it. I do like the idea of a packing tool and a screwdriver!
ebinmaine
They certainly can be plastic too.
I've taken a few of those out as well. Usually they have a metal ring where they hit the transmission case and of course a rubber ring where they contact the axle.
peter lena
@SylvanLakeWH  just drill or make a pin hole for that packing puller to get in , and you have instant mechanical advantage , makes tough removals much easier . those bearing distributors , have swing out wall boards , with all types of pulleys and seals on them . love the fact that you can duplicate your pulley with a larger bearing , wide side seals , guess what ? lucas grease replacement , very easy . get a matching bronze bearing insert , for 3/8 bolt mount , have that on my 3 horses , amazing quiet , solid ease , in a typical problem area , make sense ? being a retired millwright , my main thought was to make a problem go away , that's how I look at anything . just me , pete
SylvanLakeWH
I think you meant to tag @AHS…
Great advice! :handgestures-thumbupright:
AHS
Great advice! Make a pin hole with a drill bit! Yup!!
AHS
Your right @ebinmaine the seal was metal on the outside, double lip on the inside. Drilled the seal, and it pulled out! Easy! Thank you!!
