RandyL 53 #1 Posted November 1, 2021 I have a leaking fuel tank. Folks here state that it is polypropylene. ( from here on known as PP ). I was curious where I could aquire more PP to test and weld with. I thought about oil bottles and did a research about such. Oil bottles seem to be made with either PP or HDPE ( high density polypropylene ). The oil producers site got onto recycling.. PP is code 5, HDPE is code 2. I checked 4 oil containers in my shop, sure enough, they were all marked. I had never noticed. All of mine are marked HDPE 2. Outside of that HDPE has a lower melting point than PP. That may be good for trying to repair weld? No idea if this is useful, but did find it interesting. You can get HDPE oil bottles in any color as well. Share this post Link to post Share on other sites
ebinmaine 75,822 #2 Posted November 1, 2021 Your tank have a cracked seam? Share this post Link to post Share on other sites
Stepney 2,356 #3 Posted November 1, 2021 Oh, fun... Haven't done it in a few years. But we used to run a paid of 71 SkiDoo's and the tanks always cracked. Could never get anything to grab.. so I sawed off the very rim of the gas filler neck, heated it and bent it straight, and it became the filler material. Had a long neck so it wasn't critical and it was the same material.. worked good. 2 Share this post Link to post Share on other sites
RandyL 53 #4 Posted November 1, 2021 39 minutes ago, ebinmaine said: Your tank have a cracked seam? Yea, My tank is pretty well wasted, but this may still be useful for later, or others. Share this post Link to post Share on other sites
RandyL 53 #5 Posted November 1, 2021 37 minutes ago, Stepney said: Oh, fun... Haven't done it in a few years. But we used to run a paid of 71 SkiDoo's and the tanks always cracked. Could never get anything to grab.. so I sawed off the very rim of the gas filler neck, heated it and bent it straight, and it became the filler material. Had a long neck so it wasn't critical and it was the same material.. worked good. That is what got me onto this. I was thinking of cutting up my tank and save strips of it for future "welding", Then I started looking into where else I would find it. Share this post Link to post Share on other sites
RandyL 53 #6 Posted November 1, 2021 44 minutes ago, ebinmaine said: Your tank have a cracked seam? I'm looking for a tank for my 74 c-120. I may have to use non-WH and make fixtures to hold it if I don't find one. Share this post Link to post Share on other sites
SylvanLakeWH 29,891 #7 Posted November 1, 2021 Two thoughts: 1. Post a want add for another tank. Either use it or sacrifice for material. 2. Shave some material off the neck or other area as mentioned above. Melt it dripping onto crack. Seal with soldering tip… 2 1 Share this post Link to post Share on other sites
ebinmaine 75,822 #8 Posted November 1, 2021 9 minutes ago, RandyL said: I'm looking for a tank for my 74 c-120. I may have to use non-WH and make fixtures to hold it if I don't find one. 3 minutes ago, SylvanLakeWH said: Post a want add for another tank I've got a red tank that has a bad outlet I think. It could be used by cutting/drilling the bottom hole or as sacrificial material. If no one here on Redsquare has one maybe Lincoln at A to Z does. 2 Share this post Link to post Share on other sites
Achto 30,210 #9 Posted November 1, 2021 2 hours ago, RandyL said: I was curious where I could aquire more PP to test and weld with Check with a local shop that has supply's for body shops. They should carry multiple types of fillers for plastic welding. Or. https://www.amazon.com/Plastic-Welding-Bumper-Soldering-Supplies/dp/B07JL7TKK3/ref=sr_1_5?dchild=1&gclid=CjwKCAjwoP6LBhBlEiwAvCcthEJHm38lFJfRmaKcovhFrUqjkgXTJ8j7PoSffGWi7KmebIqS6DJq1RoC23YQAvD_BwE&hvadid=256784799250&hvdev=c&hvlocphy=9019452&hvnetw=g&hvqmt=e&hvrand=10329730357772323814&hvtargid=kwd-518207011592&hydadcr=11983_9729845&keywords=pp+plastic+welding+rods&qid=1635808065&sr=8-5 1 Share this post Link to post Share on other sites
RandyL 53 #10 Posted November 1, 2021 10 minutes ago, Achto said: Check with a local shop that has supply's for body shops. They should carry multiple types of fillers for plastic welding. Or. https://www.amazon.com/Plastic-Welding-Bumper-Soldering-Supplies/dp/B07JL7TKK3/ref=sr_1_5?dchild=1&gclid=CjwKCAjwoP6LBhBlEiwAvCcthEJHm38lFJfRmaKcovhFrUqjkgXTJ8j7PoSffGWi7KmebIqS6DJq1RoC23YQAvD_BwE&hvadid=256784799250&hvdev=c&hvlocphy=9019452&hvnetw=g&hvqmt=e&hvrand=10329730357772323814&hvtargid=kwd-518207011592&hydadcr=11983_9729845&keywords=pp+plastic+welding+rods&qid=1635808065&sr=8-5 Thanks for the link. That is very useful. 1 Share this post Link to post Share on other sites
DennisThornton 4,772 #11 Posted November 1, 2021 It can be "welded" with more HDPE and good techniques. It would NOT be my first attempt! Practice on something else first. Or second... Or third... 1 Share this post Link to post Share on other sites
RandyLittrell 3,942 #12 Posted November 2, 2021 From one Randy L to another, I bought a tank for my C-120 from A-Z, here is a link to his website. Just call him on the phone and he can fix you up. https://a-ztractor.com/ Randy 2 Share this post Link to post Share on other sites
RandyL 53 #13 Posted November 2, 2021 34 minutes ago, RandyLittrell said: From one Randy L to another, I bought a tank for my C-120 from A-Z, here is a link to his website. Just call him on the phone and he can fix you up. https://a-ztractor.com/ Randy Thank you, I have a possible one in the works. I will let that work out before I look further. I appreciate having more options. I will use the phone as you say. Currently having my lift cyl rebuilt by the folks in MN. Anxious to get it all together before cold weather as my shop has no heat. 2 Share this post Link to post Share on other sites
rjg854 12,639 #14 Posted November 2, 2021 Depending on how big and well insulated your shop is, one of those oil-filled heaters might be an ideal. If you know you're going to spend any amount of time out there, turn it on an hour or so before you're going to be out there, might be enough to take the edge off. My horse barn is only 14x18, with 6" of rockwool in the ceiling, and 1 1/2" styrofoam in the sidewalls between the purlins. This will be the 1st time I'll have any type of heat in there. And it will be for those times I actually spend any great amount of time in there. So far (knock on wood) I don't mind the cold that much. So even to get it above freezing will be fine. I'm not planning on constant heat. Share this post Link to post Share on other sites
RandyL 53 #15 Posted November 2, 2021 1 hour ago, rjg854 said: Depending on how big and well insulated your shop is, one of those oil-filled heaters might be an ideal. If you know you're going to spend any amount of time out there, turn it on an hour or so before you're going to be out there, might be enough to take the edge off. My horse barn is only 14x18, with 6" of rockwool in the ceiling, and 1 1/2" styrofoam in the sidewalls between the purlins. This will be the 1st time I'll have any type of heat in there. And it will be for those times I actually spend any great amount of time in there. So far (knock on wood) I don't mind the cold that much. So even to get it above freezing will be fine. I'm not planning on constant heat. I am lucky to have indoor area. its 45 x 60. I use a space heater to somewhat point at the area I am working in, but there is no heating this big metal building. I used 11 ft sidewalls and its all open. I just stay in when the cold gets here. Old age must be creeping in! Share this post Link to post Share on other sites
RandyLittrell 3,942 #16 Posted November 3, 2021 11 hours ago, RandyL said: I am lucky to have indoor area. its 45 x 60. I use a space heater to somewhat point at the area I am working in, but there is no heating this big metal building. I used 11 ft sidewalls and its all open. I just stay in when the cold gets here. Old age must be creeping in! A friend of mine uses tyvek sheeting and 2x2's to make a paintbooth in his shop, I bet you could do something similar to make yourself a smaller space to heat for the winter and could just take it apart in sections come summer. Randy Share this post Link to post Share on other sites
threepiece 6 #17 Posted November 3, 2021 On 11/1/2021 at 4:57 PM, RandyL said: I have a leaking fuel tank. Folks here state that it is polypropylene. ( from here on known as PP ). I was curious where I could aquire more PP to test and weld with. I thought about oil bottles and did a research about such. Oil bottles seem to be made with either PP or HDPE ( high density polypropylene ). The oil producers site got onto recycling.. PP is code 5, HDPE is code 2. I checked 4 oil containers in my shop, sure enough, they were all marked. I had never noticed. All of mine are marked HDPE 2. Outside of that HDPE has a lower melting point than PP. That may be good for trying to repair weld? No idea if this is useful, but did find it interesting. You can get HDPE oil bottles in any color as well. Gosh I thought fuel tanks are made from polyethylene not polypropylene. Isn’t HDPE high density Polyethylene? 1 Share this post Link to post Share on other sites
RandyL 53 #18 Posted November 3, 2021 7 hours ago, threepiece said: Gosh I thought fuel tanks are made from polyethylene not polypropylene. Isn’t HDPE high density Polyethylene? Yes it is. I'm happy you caught that. Not my intent to spread incorrect info. Got my words turned around after reading a few web sites. Thanks! 1 Share this post Link to post Share on other sites
