Sarthurs01 1,028 #1 Posted October 11, 2021 So winter is not far off, and show season is over, what are you guys doing to store for the winter? Last year I drained all the fuel and ran the carbs dry and didn’t seam to have any issue. I am running ethanol free fuel too. The 2 Rjs will be in a heated bacement but the c81 and commando will be in a cold shed. Should mention I am in Western PA where it’s 20° one day and 65° the next. Haha 4 Share this post Link to post Share on other sites
pfrederi 20,147 #2 Posted October 11, 2021 I either empty the tank or add Stabil shut off the gas and run them till they stall pull the choke at at the end to empty them completly. if you have a Techy a lot of then have bowl drains a great idea... 4 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #3 Posted October 11, 2021 Haven’t had this issue, mine get run year round, usually once a week or two. 3 Share this post Link to post Share on other sites
squonk 45,929 #4 Posted October 11, 2021 Tractors that are stored here get 94 octane VP fuel from TSC. 3 year shelf life. Just enough to get the carb full and run a few minutes. 3 1 Share this post Link to post Share on other sites
Achto 31,423 #5 Posted October 12, 2021 I only use non-ethanol fuel in my small engines, every drop of it is treated with Sea Foam. When storage season comes around I run the carburetors dry and put them to bed. 2 1 Share this post Link to post Share on other sites
Pullstart 69,478 #6 Posted October 12, 2021 10 hours ago, Achto said: I only use non-ethanol fuel in my small engines, every drop of it is treated with Sea Foam. When storage season comes around I run the carburetors dry and put them to bed. Would you say a fuel tank full to the tippy top is better or bone dry is better as far as condensation control goes? 1 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #7 Posted October 12, 2021 1 minute ago, Pullhosen’s Pony Express said: Would you say a fuel tank full to the tippy top is better or bone dry is better as far as condensation control goes? From what I’ve read off the back of the Sta-bil bottle, up to the tippy top. 2 Share this post Link to post Share on other sites
Achto 31,423 #8 Posted October 12, 2021 (edited) 1 hour ago, Pullhosen’s Pony Express said: Would you say a fuel tank full to the tippy top is better or bone dry is better as far as condensation control goes? I would agree with full to the top. Also, A small amount of fuel will go bad faster than a large amount. When working at a motorcycle shop, bikes would come in that would not start in the spring. Most times I would drain the fuel from the bowl, and they would start on the gas that was sitting in the tank all winter. Edited October 12, 2021 by Achto 3 Share this post Link to post Share on other sites
peter lena 9,815 #9 Posted October 12, 2021 @Sarthurs01 got your battery tender plug in wired to your battery ? sta-bil in all my gas no fuel issues at all, regularly run my three horses , lighter winter oil , same zink additive , no problems , pete 1 Share this post Link to post Share on other sites
953 nut 64,880 #10 Posted October 12, 2021 I have made a practice of adding Stable Gas Additive and Seafoam to every drop of Non-Ethanol Gas I buy. Also make an effort to run each for a while year round. Even though there is no grass to mow in the winter the 310-8 gets some exercise once a month. Same for the 953s, no shows to attend but quality seat time pulling a cart picking up fallen branches is good practice for the show dates to come. The GT-14 with FEL gets worked all year and the 418-C is in leaf blowing mode now and is my go-to snow mover for the winter months so it never sits idle. The 1055 is a back-up snow mover but gets out to push some dirt from time to time. Mine are never in storage, they just take turns putting a smile on my face. 4 1 Share this post Link to post Share on other sites
Sarthurs01 1,028 #11 Posted October 12, 2021 14 minutes ago, peter lena said: @Sarthurs01 got your battery tender plug in wired to your battery ? sta-bil in all my gas no fuel issues at all, regularly run my three horses , lighter winter oil , same zink additive , no problems , pete Yep I have all my batteries on tenders. Made that mistake one winter on our 16v race car battery.. NEVER agin! haha 1 Share this post Link to post Share on other sites
peter lena 9,815 #12 Posted October 12, 2021 @ 953 nut , been using ethanol fuel all along with no problems , rotate my 3 horses , 2 with plows and 1 with the blower when needed . agree with the activity , just for snow fun , the weather has not been what it was , more sloppy than light and fluffy . still needed to keep driveway clear and the dreaded frozen snow issue . also use my walking snow blower for tight spots , pete 1 Share this post Link to post Share on other sites
littleredrider 409 #13 Posted October 12, 2021 I don’t do anything really. I run 93 in everything, and had stuff sit for months, and always started. But this winter I’ll actually be able to use my garage, no heat but least outta the elements. 3 Share this post Link to post Share on other sites
peter lena 9,815 #14 Posted October 12, 2021 @ 953 nut , been using ethanol fuel all along with no problems , rotate my 3 horses , 2 with plows and 1 with the blower when needed . agree with the activity , just for snow fun , the weather has not been what it was , more sloppy than light and fluffy . still needed to keep driveway clear and the dreaded frozen snow issue . also use my walking snow blower for tight spots , pete 1 Share this post Link to post Share on other sites
peter lena 9,815 #15 Posted October 12, 2021 @littleredrider have a couple of sheds , out of the weather is best , real cold spells use an old type bulb in a reflector , tucked up under the engine , just keeps the engine slightly warm , for instant starts . pete 1 Share this post Link to post Share on other sites
squonk 45,929 #16 Posted October 12, 2021 Snow equipment on battery tenders. Turn the key and they start. 2 Share this post Link to post Share on other sites
Jeff-C175 7,207 #17 Posted October 12, 2021 16 hours ago, Sarthurs01 said: 20° one day and 65° the next Same here in Joisey, and I've had issues with condensation (dew) because of it. I roll my toolboxes into a more protected part of my shop so the tools don't rust. Keep doors closed as much as possible during these periods. There have been conditions when EVERY thing in my shop has been dripping wet! This has been more troublesome in my shop than fuel preservation! 1 Share this post Link to post Share on other sites
Handy Don 16,128 #18 Posted October 12, 2021 41 minutes ago, Jeff-C175 said: Keep doors closed as much as possible during these periods. Yep. Not uncommon here in winter to open the garage door, back out the cold-soaked car and have it be coated with condensation by the end of the driveway. I've learned to get that garage door closed again quickly! 2 Share this post Link to post Share on other sites
wh5208speed 669 #19 Posted October 15, 2021 Here is our winter strategy: ethanol free w/ Stabil year round keep tanks full Calendar reminder for 1x per month to start all engines and let run for 5-10 minutes This includes small equipment as well (trimmer, leaf blower, chain saw, push mower, etc.) The only exception is the pressure washer as the pump gets winterized, so you can't start it up once you put the pump foam Never have an issue since starting this plan 1 Share this post Link to post Share on other sites
pfrederi 20,147 #20 Posted October 15, 2021 At $4.25 a gallon for non-ethanol yesterday getting the heavily used horses converted from regular to NE for the last tankful is getting pricey... 1 Share this post Link to post Share on other sites
