kpinnc 16,201 #926 Posted March 6, 2022 (edited) 3 hours ago, Horse Newbie said: with model number 4120OE01, the seat pan you gave me appears to be off of a 520. Probably. I picked up two over the years that were donor machines. Shameful but true. Edited March 6, 2022 by kpinnc 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #927 Posted March 7, 2022 I sanded on the seat pan a little more and primed it for the Work Horse… 2 8 Share this post Link to post Share on other sites
Horse Newbie 7,398 #928 Posted March 7, 2022 Does anybody know a source for the little square rubber bumpers (about 1/2 to 3/4 inch square) ? I have seen them used as a bumper between the foot boards and seat pan/ rear fender on many Wheel Horses. They may be seen under seat brackets also to keep from damaging the seat pan paint. Thanks… Share this post Link to post Share on other sites
ebinmaine 75,772 #929 Posted March 7, 2022 My first inclination would be to tell you to call McMaster Carr. There are other ways you could go as well. I don't know what thickness you're looking for but you might be able to get a hold of a sheet of gasket material and cut the squares to your own size. Spray glue them in place or whatever. Also a possibility might be sheets of some sort of furniture to floor protector. Bunches of different kinds of that. All the tractors that Trina and I have, the seat pan folds backwards. Not bolted in place like the newer ones. We've used door edge protector in that same location. 1 Share this post Link to post Share on other sites
kpinnc 16,201 #930 Posted March 7, 2022 18 minutes ago, ebinmaine said: Also a possibility might be sheets of some sort of furniture to floor protector. Bunches of different kinds of that. I would agree. I had 1/4 inch adhesive rubber bumpers from work stuff, and still got some scratches. The area between the footrests and fender flexes quite a bit. 2 Share this post Link to post Share on other sites
Handy Don 15,205 #931 Posted March 7, 2022 1 hour ago, Horse Newbie said: Does anybody know a source for the little square rubber bumpers (about 1/2 to 3/4 inch square) ? I have seen them used as a bumper between the foot boards and seat pan/ rear fender on many Wheel Horses. They may be seen under seat brackets also to keep from damaging the seat pan paint. Thanks… here is one that I found using a google search for "rubber table leg feet square stick-on" good luck 1 Share this post Link to post Share on other sites
WHX?? 53,349 #932 Posted March 7, 2022 1 hour ago, Horse Newbie said: source for the little square rubber bumpers Ace has them ...in the isle with the furniture pads & sliders. they have them in 1/2 square also. https://www.acehardware.com/departments/home-and-decor/cabinet-and-furniture-hardware/protective-furniture-pads/52728 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,846 #933 Posted March 7, 2022 Or just but a dab of silicone caulk in a spot or two… done. 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #934 Posted March 7, 2022 5 hours ago, SylvanLakeWH said: Or just but a dab of silicone caulk in a spot or two… done. I would be in agony waiting for it to dry… probably will check out Ace Hardware for the stick on squares… 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #935 Posted March 7, 2022 (edited) Sanded a little on the foot boards tonight after work… Edited March 8, 2022 by Horse Newbie 2 4 Share this post Link to post Share on other sites
SylvanLakeWH 29,846 #936 Posted March 8, 2022 19 minutes ago, Horse Newbie said: I would be in agony waiting for it to dry… probably will check out Ace Hardware for the stick on squares… Couple dots put em on wet… no harm and they will reduce vibration…! 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #937 Posted March 8, 2022 33 minutes ago, SylvanLakeWH said: they will reduce vibration Won’t be no vibration… it has a Briggs… 5 Share this post Link to post Share on other sites
SylvanLakeWH 29,846 #938 Posted March 8, 2022 5 minutes ago, Horse Newbie said: Won’t be no vibration… it has a Briggs… Oh that’s right… engine no runny engine no vibratey… 5 Share this post Link to post Share on other sites
WHX?? 53,349 #939 Posted March 8, 2022 I like what yer doing Newbie but at 38 pages are we workin on somthing EB has got conjured up? 'At's alright if if weren't for the jib jabber but that's what makes it all enjoyable! Wished I had tunnel vision at times like @Achto has and would have that giterdone mentalitiy ! Enjoy your project and keep us posted! 2 3 Share this post Link to post Share on other sites
ebinmaine 75,772 #940 Posted March 8, 2022 3 minutes ago, WHX?? said: are we workin on somthing EB has got conjured up? Got a loooooonngg way to catch up. 3 Share this post Link to post Share on other sites
SylvanLakeWH 29,846 #941 Posted March 8, 2022 Just now, ebinmaine said: Got a loooooonngg way to catch up. I’d say there’s a colossal difference… 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #942 Posted March 8, 2022 5 minutes ago, WHX?? said: I like what yer doing Newbie but at 38 pages are we workin on somthing EB has got conjured up? 'At's alright if if weren't for the jib jabber but that's what makes it all enjoyable! Wished I had tunnel vision at times like @Achto has and would have that giterdone mentalitiy ! Enjoy your project and keep us posted! I thought about how long the thread was today… I sand two pieces and post it …thought maybe I should save up some progress and post more per post… I did predict that I would finish the Work Horse in 50 pages though… still a possibility since I’m painting body panels now… 3 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #943 Posted March 8, 2022 See this jibber is taking up valuable space ! But I don’t mind it a bit . I need to do a “progress” type thread instead of a “reveal” type, because I need help and advice along the way. At the same time I see why others here like a “reveal”. 2 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #944 Posted March 8, 2022 I started this in October…Eb started Colossus in August 2019 ! However I do realize his is a custom from scratch project, and mine is take apart, and reassemble… 2 1 Share this post Link to post Share on other sites
WHX?? 53,349 #945 Posted March 8, 2022 You do what you want Newbie your thread and we'll back ya. Truth be told a Work Horse was never a bucket lister for me anyway but every time I see @c-series don 's and the history behind it get the hebbe jeses and thinkin if one come my way....so I err... we appreciate what yer doin. Me thinks you are doing a bit more than a mechanical resto and that's a great thing! 3 2 1 Share this post Link to post Share on other sites
ebinmaine 75,772 #946 Posted March 8, 2022 9 minutes ago, Horse Newbie said: See this jibber is taking up valuable space ! But I don’t mind it a bit . I need to do a “progress” type thread instead of a “reveal” type, because I need help and advice along the way. At the same time I see why others here like a “reveal”. Agreed on all counts. 6 minutes ago, Horse Newbie said: I started this in October…Eb started Colossus in August 2019 ! However I do realize his is a custom from scratch project, and mine is take apart, and reassemble… Spare parts/spare time build for me. It'll get done.... Whenever.... 👍 2 Share this post Link to post Share on other sites
WHX?? 53,349 #947 Posted March 8, 2022 20 minutes ago, Horse Newbie said: See this jibber is taking up valuable space ! Nope ... the jibber is included with with the price of supporter.... keep at it! Yer a freak of nature EB but we'll put up with ya 3 Share this post Link to post Share on other sites
ebinmaine 75,772 #948 Posted March 8, 2022 8 minutes ago, WHX?? said: Yer a freak of nature EB Ok yeah ya caught me... 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,846 #949 Posted March 8, 2022 22 minutes ago, WHX?? said: Yer a freak of nature EB but we'll put up with ya 14 minutes ago, ebinmaine said: Ok yeah ya caught me... Off topic sorta, but… Stolen images from BBT’s camera… Colossus has evolved in a different direction… 4 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #950 Posted March 12, 2022 Got the backside and underneath of the side panels and footboard’s sanded and primed… painted the underside of the Work Horse seat pan with Rustoleum Smoke Gray… getting closer to riding ! 2 8 Share this post Link to post Share on other sites
