chev0545 238 #1 Posted October 2, 2021 tractor starts by turning on the key Share this post Link to post Share on other sites
lynnmor 8,827 #2 Posted October 2, 2021 I guess you somehow connected the power to the starter solenoid to the run position of the switch. 1 Share this post Link to post Share on other sites
chev0545 238 #3 Posted October 3, 2021 where would i start Share this post Link to post Share on other sites
Handy Don 16,601 #4 Posted October 3, 2021 What has r 1 hour ago, chev0545 said: where would i start What have you recently changed? 1 Share this post Link to post Share on other sites
chev0545 238 #5 Posted October 3, 2021 1 hour ago, Handy Don said: What has r What have you recently changed? put a new fuse block on,it worked fine then yesterday it started acting up Share this post Link to post Share on other sites
lynnmor 8,827 #6 Posted October 4, 2021 I would start at the ignition switch. You should only have voltage at the start terminal when the switch is turned completely clockwise. 1 Share this post Link to post Share on other sites
Handy Don 16,601 #7 Posted October 4, 2021 if you disconnected wires on the ignition switch when you changed the fuse block, the you most likely put the wires back on the wrong terminals. 1 Share this post Link to post Share on other sites
chev0545 238 #8 Posted October 4, 2021 for some reason it's working like it should. Share this post Link to post Share on other sites
cleat 8,979 #9 Posted October 4, 2021 Good to hear. Always good when you fix up the wire harness and then everything works properly. The 520's get a bad rap for wiring issues but with a properly maintained harness there is no problem. 2 Share this post Link to post Share on other sites
