grinchsr 674 #1 Posted October 1, 2021 (edited) I have a model 79301 rear bagger with a noisy blower shaft bearing. Has anyone sourced the bearings on that shaft from any where other than Toro who wants around $60. Toro #251-288 Edited October 1, 2021 by grinchsr Share this post Link to post Share on other sites
peter lena 10,091 #2 Posted October 1, 2021 @grinchsr , visible # on that bearing ? internet source that , if you get a chance to get a bearing with wide rubber side seals , you could easily convert it over to better hi temp grease , no noise or failures . done that to all my bearing replacements . pete Share this post Link to post Share on other sites
grinchsr 674 #3 Posted October 1, 2021 Hi Pete No visible number on that bearing at least not on the outside. I will have to rip into it tomorrow. I was trying to get the bearings here before I broke it down. I too have saved some bearings with rubber seals with the grease needle thing. These bearings are sealed, Now I have some thing to do tomorrow besides cut my lawn. Share this post Link to post Share on other sites
cleat 9,380 #4 Posted October 2, 2021 Blower bearings 251-288 RA012RRB YET204-012 AEL204-012 That should help. 1 Share this post Link to post Share on other sites
grinchsr 674 #5 Posted October 2, 2021 Yes it helps a lot and thanks. I removed the old bearings cleaned them up and could not find a number on them at all. Share this post Link to post Share on other sites
