Shuboxlover 480 #1 Posted September 9, 2021 Does anyone know if a bearing plate from a Kohler K321 (14 HP) will fit on a Kohler K301 (12 HP)? Thanks in advance Tyson Share this post Link to post Share on other sites
953 nut 59,921 #2 Posted September 9, 2021 (edited) Not all K301s and K 321s are created equal. Got to check the size of the flywheel, are both starter equipped or is the K301 S/.G equipped?. If they were both from they should work but I would check the Spec. #s against the Kohler parts manual first. Edited September 9, 2021 by 953 nut fat finger 1 Share this post Link to post Share on other sites
squonk 43,799 #3 Posted September 9, 2021 I have a K341 and a K 321 plate here I can look at. Both off of non start gen models. Share this post Link to post Share on other sites
Shuboxlover 480 #4 Posted September 10, 2021 Thanks guys, both of these motors have a starter...NOT a starter generator. The 14hp is from a GT-14 and the 12HP is from a C-120. I'm hoping for a direct swap. Share this post Link to post Share on other sites
squonk 43,799 #5 Posted September 10, 2021 I'm pretty sure it will work. Share this post Link to post Share on other sites
Shuboxlover 480 #6 Posted September 10, 2021 Thank you! Share this post Link to post Share on other sites
pfrederi 18,666 #7 Posted September 10, 2021 I would check the spec# of the engines first. 12 hp used 4615603 235354 235998 4515602 14 hp use 4615603 and 4515602 are the differences are significant who knows.. Share this post Link to post Share on other sites
squonk 43,799 #8 Posted September 10, 2021 (edited) These are the 2 I have. I think the one on the right was off of an older K301. Has the rear timing hole. The other is off of a K341. Has the 4 holes for the stator. Physically they are the same size. If you need either of these you can have them CHEEP! Edited September 10, 2021 by squonk Share this post Link to post Share on other sites
pfrederi 18,666 #9 Posted September 10, 2021 If the recipient engine is a breakerless looks like he would need the one on the left. Share this post Link to post Share on other sites
squonk 43,799 #10 Posted September 10, 2021 Plate on my rebuilt K321 pretty much identical to the one on the left. Share this post Link to post Share on other sites
pfrederi 18,666 #11 Posted September 10, 2021 Breakerless trigger needs the mounting points. (Would have to be drilled and tapped.) Share this post Link to post Share on other sites
Shuboxlover 480 #12 Posted September 10, 2021 Both of the engines (donor and recipient) have points. Thanks 1 Share this post Link to post Share on other sites
