Dlevin 3 #1 Posted September 9, 2021 I just purchased a 312 8 with a 36" mower deck with a bagger attachement. There are two different blades on it. What are the correct replacement blades for this deck? Thanks for any information. Share this post Link to post Share on other sites
stevasaurus 23,456 #2 Posted September 9, 2021 @gwest_ca has a PDF showing the correct blades for mower decks. It's probably in the "Manuals" Section. I am not sure where it is. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,753 #3 Posted September 9, 2021 Most likely listed with the bagger if the blades are different. How many blades are on the mower? If just 2 blades it is a 37" width of cut mower. 3 blades would make it 36" width of cut. Garry Share this post Link to post Share on other sites
clueless 3,325 #4 Posted September 9, 2021 If it has the bagger it's should be a 37" deck with two blades. The right blade (sitting on the tractor) is different then the left, it should have some wings attached to it. If you are going to use the bagger then you need that blade. Share this post Link to post Share on other sites
Dlevin 3 #5 Posted September 9, 2021 Thanks for the replies. It has two blades on it, one with wings. Each blade measures 18 1/2 inches. The right blade, sitting on the tractor has wings, the left is just a blade. Any source for replacements? 1 Share this post Link to post Share on other sites
clueless 3,325 #6 Posted September 9, 2021 Your deck is Toro # 0537SC01, your bagger is Toro 0711BC01, if you google parts for the deck number it will give you the blade numbers with out the bagger. When you google the bagger number you will get the part number for the blade with wings. The part number for the blade kit for the bagger is Toro 115084, the right blade is Toro 115083. You may want to be sitting down when you see the price, but if you planing using the bagger, it's worth it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,753 #7 Posted September 9, 2021 More research is required unless I looked up the wrong info because these numbers are different Click on the fuzzy picture in the link. Neither of these blades are available from Toro. The size of bagger is different than what clueless posted. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,753 #8 Posted September 9, 2021 Here are the baggers that use the 112398 blade set - 1986-1988 (No longer available from Toro but Pat's still shows them) https://www.wheelhorseforum.com/search/?&q=112398&type=downloads_file&search_and_or=or&sortby=relevancy Pat's https://www.psep1.biz/arinet.asp#/s/TO/bc/112398//1/ Here are the baggers that use the 115084 blade set - 1989-1998 (Still available from Toro) https://www.wheelhorseforum.com/search/?&q=115084&type=downloads_file&search_and_or=or&sortby=relevancy Pat's https://www.psep1.biz/arinet.asp#/s/TO//115084//1/ Share this post Link to post Share on other sites
