RandyLittrell 3,944 #1 Posted September 9, 2021 I pulled out my old parts washer which must be pushing 15 years old and I haven't used it since before I moved into this shop. It still had a 1/2" of solvent in it! I moved here 6 years ago and its been sitting in the shed ever since! Best part is it still works! I really thought I might need a new pump, but she is purring right along! 8 4 1 Share this post Link to post Share on other sites
lynnmor 8,680 #2 Posted September 9, 2021 4 hours ago, RandyLittrell said: I pulled out my old parts washer which must be pushing 15 years old and I haven't used it since before I moved into this shop. It still had a 1/2" of solvent in it! I moved here 6 years ago and its been sitting in the shed ever since! Best part is it still works! I really thought I might need a new pump, but she is purring right along! Most of what I own is older than that. 2 Share this post Link to post Share on other sites
JoeM 9,672 #3 Posted September 9, 2021 Anyone tried the water based parts solvent like the ZEP stuff? Share this post Link to post Share on other sites
pacer 3,179 #4 Posted September 9, 2021 I have ,,,, a 'look alike' in one, must be 25yrs old! So old that it would pump mineral spirits - Varsol (my favorite) and others like diesel, kerosene, etc. and I used it a LOT! But, it was plastic and eventually cracked. I suppose HF realized this as a problem and started using metal tubs, so I just went and got a metal tub one .... Within days the pump quit working ... hmmm, took it back and they exchanged it -- done the same thing. So I (finally!) read the directions and sure nuff says "do not use mineral spirits" (you might blow yourself up, thank you OSHA, Ralph Nader) So I try one of the "safe' cleaners (dont remember which) and what a joke, was useless! Still had the cracked tub with the pump that still worked ... soooo using my 'cobbling together' knowledge, I mounted the old pump in the new metal tub --- Viola! worked like a champ with Varsol and in fact is in use til this day, dern handy tool! 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #5 Posted September 9, 2021 1 hour ago, JoeM said: Anyone tried the water based parts solvent like the ZEP stuff? I have not, thought about it though. 11 minutes ago, pacer said: "do not use mineral spirits" That is exactly what I am using and pretty sure that is what had been in the bottom of it for the last 10 years. Mine must be old enough!! Randy Share this post Link to post Share on other sites
WHX?? 55,673 #6 Posted September 9, 2021 1 hour ago, JoeM said: Anyone tried the water based parts solvent like the ZEP stuff? I did once Joe and didn't like it. It turned AL parts black if you soaked it too long and just didn't cut crud and grease like mineral spirits does. And I had a five gallon bucket of the stuff. It worked good thru the pressure washer tho. Thanks for reminding me I need to clean it one of these days Randy.. rather have root canal tho! 2 Share this post Link to post Share on other sites
JoeM 9,672 #7 Posted September 9, 2021 (edited) I have a five gallon can of mineral based cleaner and kind of recycle it in an oil drain tub just using a brush. works ok I don't dump it back into the original can but put it in a container as used. I use the used stuff first then if needed use the new to finish up. I have one of those plastic portable ones and it requires water based. I have not used it yet. Wonder if one of those cheap diesel fuel pumps would work good enough with the solvent? Edited September 9, 2021 by JoeM 2 Share this post Link to post Share on other sites
WHX?? 55,673 #8 Posted September 9, 2021 Very similar to the water based stuff I used here Who you callin frugal Joe! 60 bucks a can! I drain it back to the original can thru a funnel and cheese cloth to get the old gasket material, metal bits & red paint flakes out. I tried frying oil filters and worked but talk about a mess! Let it set for a couple of weeks so the crud goes to the bottom of the can then after wiping out the washer .... yep root canal ther Carefully dump it back in so as not to disturb the crap in the bottom of the can & leave some of the nasty stuff in the can. Add new as needed. 13 hours ago, RandyLittrell said: 6 years ago and its been sitting in the shed ever since! ? here Randy .... how did you get by so long without needing it!! Share this post Link to post Share on other sites
RandyLittrell 3,944 #9 Posted September 9, 2021 (edited) 49 minutes ago, WHX?? said: ? here Randy .... how did you get by so long without needing it!! My Grandson was born 6 years ago, so that played a part! Multiple surgeries and going on disability during this time as well. Dad passed 12 years ago and Mom decided to sell the place in the country the same month my Grandson was born. Dad had a 36x50 shop and a couple of outbuildings. Mom's place sold the first day and I had 30 days to do something with a lot of stuff!! I got lucky and bought a lot that had a double car garage on it, 24x24 for cheap money but had to put 10 pounds of you know what in a 5 pound building. It has taken me this long, to get where I get actually work on tractors instead of just fixing things as they broke! Life likes to throw punches and I'm just bobbin and weavin!!! Randy Edited September 9, 2021 by RandyLittrell 1 Share this post Link to post Share on other sites
pfrederi 20,049 #10 Posted September 9, 2021 I have an almost 20 yr old harbor freight 20 gal metal parts washer. i use GUNK S-C Super Concentrate de-greaser. 1:10 with Kerosene Works good smells bad. I really have to clean mine out. Dropped a part and had to go fishing for it there must be 2" of sludge on the bottom....been several years since i did it.. 1 Share this post Link to post Share on other sites
squonk 45,789 #11 Posted September 9, 2021 Fishing out a part! You haven't lived until you had to fish out a Quadrajet metering rod from the bottom of a 15 gallon Safety Klean carb cleaning machine. And the cleaner was brand new and potent. My arm looked like a prune for a month! 1 Share this post Link to post Share on other sites
aemsee 93 #12 Posted September 10, 2021 8 hours ago, squonk said: Fishing out a part! You haven't lived until you had to fish out a Quadrajet metering rod from the bottom of a 15 gallon Safety Klean carb cleaning machine. And the cleaner was brand new and potent. My arm looked like a prune for a month! that old organic solvent in those carb cleaner buckets was toxic as hell....but it sure worked great Share this post Link to post Share on other sites
