upstateyankee50 59 #1 Posted September 8, 2021 first of all I want to thank the ones that did reply and offer there thoughts as to why the carb is acting up; the thing is I can not get it to fire up ;the gas flow to the carb flows like a river so the pump is fine ;the inline filter was checked and it is clan as it is one of there glass types where you can see the fuel and it is clean ;taking out the spark plug it is dry where it at least should be wet from gas ;even trying to prime the carb it still will not fire up besides at times I can hear a snap might be from the starter but I am not sure so to be safe I walked away as not to end up with a bad motor ;the dealer where it was taken a week ago Tuesday told me he would check it out yesterday well around 3-O- clock yesterday my daughter and son went with me to check it out well the tractor was just sitting where it was taken off so we loaded it on the truck and off we went ;there is no reason to let it sit any longer and really not knowing when it will be looked at ;so it is here where it belongs ;the pitch of the loading ramps were at a 90 degree angle going up and no way could be push it that up that height so putting the forward control in forward as being an automatic I let the motor creep its way up the steep incline ;good things the batter was new ;not a word was spoken from the mechanic so again off we went so now I am trying to go alone here and figuring out where to go ;in the ears there are a few repair shops but due to the virus they have closed ;as far as setting the adjustments it would hard as it won't start to even get it warmed up 'so again any thought sure would be appreciated ;thanks everyone Share this post Link to post Share on other sites
ebinmaine 79,737 #2 Posted September 8, 2021 Can you post some pics of the tractor, engine, and carb so we can see what we're up against? I'm thinking you'll be in need of a carb rebuild to start. 1 Share this post Link to post Share on other sites
Ed Kennell 46,617 #3 Posted September 9, 2021 I may have missed part of the story, but do you have a good spark at the plug? 1 Share this post Link to post Share on other sites
Gregor 4,848 #4 Posted September 9, 2021 (edited) 10 hours ago, upstateyankee50 said: I let the motor creep its way up the steep incline I don't quite get this. Did the motor start? Are we in fact dealing with a Tecumseh 10 HP? I don't know if the HH100 has Automatic Compression Release or not, but did you check for any compression at all? Pull the plug, and hold your thumb over the hole while cranking. Any compression? I guess that answers that. Edited September 9, 2021 by Gregor 2 Share this post Link to post Share on other sites
Achto 32,110 #5 Posted September 9, 2021 Like @Gregor said. If you have fuel getting to the carburetor but your spark plug remains dry, then I would suspect either a clogged main jet, clogged emulsion tube, or no compression. No compression would mean that there is nothing to suck the fuel air mixture into the cylinder. Things to check 1. Does the engine seem to turn over really easy? Turn the engine by hand, you should feel resistance as it reaches the compression stroke. 2. Remove the air cleaner and hold you hand over the carburetor while turning the engine over, you should feel suction at the carb. 3. Remove the spark plug & hold your finger over the hole while turning the engine over. You should feel pressure trying to blow your finger off from the hole. If you find that you don't have compression, then it's time to pull the cylinder head off and see what happened. Hole in the piston, broken rod, or a valve stuck open. 3 Share this post Link to post Share on other sites
WHX?? 57,468 #6 Posted September 9, 2021 Does it start or run with full choke? Does it run if you hand feed it? Might be something as simple as a stuck float/inlet valve. Do the compression test as outlined above and if it passes a good old fashioned carb cleaning is in order. 1 Share this post Link to post Share on other sites
Ed Kennell 46,617 #7 Posted September 9, 2021 16 hours ago, upstateyankee50 said: I can not get it to fire up ; 16 hours ago, upstateyankee50 said: trying to prime the carb it still will not fire If it does not ignite when you spray fuel into the carb, You do not have spark or the intake valve is not opening. 1 Share this post Link to post Share on other sites
WHX?? 57,468 #8 Posted September 9, 2021 16 hours ago, upstateyankee50 said: ;even trying to prime the carb Thank you Ed I missed that..... Share this post Link to post Share on other sites
upstateyankee50 59 #9 Posted September 9, 2021 19 hours ago, ebinmaine said: Can you post some pics of the tractor, engine, and carb so we can see what we're up against? I'm thinking you'll be in need of a carb rebuild to start. i did have the carb rebuilt but I am not sure if the shop did put a new kit in to it; I did buy a brand new carb for it from a dealer here and he said it is the correct one for this motor ;well after installing that one the tractor still wouldn't start even when primed ;so that is when I decided to have a repair shop rebuild the one that came on the motor ; lME-29 Share this post Link to post Share on other sites
upstateyankee50 59 #10 Posted September 9, 2021 10 hours ago, Gregor said: I don't quite get this. Did the motor start? Are we in fact dealing with a Tecumseh 10 HP? I don't know if the HH100 has Automatic Compression Release or not, but did you check for any compression at all? Pull the plug, and hold your thumb over the hole while cranking. Any compression? I guess that answers that. yes it is a 10 horse Tecumseh motor and I do have spark plus compression ;odd that I always started up every time but when I wanted to mow the yard a few weeks back that is when I had issues as it wouldn't start even with priming it ;it wanted to start but that is all ;it has the electronic ignition and I was concerned if I tried to crank it so many time the ignition would had burnt out so I replaced the carb with a brand new one from a dealer and he told me it is the correct carb for this motor ; Share this post Link to post Share on other sites
upstateyankee50 59 #11 Posted September 9, 2021 6 hours ago, Achto said: Like @Gregor said. If you have fuel getting to the carburetor but your spark plug remains dry, then I would suspect either a clogged main jet, clogged emulsion tube, or no compression. No compression would mean that there is nothing to suck the fuel air mixture into the cylinder. Things to check 1. Does the engine seem to turn over really easy? Turn the engine by hand, you should feel resistance as it reaches the compression stroke. 2. Remove the air cleaner and hold you hand over the carburetor while turning the engine over, you should feel suction at the carb. 3. Remove the spark plug & hold your finger over the hole while turning the engine over. You should feel pressure trying to blow your finger off from the hole. If you find that you don't have compression, then it's time to pull the cylinder head off and see what happened. Hole in the piston, broken rod, or a valve stuck open. thanks and I really never thought of a few things that you suggested ; the engine does turn over really easy I did remove the plug and tested for spark as I was turning it over I could fell the compression 'yes and my last thought was to remove the head off and check the valves ;I will let you know and for sure I do hope that I don't have a busted rod as odd it has always started great before this issue Share this post Link to post Share on other sites
ebinmaine 79,737 #12 Posted September 9, 2021 It's important to keep in mind that you should never ever assume a new part is a working part. Every manufacturer in every industry all around the world has an acceptable defect level. You say you've replaced the carburetor and that your dealer claims it's the correct one. Where was it made? How old is it? Is it gummed up? Is it ACTUALLY letting the gas go through it? How are you testing for spark? Are you using an external spark plug tester that allows you to leave the spark plug in the engine as it should be? Share this post Link to post Share on other sites
upstateyankee50 59 #13 Posted September 9, 2021 5 hours ago, WHX?? said: Does it start or run with full choke? Does it run if you hand feed it? Might be something as simple as a stuck float/inlet valve. Do the compression test as outlined above and if it passes a good old fashioned carb cleaning is in order. no it will not start on full choke at times it seems it wants to start but won't ;even priming it rather hand feed still nothing ;I did have the carb rebuilt by a dealer but who knows if he really replaced any thing 15 hours ago, Ed Kennell said: I may have missed part of the story, but do you have a good spark at the plug? Share this post Link to post Share on other sites
upstateyankee50 59 #14 Posted September 9, 2021 15 hours ago, Ed Kennell said: I may have missed part of the story, but do you have a good spark at the plug? yes plenty of spark Share this post Link to post Share on other sites
upstateyankee50 59 #15 Posted September 9, 2021 4 hours ago, Ed Kennell said: If it does not ignite when you spray fuel into the carb, You do not have spark or the intake valve is not opening. yep that was my next thought the intake is stuck I am going to remove the hard today and check things out and hope it isn't a serious issue ;thanks for the imput Share this post Link to post Share on other sites
upstateyankee50 59 #16 Posted September 9, 2021 10 minutes ago, ebinmaine said: It's important to keep in mind that you should never ever assume a new part is a working part. Every manufacturer in every industry all around the world has an acceptable defect level. You say you've replaced the carburetor and that your dealer claims it's the correct one. Where was it made? How old is it? Is it gummed up? Is it ACTUALLY letting the gas go through it? How are you testing for spark? Are you using an external spark plug tester that allows you to leave the spark plug in the engine as it should be? yes you are correct about assuming but I do go buy what the dealer says as far as being the correct carb for it where was it made well there are no markings or numbers on the carb the new on that is 'it looks brand new with the instructions ;as far as your next question all I can tell is that the bowel gets full 'the tester is an external tester as leaving the plug in the engine I as well replaced the plug but that didn't help either ;thanks for the input and I will let everyone know once I pull the head and check the valves if they are opening and closing as they should ; Share this post Link to post Share on other sites
upstateyankee50 59 #17 Posted September 9, 2021 12 minutes ago, upstateyankee50 said: no it will not start on full choke at times it seems it wants to start but won't ;even priming it rather hand feed still nothing ;I did have the carb rebuilt by a dealer but who knows if he really replaced any thing yes the plug was replaced and still the same issue Share this post Link to post Share on other sites
upstateyankee50 59 #18 Posted September 9, 2021 2 hours ago, upstateyankee50 said: thanks and I really never thought of a few things that you suggested ; the engine does turn over really easy I did remove the plug and tested for spark as I was turning it over I could fell the compression 'yes and my last thought was to remove the head off and check the valves ;I will let you know and for sure I do hope that I don't have a busted rod as odd it has always started great before this issue 8 hours ago, Achto said: Like @Gregor said. If you have fuel getting to the carburetor but your spark plug remains dry, then I would suspect either a clogged main jet, clogged emulsion tube, or no compression. No compression would mean that there is nothing to suck the fuel air mixture into the cylinder. Things to check 1. Does the engine seem to turn over really easy? Turn the engine by hand, you should feel resistance as it reaches the compression stroke. 2. Remove the air cleaner and hold you hand over the carburetor while turning the engine over, you should feel suction at the carb. 3. Remove the spark plug & hold your finger over the hole while turning the engine over. You should feel pressure trying to blow your finger off from the hole. If you find that you don't have compression, then it's time to pull the cylinder head off and see what happened. Hole in the piston, broken rod, or a valve stuck open. well again; I put the thumb over the plus hole and I had a lot of compression than putting my hand over the mouth of the carb it sucked my hand plus my hand was covered in gas ;then I removed the head and both valves are working properly as both going up and down as far as the emulsion it was clear as when blowing though the tube I can hear air through the carb; so it seems the repair shop really didn't rebuild the carb just a fast cleaning ;I did chat with the dealer who sold me the new one he says it is the correct carb for the 10 horse and there is no way he will give back the 103 plus for it ;if that carb was the correct one the engine should had started as I didn't mess with any adjustments nor on the one that came with the 10 horse ;so now to get a kit and try to fix it myself ;to all that replied with there thoughts and help I sure do appreciate it ;in the future once I get the old girl running I for sure will let you know again thanks so much guys ; Share this post Link to post Share on other sites
ebinmaine 79,737 #19 Posted September 9, 2021 Given that your hand is covered in gas the carb may not be the entire problem. That tells you it's at least getting into the bowl and up the tubes. Engine runs if you SPRAY gas in it? Share this post Link to post Share on other sites
upstateyankee50 59 #20 Posted September 9, 2021 6 hours ago, Ed Kennell said: If it does not ignite when you spray fuel into the carb, You do not have spark or the intake valve is not opening. I did the hand test over the spark plug hole and had lots of pressure as well as placing my hand over the front of the carb and it sucked my hand in plus my hand was covered in gas ;than removing the head both valves are opening and shutting so it seems the repair shop just gave it a once over and really didn't rebuilt it with new parts ;lesson learned as not to trust anyone ;thanks for the input and I will let you know what happens Share this post Link to post Share on other sites
upstateyankee50 59 #21 Posted September 9, 2021 Just now, ebinmaine said: Given that your hand is covered in gas the carb may not be the entire problem. That tells you it's at least getting into the bowl and up the tubes. Engine runs if you SPRAY gas in it? yes that is true and no it will not run even with a spray Share this post Link to post Share on other sites
Gregor 4,848 #22 Posted September 9, 2021 Starting to look like a possible timing issue. 1 Share this post Link to post Share on other sites
ebinmaine 79,737 #23 Posted September 9, 2021 10 minutes ago, upstateyankee50 said: yes that is true and no it will not run even with a spray I'm thinking your carb is fine. Other issues..... 1 Share this post Link to post Share on other sites
upstateyankee50 59 #24 Posted September 9, 2021 4 minutes ago, ebinmaine said: I'm thinking your carb is fine. Other issues..... yep could be but what else to look for Share this post Link to post Share on other sites
upstateyankee50 59 #25 Posted September 9, 2021 7 minutes ago, Gregor said: Starting to look like a possible timing issue. that could be but that is one thing that I never had done Share this post Link to post Share on other sites
