chipwitch 73 #1 Posted September 5, 2021 Okay, so this is a question about the machine key that transmits torque to the clutch plate. It's Labor Day weekend, and virtually every business in my sleepy little town left early Friday for the holiday. So... As some of you may know, I received a 16hp replacement engine for my C-165 and didn't have the sleeve adapter to go from a 1" engine shaft to a 1-1/8" sheave. No one in town was open but I considered myself lucky to find one on Amazon for 12 bucks and they would deliver it the next day... Sunday... Labor Day weekend!!! SMH. The package arrived today but unfortunately, the key they sent is the wrong size (3/16") and the slot in the sleeve is 0.230 inches. What crap. The OD and ID are "probably" acceptable. Both seem a tad loose. Anyway, I don't have the proper keystock. I have 1/4" square which is fine except the sleeve adapter adds 1/16" to the keyway between the shaft and sheave. Ideally, I would use a 1/4" x 5/16". I also have some woodruff keys. Of course the roundness means that there is less cross section in the shear direction than ideal. The ones I have are pretty long but fall about 3/16" shy of full length engagement of the sheave. I'm thinking if I grind the height of the woodruff key down to 5/16" I'm probably good to go. Just wanted to run it past y'all first to see what you thought. Share this post Link to post Share on other sites
kasey54 305 #2 Posted September 6, 2021 I'm no expert. I'd want to know where any"looseness" was coming from. Nothing sounds right as you have described it.. I'd check the shaft in a fashion to leave me certain it wasn't worn. Preferably with a micrometer. 2nd I'd check the bore of the PTO assembly.I'm thinking you have a very substandard shaft adapter that should be replaced with a good one. I wouldn't want more than a total of .005" of clearance between all items here, shaft, adapter, and pto. Just my $.02. I'd also want the gap in my sleeve when installed to be a bit snug on my key. Good luck. Maybe more will chime in. Share this post Link to post Share on other sites
kasey54 305 #3 Posted September 6, 2021 What brand is your replacement engine? Any chance its a metric shaft? 1 Share this post Link to post Share on other sites
chipwitch 73 #4 Posted September 6, 2021 10 minutes ago, kasey54 said: What brand is your replacement engine? Any chance its a metric shaft? It's a Carroll Stream Rhino Share this post Link to post Share on other sites
kasey54 305 #5 Posted September 6, 2021 i've never heard of it. Share this post Link to post Share on other sites
kasey54 305 #6 Posted September 6, 2021 Google says its 1 inch ,good sofar. Share this post Link to post Share on other sites
953 nut 64,126 #7 Posted September 6, 2021 You probably need some "STEP KEYSTOCK" for this application. 1 1 Share this post Link to post Share on other sites
chipwitch 73 #8 Posted September 6, 2021 6 minutes ago, 953 nut said: You probably need some "STEP KEYSTOCK" for this application. No, both the sheave and shaft are 1/4" 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #9 Posted September 6, 2021 4 hours ago, chipwitch said: No, both the sheave and shaft are 1/4" You don't have any steel laying around, do you chip? I... always make my own... using 316 stainless... Don Share this post Link to post Share on other sites
Snoopy11 5,731 #10 Posted September 6, 2021 4 hours ago, chipwitch said: No, both the sheave and shaft are 1/4" You... know that you can also buy them at auto parts stores... usually... Chip... Don Share this post Link to post Share on other sites
Snoopy11 5,731 #11 Posted September 6, 2021 4 hours ago, chipwitch said: No, both the sheave and shaft are 1/4" And at home improvement stores.... Don Share this post Link to post Share on other sites
chipwitch 73 #12 Posted September 6, 2021 4 minutes ago, Snoopy11 said: You... know that you can also buy them at auto parts stores... usually... Chip... Don Ha! Not where I live! LOL... Podunk. I'm sure they can order them, but O'Reilleys and Advance didn't know what I was talking about. My Napa guy is real good, he'd know exactly what I was talking about but would probably have to order it. Still, he took the weekend off. So... here I am... unable to mow my lawn. Share this post Link to post Share on other sites
Snoopy11 5,731 #13 Posted September 6, 2021 2 minutes ago, chipwitch said: Ha! Not where I live! LOL... Podunk. I'm sure they can order them, but O'Reilleys and Advance didn't know what I was talking about. My Napa guy is real good, he'd know exactly what I was talking about but would probably have to order it. Still, he took the weekend off. So... here I am... unable to mow my lawn. I'd end up going to walmart, buying a hatchet and cutting one out of the steel hatchet. yes, I improvise where I can... What happened to... ⬇ 18 hours ago, chipwitch said: I'm thinking if I grind the height of the woodruff key down to 5/16" I'm probably good to go. Don Share this post Link to post Share on other sites
Handy Don 15,947 #14 Posted September 6, 2021 33 minutes ago, chipwitch said: So... here I am... unable to mow my lawn. Lesson: Take. The. Day. Off. The lawn will be there tomorrow or the next day! 1 Share this post Link to post Share on other sites
pacer 3,179 #15 Posted September 6, 2021 That is one area where you absolutely DO NOT want ANY slack!! That why so often when you need to remove a key you very often have to give them some .... help? getting them prized out of the slot. I have had instances where I have mangled the key so badly it wasnt reusable. The slightest bit of slop in there will RAPIDLY beat out the pocket and the piece on it. Wheel hubs are notorious for this.... Share this post Link to post Share on other sites
chipwitch 73 #16 Posted September 6, 2021 2 hours ago, Snoopy11 said: What happened to... ⬇ Don I ground down a woodruff key Just figured out how I'm doing the mount. I needed to figure out how to do it with what I have on hand. I think I'm all set now. I hope to have the mount done today. Share this post Link to post Share on other sites
Snoopy11 5,731 #17 Posted September 6, 2021 43 minutes ago, chipwitch said: I ground down a woodruff key Just figured out how I'm doing the mount. I needed to figure out how to do it with what I have on hand. I think I'm all set now. I hope to have the mount done today. Share this post Link to post Share on other sites
pfrederi 19,887 #18 Posted September 6, 2021 3 hours ago, pacer said: That is one area where you absolutely DO NOT want ANY slack!! That why so often when you need to remove a key you very often have to give them some .... help? getting them prized out of the slot. I have had instances where I have mangled the key so badly it wasnt reusable. The slightest bit of slop in there will RAPIDLY beat out the pocket and the piece on it. Wheel hubs are notorious for this.... Just take a look at this new post showing what happens when a key fails... Share this post Link to post Share on other sites
Gregor 4,847 #19 Posted September 6, 2021 (edited) 5 hours ago, Snoopy11 said: So... here I am... unable to mow my lawn. A perfect excuse to buy another Edited September 6, 2021 by Gregor Share this post Link to post Share on other sites
kpinnc 17,158 #20 Posted September 7, 2021 I'm thinking Chip needs to put up some pictures. I for one, need motivation! I have some of the correct key stock if you can't find it. I have a stainless sleeve on one of my tractors too. You only need about a 3/4 inch peice of key stock. The sleeve should be very tight. I had to use a mallet just to get mine onto the shaft. Share this post Link to post Share on other sites
Gregor 4,847 #21 Posted September 7, 2021 15 minutes ago, kpinnc said: I had to use a mallet just to get mine onto the shaft. I also have one of those sleeves, and it is VERY tight. I was afraid to hammer it on. Share this post Link to post Share on other sites
