SylvanLakeWH 28,846 #51 Posted July 10, 2022 (edited) I have a deck for my “new” E 141 that I might be persuaded to part with. I don’t think I will ever use it. Works perfectly. Has all the wiring etc. Works great. Distance between us may be an issue… but stranger things have happened. It made it to Michigan from New York via Pennsylvania so… PM me to chat. Edited July 10, 2022 by SylvanLakeWH Share this post Link to post Share on other sites
uglyblue66 125 #52 Posted July 31, 2022 Well, the re soldering of solder joints on the pc board must have done the trick for sure because i took it to the High Country crankup in Boone NC and ran it from thursday after noon to saturday afternoon as I needed to get around and just for the fun of it,no issues. I let a couple folks drive it and 1 said it seemed harder to steer than most other tractors of this size and after he said it does seem a bit "tight" I just attribute it to the very low hours the machine has on it and stuff not being worn out. 1 Share this post Link to post Share on other sites
Mike in NC 342 #53 Posted August 1, 2022 (edited) Jeff, I am not sure how many miles you put on your tractor this weekend, but it was several. It ran great and was very neat to see running. If you are interested in that deck, maybe it could find a ride this way by way of the Big Show. Edited August 1, 2022 by Mike in NC 1 Share this post Link to post Share on other sites
uglyblue66 125 #54 Posted August 1, 2022 Batterys were just starting to show a bit of use by the time I broke free of the "parade of power" and headed to the trailer.Still had plenty though as I rode it around the place here looking over storm damage that happened while i was gone.Nothing serious,just alot of work to clean up. I hope to get the A-60E I think is the right numbers, going this summer as well. Share this post Link to post Share on other sites
uglyblue66 125 #55 Posted December 11, 2022 Ok. are there any tricks to freeing up the button on top of the lift lever? i have tried soaking it in Kriol, tapping it gently with a light hammer and so forth but NO go. I might want to put my front blade on just to "play " with the tractor a bit as it is the only implement I have to fit on it.But the lift lever button is stuck. Share this post Link to post Share on other sites
SylvanLakeWH 28,846 #56 Posted December 11, 2022 soak repeat tap repeat Also make sure black adjustment knob is free and loose... 1 Share this post Link to post Share on other sites
oliver2-44 10,824 #57 Posted December 11, 2022 Soak the “L” shaped rod that comes out of the bottom of the lift lever too. 1 Share this post Link to post Share on other sites
peter lena 9,330 #58 Posted December 16, 2022 @uglyblue66 referring to your lift lever , issue , look up the schematic drawing for that , looks common . remove your " shifter plate " on the console , aerosol penetrating oil with small tube extension get into the related bushing end points , also at each side of the transmission tunnel , make the rust run out . squirt into the top of lift lever , as well as all related linkage areas , typically neglected , any rust / dry spot will hang it up . notice there is no grease on your front axel spindle points , or center axel swing / mount point , typically emphasize lubrication related issues , that reinforced front axel , is so worth some green grease . would love to recover / lubricate that set up , you are looking right at it , pete 2 Share this post Link to post Share on other sites
