johnnymag3 2,635 #1 Posted August 9, 2021 (edited) Have been trying to figure out where this belt squeal type sound is coming from on a 12 HP magnum....seems to be near or behind flywheel area? Any ideas? I took off the drive belt and ran the engine with NO Drive belt and the squealing screeching is still prevalent.....Nothing at Idle...mid range and higher only it seems. Never heard a sound like this...Engine runs perfect and has 600 Hours on it...fully Serviced regularly, SAE 30 and Zinc added....no metal or filings in drain oil....Need some advice. DOES IT RIGHT FROM START UP, NO NEED TO EVEN GET IT HOT... THANKS....JOHN Edited August 9, 2021 by johnnymag3 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted August 9, 2021 Only thing I can think of is a loose magnet. Time to remove flywheel and look see. Garry 3 Share this post Link to post Share on other sites
squonk 45,536 #3 Posted August 9, 2021 (edited) Take off you shroud and remove the grass screen. look for anything that might have gotten jammed in there like a stone or stick. If it looks good put the shroud back on without the screen. If the noise is still there, I'd say the front bearing is starting to fail or like Gary said loose magnet. Edited August 9, 2021 by squonk 2 Share this post Link to post Share on other sites
Bill D 2,598 #4 Posted August 9, 2021 Yep. Pull the flywheel. 1 Share this post Link to post Share on other sites
Tuneup 1,452 #5 Posted August 9, 2021 ...or you'll find that the starter is jammed in the flywheel, Good luck! 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #6 Posted August 9, 2021 1 hour ago, Tuneup said: ...or you'll find that the starter is jammed in the flywheel, Good luck! You mean like what I had with a cheap Chinese starter from Amazon on my 520-H… 1 Share this post Link to post Share on other sites
kpinnc 17,163 #7 Posted August 9, 2021 Check to make sure that you don't have a long screw holding the shroud on. If someone put a long screw where the short ones go, they can contact the flywheel. Makes an awful racket! I know someone who did it once, but it wasn't me... 1 Share this post Link to post Share on other sites
cleat 8,735 #8 Posted August 10, 2021 When I first bought my 312H it was making a racket. Turns out it was the ignition coil rubbing the flywheel. Properly gapped it and all is well. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,635 #9 Posted August 26, 2021 So I took the entire Flywheel off, ...gapped the coil., it was already good.....Stator is not touching magnets..nothing loose or out of position....I left cooling tin off to view starter....it was perfect.....and fired up M12.....squeal seems like its on the other side of the engine....PTO? Any ideas? engine runs perfect..... Thanks, John Share this post Link to post Share on other sites
Bill D 2,598 #10 Posted August 26, 2021 How are the bearings in the PTO? The main support bearing for the PTO pulley could make a noise when the engine is running and the PTO is not engaged. Does the noise stop when the PTO is engaged? Are the belt guides on the engine rubbing the drive pulley? How is the idler pulley for the drive belt. I had a hydro making an awful noise, the idler pulley bearings were gone. Just metal on metal. Share this post Link to post Share on other sites
johnnymag3 2,635 #11 Posted August 26, 2021 I am going to take off the PTO pulley and inspect that next...Very odd sound... maybe harmonics coming from elsewhere and fooling me? With a bare engine and no pulleys or drive belts on it I will be able to isolate the sound if it is still there.....Could be something simple...if not, I will swap an engine into this Tractor as it is a real nice low hour machine....Thanks Bill for the ideas and everyone else who has sent ideas John Share this post Link to post Share on other sites
Bill D 2,598 #12 Posted August 26, 2021 2 hours ago, johnnymag3 said: I am going to take off the PTO pulley and inspect that next...Very odd sound... maybe harmonics coming from elsewhere and fooling me? With a bare engine and no pulleys or drive belts on it I will be able to isolate the sound if it is still there.....Could be something simple...if not, I will swap an engine into this Tractor as it is a real nice low hour machine....Thanks Bill for the ideas and everyone else who has sent ideas John I doubt it's the engine. Post a video if you can. I would like to hear the noise. Share this post Link to post Share on other sites
johnnymag3 2,635 #13 Posted August 27, 2021 I cant post a video....you know that silly LOL I have a flip phone HAHAHA Thank you.... Share this post Link to post Share on other sites
johnnymag3 2,635 #14 Posted August 28, 2021 Ran the engine with NOTHING on it............squeals like a bandit !!!!!!!!!! Share this post Link to post Share on other sites
