clarsona5955409 1 #1 Posted July 29, 2021 (edited) I have a Wheel Horse 416-8 with a Kholer 16 hp Motor and a 8 speed Trans. I am looking for a Transmission Belt Because mine was last replaced by my grandfather years ago. Any other info needed I would he happy to give. Thanks in advance Edited July 29, 2021 by clarsona5955409 1 Share this post Link to post Share on other sites
8ntruck 9,021 #2 Posted July 29, 2021 to the forum. Bunch of good folks here. Somebody will be along soon with an answer. You might be able to find the answer yourself in the manuals section of the forum. I think there is a list of belts there somewhere, and if you have the model number, you can probably find an owner's manual for your tractor. Good luck and have fun. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,323 #3 Posted July 29, 2021 Drive belt has been added to this page. Click on the fuzzy picture in the link. 2 Share this post Link to post Share on other sites
Lee1977 7,687 #4 Posted July 29, 2021 3 hours ago, clarsona5955409 said: I have a Wheel Horse 416-8 with a Kholer 16 hp Motor and a 8 speed Trans. I am looking for a Transmission Belt Because mine was last replaced by my grandfather years ago. Any other info needed I would he happy to give. Thanks in advance Belt no. 7473 ( 5/8" x 82") I have had good luck with the blue belts from Tractor Supply. Put one on my 520-H a year ago and it's doing great at about half the price of Toro. 1 Share this post Link to post Share on other sites
squonk 47,276 #6 Posted July 29, 2021 Napa 4L820W 1 Share this post Link to post Share on other sites
JAinVA 4,638 #7 Posted July 29, 2021 (edited) For what it's worth. I just went through this on 2 of my 418-8 tractors. The 82" belt length is for the hydros. The 416 -8 with the Kohler uses a 5/8" 83" belt and the Onan powered 416-8 uses a 5/8-84" belt. Go ahead get what the manuals say and partstree as well and let us know how this works for you The Onan is located further forward on the frame than a Kohler so it needs a longer belt Edited July 29, 2021 by JAinVA Share this post Link to post Share on other sites
JCM 11,251 #8 Posted July 30, 2021 Great info @JAinVA Share this post Link to post Share on other sites
clarsona5955409 1 #9 Posted August 2, 2021 On 7/29/2021 at 5:42 PM, JAinVA said: For what it's worth. I just went through this on 2 of my 418-8 tractors. The 82" belt length is for the hydros. The 416 -8 with the Kohler uses a 5/8" 83" belt and the Onan powered 416-8 uses a 5/8-84" belt. Go ahead get what the manuals say and partstree as well and let us know how this works for you The Onan is located further forward on the frame than a Kohler so it needs a longer belt I ended up going for a dayco belt because it was what I had readily available to purchase. I used the Toro part number to cross reference and found L582 is the part number for the belt from them and it seemed to work great. Got it all installed and can drive around again to mow. 👍 Share this post Link to post Share on other sites
Tuneup 1,459 #10 Posted August 2, 2021 If you start to notice that the clutch action is much more sensitive - jerking the tractor into movement, it's likely that the belt is not kevlar coated. If it's a Dayco, likely a non-coated belt. That coating allows for some slippage in engagement that you don't appreciate until you lose it. Keep it in mind. 1 Share this post Link to post Share on other sites
tom2p 2,394 #11 Posted August 3, 2021 (edited) If you can find a 'real' Toro / Wheel Horse OEM belt - they are the way to go molded / wrapped belts - with the name and numbers stamped (not printed) in the belt I don't know who manufactured belts for Wheel Horse - but the materials and quality control were first rate some are black - some are off -white I believe the OEM drive belts with the off-white cover allow for smoother engagement when the clutch is released Edited August 3, 2021 by tom2p Share this post Link to post Share on other sites
Bill D 2,976 #12 Posted August 4, 2021 On 7/29/2021 at 7:24 AM, squonk said: Napa 4L820W Shouldn't that be 5L? I thought all drive belts were 5/8"? Share this post Link to post Share on other sites
squonk 47,276 #13 Posted August 4, 2021 6 hours ago, Bill D said: Shouldn't that be 5L? I thought all drive belts were 5/8"? Yup. My mistake Share this post Link to post Share on other sites
