Felix 145 #1 Posted July 16, 2021 Gone from bad to worse. I had one running tractor and one dead one. Now both are dead. I tried to start the old c120 I’ve acquired and couldn’t get a spark. I fitted a new coil and still nothing. so I put the new coil on the running B80 I have to test it and it turned over a few times and then stopped. Now it won’t turn over at all. Could this be coincidence or have I blown something. Any ideas any body? Share this post Link to post Share on other sites
squonk 45,383 #2 Posted July 16, 2021 If that B-80 has an ammeter, check the connections there. Share this post Link to post Share on other sites
pfrederi 19,801 #3 Posted July 16, 2021 Coil would not prevent cranking. Check all your connections may have yanked something loose during the swap. Share this post Link to post Share on other sites
Felix 145 #4 Posted July 16, 2021 4 minutes ago, squonk said: If that B-80 has an ammeter, check the connections there. No there’s no ammeter on it. It started to crank with the new coil then suddenly stopped and I’d now there’s nothing. it’s never done this before. I was wondering if I got the wrong coil and it’s somehow blown something. Share this post Link to post Share on other sites
oldlineman 1,638 #5 Posted July 16, 2021 I don't have experience with the B-80 but may be a blown fuse if there is one on that model. Bob Share this post Link to post Share on other sites
Gregor 4,847 #6 Posted July 17, 2021 3 hours ago, Felix said: I was wondering if I got the wrong coil and it’s somehow blown something. The ignition circuit, and the starter circuit are completely separate. At least they are suppose to be. One has nothing to do with the other. Share this post Link to post Share on other sites
rmaynard 16,843 #7 Posted July 17, 2021 (edited) Check your safety switches. Edited July 17, 2021 by rmaynard Share this post Link to post Share on other sites
Felix 145 #8 Posted July 17, 2021 Problem solved. A wire had come of pto safety switch thanks everyone 👍🏻👍🏻👍🏻 4 Share this post Link to post Share on other sites
Tuneup 1,452 #9 Posted July 17, 2021 3 hours ago, Felix said: Problem solved. A wire had come of pto safety switch thanks everyone 👍🏻👍🏻👍🏻 Hey Felix - your Wheel Horse is speaking to you. One wire fell off meaning the other wires are about to do so. Time to take a close look at the wiring on that old machine. Share this post Link to post Share on other sites
