crazy passworD 3 #1 Posted June 27, 2021 I need to put new rings in my p220g onan engine.i am unable to find the correct part number.Do they still make rings to fit this unit? crazy passworD thanks Share this post Link to post Share on other sites
lynnmor 8,089 #2 Posted June 27, 2021 Google this part number for standard size and choose a supplier: 113-0310 1 Share this post Link to post Share on other sites
19richie66 17,763 #3 Posted June 27, 2021 Have to admit.... when I first saw this I thought it said “onion rings”. No help at all I know. Good luck in your search. 1 Share this post Link to post Share on other sites
onanparts.com 185 #4 Posted June 28, 2021 There were two different ring sizes found on the P series Onan's. You must measure not only the bore, 3 1/4 is STD, but also the compression ring thickness to determine the correct rings. 1/16 part # 113-0310, or 5/64 part # 113-0314. No caliper or mic handy? Pocket change will do the trick...:) Share this post Link to post Share on other sites
crazy passworD 3 #5 Posted June 28, 2021 Thanks!You made it simple. Now i know what to order. Thanks again Share this post Link to post Share on other sites
