Aldon 4,832 #1 Posted June 21, 2021 Does anyone know what the part number is for the double pulley on discharge side of the 48 inch deck? I bought a used bagger set up that I want to retrofit to go on my C160's 48 inch deck. The only part obviously not provided was the drive pulley for the bagger which is a double pulley set up on the right side or te one next to the discharge chute. Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted June 21, 2021 44 minutes ago, Aldon said: Does anyone know what the part number is for the double pulley on discharge side of the 48 inch deck? I bought a used bagger set up that I want to retrofit to go on my C160's 48 inch deck. The only part obviously not provided was the drive pulley for the bagger which is a double pulley set up on the right side or te one next to the discharge chute. I don't know the answer, but I wonder if it's the same pulley as the center? If it is, I might be able to fix you up if you have the keyed 3/4" shaft spindles. IM me if you're interested and we'll talk. Share this post Link to post Share on other sites
Aldon 4,832 #3 Posted June 21, 2021 Im assuming its the same. but not sure. Share this post Link to post Share on other sites
Jeff-C175 7,207 #4 Posted June 21, 2021 57 minutes ago, Aldon said: Im assuming its the same. but not sure. I can't think why it would not be the same... of course you won't be able to run the belt/pulley cover on that side. Does the bagger attachment come with a belt cover to replace the existing one? I've not seen a belt driven bagger for a WH, is this something that WH sold as an attachment? or aftermarket? You said your machine is a '78 so I presume that you've got the 3/4" keyed spindle shafts? Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted June 21, 2021 1 hour ago, Aldon said: Im assuming its the same. but not sure. I can't think why it would not be the same... of course you won't be able to run the belt/pulley cover on that side. Does the bagger attachment come with a belt cover to replace the existing one? I've not seen a belt driven bagger for a WH, is this something that WH sold as an attachment? or aftermarket? You said your machine is a '78 so I presume that you've got the 3/4" keyed spindle shafts? It appears that the second pulley is a bit smaller than the primary pulley. This is from a thread here by @cleat from 2016 Share this post Link to post Share on other sites
